Question about SanDisk Sansa e250 MP3 Player
M250. Not recognized by My computer? Why?I had a new mother board put in.(power outage (short) seriously damaged poor computer) Since then the simple plug it in, and edit and add files is a no go? I use the same cable for my camera.. no problems down loading photos etc... What has happened? the m250 works well with what is already in it.
  • 80 Answers
This problem can be solved by just installing the drivers of the m250, to your computer. if the drivers are installed it will work well as before,thank you plz rate me..
Posted on Jun 28, 2009
How do I fix an issue PC Bios not recognizing memory on HP Pavilion a6228x PC?
The beeps are a bios error code. Sounds to me like a power supply or motherboard got toasted. Refer to owners manual what the beeps mean.(how many, how far apart. Longs and short beeps etc are all codes)
Sep 18, 2015 | HP Pavilion a6228x PC Desktop
Power too computer will not come after power outage
Check your surge protector, it may have tripped due to a surge in power.
If you didn't have it on a surge protector you could have blown a capacitor in the power supply. In that case replacing those is pretty simple just 4 screws and paying attention to what and where you disconnect from the mother board
Mar 29, 2014 | Dell Studio Slim-Tower Desktop Computer
Dell inspiron 560 won't recognize network adapter
Try reinstalling the NIC driver. If its separate network card, connected in PCI adapter, try to remove and plug it back in to see if its found after.
If these actions do not help, maybe NIC was damager with the power outage, it can happen.
Nov 04, 2012 | Dell Inspiron 560 MT Celeron 450@ 2.2GHz...
Power to house went out during area power outage. Everything came back on except the computer? Tries to restart by holding power switch in, unplugged and replugged power cord - no response on monitor. ...
When the power is returned after a power outage it can cause a power surge and damage electronic equipment such as a computer. This is a reason to install a surge protection power board and connect your computer equipment to a surge protection board.
The switch mode power supply may be faulty and replacing it may get your computer operating again.
If you cannot DIY then ask a friend or take it to a computer repair shop.
Jul 14, 2011 | HP Pavillion s7420n PC Desktop
After replacing my psu (was old and it shorted out) my LG CD-ROM GCR-8523B doesn't work. It has power but the computer doesn't recognize it..?
It is possible that when psu shorted it shorted part of the mother board. Try going into device manager right on the cd-rom in the list and choose search for new hard ware in the drop down menu. If this doesn't work go back into device manager right click the cd-rom and uninstall the cd-rom and reboot the pc. If it does not auto find the cd-rom that way, the mother board is probably messed up. Oh yeah try unplugging the ribbon cable for the cd-rom from the mother board and plug it back in also.
Please rate, and write testimonial if you feel the need to, if this was helpful.
Thank You
cookieMonster
Oct 06, 2010 | LG GCR 8523B Internal 52x CD-ROM Drive
Wont turn on.no light on when ist plugged
A blown fuse is a very common type of fault due to poor design very often triggered by power surges due to outages or lightning storms. However, the most likely parts to short are easily tested, usually in-circuit, with an ohmmeter and then easily removed to confirm.
Note that it *may be* useful to replace a fuse the *first* time it blows (though it would be better to do some basic checks for shorted components first as there is a small chance that having a fuse blow the second time could result in additional damage which would further complicate the troubleshooting process). However, if the new one blows, there is a real problem meaning that your power Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this work...
Jun 07, 2010 | LG 42LB1DRA 42 in. LCD Television
Dell Dimension 3100
You most likely just need a new power supply. You can pick these up for around $40 for a 450W, which is plenty for your machine. Pretty simple to replace, unscrew the 4 screws in back, around the fan on top, then unplug all the power wires, pull the old one out, and then put the new one in. There is a slim chance that other components were damaged, but this is your first step to fixing it. The power supply is the martyr of the computer. It will throw itself in front of power surges to save the rest of your computer....
Feb 11, 2010 | Dell Dimension 3100 PC Desktop
DEAD DELL
Replace the DC Jack, the battery will may charge if it doesn't get power from Positive and Negative. On that particular model it is usually the positve terminal. Insufficicent solder at production time causes a weak joint, repeated plugging in weakens the joint even further until it breaks the connection. If you have not damaged the jack badly, you may be able to get by with a simple 'reflow' of the solder. Use flux paste and add about 1 drop of solder to the terminals. Being careful not to short POS & NEG. (the contact pads are very close- use magnifying glass to verify)
Most likely the burning smell was the solder arcing around a poor solder connection.
I would suggest verifying DC jack before spending good money on a battery, since most LI-ION batteries are good for upto a thousand charges plus...
Mar 14, 2008 | Dell Inspiron 2200 Notebook
The pc doesn't recognize the m250
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
download the sansa connect recovery tool
download the manual and it will tell you how to reset your mp3
Feb 26, 2008 | SanDisk Sansa m250 MP3 Player
Computer shuts down y by itself
remove ur power supply socket from the mother board short the pin green and black in the connector if the smps start no problen with the power supply then the problems lies with ur mother board wiring or fault in your mother board if your mother board has secondry power fix it correctly to mother board sock et with has 4 pin if its not working cousult a chiplel engineer the fault lies in the power supply of the motherboard
Dec 02, 2007 | EliteGroup 945GZT-M (V1.0) Motherboard
SanDisk Sansa e250 MP3 Player Logo
138 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
