Question about Frigidaire GLTR1670A Front Load Washer
The machine won't drain and then won't spin...?
  • 232 Answers
Please unplug the washer!!! if you have a wet / dry vaccume **** the water out at the drain hose remove the lower front cover and remove the rubber hose at the pump water may still come out so have vac ready. check in the pump and the hose for blockage put back togeather plug in and put in spin you should here the pump running if it is and still wont pump water then replace it if it isnt thet check for power to it if power is ther replace it if not its probly the timer good luck be careful
Posted on Jun 28, 2009
Washer doesn't spin out sometimes
you say it drain, but sometimes it won't spin,this could be your filter if it is blocked these new machines can sence it and won't let the machine spin easyest thing check your filter,you never know might be that simple
May 07, 2012 | Washing Machines
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Washing machine won't rinse and the water won't drain out.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 04, 2011 | Washing Machines
Washer will wash but won't spin or drain
heatman101
Aug 11, 2011 | Kenmore 22422 Top Load Washer
My washer won't spin and drain. what should I do?
heatman101
Aug 09, 2011 | Kenmore Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Washer won't drain
heatman101
May 23, 2011 | Washing Machines
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Washing machine won't drain
heatman101
May 14, 2011 | Frigidaire Washing Machines
My Westinghouse LT 9555 washing machine won't spin how to fix problem??????
heatman101
Nov 06, 2010 | Westinghouse Washing Machines
Frigidaire GLTR1670A Front Load Washer Logo
185 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
