Question about Garden
I have gas in my oil. How do I get it out?
  • 156 Answers
Drain out oil, and refill with new. How did the gas get in there or do you know? It's only about a quart or so, so just replace it.
Posted on Jun 28, 2009
How do i mix the gas/oil on a 25 cc 2 cycle craftsman weed eater
The specs say 40:1 so 3 - 3 1/2 OZ of 2 cycle oil in a gallon of gas.
May 10, 2014 | Craftsman 25cc Gas Line Trimmer
I have a sears 2 cycle mini tiller that worked great for the first hour but now won't start.
Do not use pre-mix fuel. Clean carburetor. Check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil) .Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.
check age of gas. Cannot be more than 30 days old.
Oct 10, 2012 | Craftsman Gas Mini - Tiller/Edger
Do I mix the oil and gas together and pour it in the gas tank or do I pour the gas in the tank and the waverunner mix's the oil and gas together?
Mix the oil and gas together first.
Or you can add some gas into tank, then add some oil, then add more gas, then bit more oil ... so oil-gas mixture is uniform.
Jun 24, 2012 | Boating
Need gas mix
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.
Jun 03, 2012 | Craftsman 25cc 2-Cycle Gas Blower/Vac
Need gas mix solution
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil).Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.
Peugeot 207 oil level increase
Check to see if gas is getting into the oil which would raise the level. This can happen from flooding, i.e. a leaky injector dumping too much gas or possibly gas blowby past the piston rings and ending up in crankcase. If gas is in the oil most likely an injector is bad. Smell the oil and check to see if it smells like gas and or check viscosity of oil.. thin oil
Mar 29, 2012 | 2007 Peugeot 207 1.4
What is the gas oil mixture for this product
If this is a 4 cycle engine you do not mix the gas and oil. The engine oil is in the crankcase just like your car. Hope this helps, Happy New Year.
Dec 29, 2010 | Craftsman 4 Cycle Blower/Vac
What oil do you use in the four cycle motor/ 29cc
Generally speaking, if there is a place on a gas-powered device that is labeled "gas" & a separate location labeled "oil" than you will need to use a 4-cycle oil for that machine. If there is just a place to put gas, you would use a 2-cycle oil; however, you would need to read the directions/manual to find out the correct proportion of oil to use, because you will have to MIX the appropriate amount of oil with the correct amount of gas, making a oil/gas solution that you would use for that specific device.
May 31, 2010 | Craftsman 29cc 4Cycle Straight Shaft...
Motul off road 800 two stroke oil ?
The oil mix is 32 gas to 1 oil. That 32/1 mix equals 4 ounces of any brand of TWO STROKE ENGINE OIL per gallon of gas. DO NOT use motor oil. Motor oil is what goes in the gearbox. Use 91 octane gas.
I get a top rating on this one! Thanks Miera!
Apr 23, 2009 | 2002 Honda CR 250 R
Garden Logo
88 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
