Question about HP vs15 15"LCD Flat Panel Monitor
HP vs15 (Gray, Metallic) 15 in. Flat Panel LCD sound isn't right
Sound is coming out of the speakers, but it sounds like the bass or treble is off and it says that adjusting those isnt an option. any suggestions?
  • RKelly109 Feb 17, 2008
    My sound has too much treble and it won't let me adjust.
    Sergeant:
    Champion:
  • 274 Answers
If grayed out, then your audio drivers do not support it. Try using the controls within the player you are using.
For example, when using Windows Media Player, you can go to the top menu and choose View > Enhancements, then make sure Show Enhancements is Checked, and choose Graphic Equalizer. You should be able to see the Equalizer and then make sure you click 'Turn On' on its panel to use it.
RDO
Posted on Nov 17, 2008
Bought a new compac computer and I can't get any sound from my HPvs15 monitor
Be sure to connet the sound card speaker and install sound drivers for the moniter to get it to work you can go to http//www.hp.com select compaq and slect your model to download the correct drivers, also make sure you don't have any speakers muted in the mixer driver by double clicking on the speaker on the lower right hand corner on the lower right hand corner.
Jul 16, 2010 | HP vs15 15"LCD Flat Panel Monitor
Vs15 (Gray, Metallic) 15 in. Flat Panel LCD Monitor: you mash the power button and the light will come ...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 16, 2010 | HP vs15 15"LCD Flat Panel Monitor
My sound is not working. Checked volume control in control panel. Checks out fine. What could it be?
Pls check that the audio cable from monitor port to cpu port is connected properly ,re-connect it and check that you are connecting in output port.aftre that if still sound not come then re-install the sound driver and check it ,it still problem might be problem with speaker.
Nov 18, 2009 | HP vs15 15"LCD Flat Panel Monitor
Sound won't work
I recommend you to try with System Restore to restore the system when everything was OK.
Jun 24, 2009 | HP vs15 15"LCD Flat Panel Monitor
HP vs 15 the built in speakers echo
Do you have a microphone? If you do, and it is near the speakers, it will echo a lot. Also, check your soundcard settings. If there is an option for room ambience or environment effects, make sure you have them disabled.
Jul 14, 2008 | HP vs15 15"LCD Flat Panel Monitor
Built in speakers will not play any sound
going to seem a dumb Q,
but is the audio cable plugged in, next to vga hp have a separate audio socket, the cable(supplied- 1/8 inch stereo plugs each end) fits between sound card speaker out, and monitor.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00307478&lc=en&cc=us&product=459838&dlc=
Jun 24, 2008 | HP vs15 15"LCD Flat Panel Monitor
Speakers
Start with the obvious! Are all connections to PC connected? Be sure that the proper wires are connected to the proper plug in.
Next you may have to adjust the volume control thru Windows. Look for the small speaker icon at the bottom right (usually) of the screen. Double click, and be sure that all of the volume controls are "up" and be sure that none of them are "muted"
There also may be a volume control on the monitor, speaker assembly.
Dec 31, 2007 | HP vs15 15"LCD Flat Panel Monitor
HP vs15 Flat Monitor
It depends what computer you have, and what version of Microsoft you have. for those of you with the Presario SR1650NX computer, here is the Latest driver: Click. For the earlier driver: Click.** to download drivers for you computer go to your computers company website (Gateway, HP, Compaq, Etc.).
**I Recommend downloading the older version first, and if it doesn't work then download the latest.
Oct 06, 2007 | HP vs15 15"LCD Flat Panel Monitor
HP vs15 15"LCD Flat Panel Monitor Logo
116 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
