Question about GE 27934GE1 Twin Cordless Phone
Lost instructions for 27934ge phone
Need to get second handset working
2 Suggested Answers
  • 45 Answers
SOURCE: My second handset for the GE 6.0 cordless phone will not register
here is the manual:
http://www.tvears.com/pdf/27907-GE-Manual.pdf
Posted on Aug 19, 2009
At&T EL52300--one phone reads 'out of range-move closer to base.' I did--it doesn't help. Battery OK---What do I do?
It appears that the one handset has become orphaned and
must be de-registered and then re-registered.
1. To de-register the orphaned handset from the old base:
When the orphaned handset says "Connecting..." or "Out of..."
enter *331734 [menu]
and it will soon beep and display "Not registered"
2. To register the new handset to your base:
press the "Handset Locator" button on the base and hold
it until the "in use" light comes on ( ~ 4 seconds ),
then release the button and set the new handset into
the base phone cradle. After ~ 30 seconds it will beep
and display "Handset #" (next in sequence).
3: Note: the base handles a maximum of 12 handsets.
If your system was fully populated ( ie, a handset is
already # 12 ) you will have to clear all the handsets
from the base and re-register them all in sequence.
( it is the only way to 'rescue' the places occupied
by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button
until the "in use" light lights and then starts to blink
( ~ 10 seconds ), release the button --
then press it again briefly while the "in use" light
is still blinking.
2. The base will beep and all handsets that were registered
will display "Not Registered"
3. Follow the instructions above for each handset
in turn to re-register them:
press "Handset Locator" ~ 4sec ( in-use light on ),
set handset into the base cradle, etc.
The manual is available from: www.manualslib.com
but does not fully describe these procedures.
Good luck !
Oct 17, 2014 | AT&T El52300 Cordless Phone
How do I register the handset
The base thinks that it lost connection with it temporarily but the handset has been replaced. You simply need to register it with the base. The instructions for doing so will be in the manual.
May 31, 2014 | Uniden Cordless Phone
Out of range or no pwr at base
It sounds like the handset has "lost" its registration with the
base ( or a replacement handset is being introduced ? )
Either way, the handset displaying "Out of range..." is now
orphaned and must be deregistered and then re-registered
to the new/current base.
enter *331734# (menu)
is still blinking.
Good luck !
Oct 14, 2011 | AT&T TL32100 Cordless Phone
The second handset says "not registered" and won't work. I lost manual. How do I "register" it so the mainbase recognizes it, please? Thanks.
1. Place the unregistered handset on the charger.
2. Press and hold the FIND button for 4 seconds on the base.
3. Release the FIND button once the IN USE light starts to flash.
4. A confirmation tone will sound when registration is successful. Handset X is displayed where X denotes the number of handsets. The phone will then go back to idle.
just in case you need it:
User Manual Clarity D613C Combo Pack (D613 with D613HS)
Don't forget to rate if this was helpful :-)
Sep 22, 2010 | Clarity D613HS Phone
here is the manual:
Aug 19, 2009 | GE 28111EE2 Cordless Phone
NEED TO DEREGISTER LOST HANDSET
The "END" and "#" key combination can be used for several purposes:
1) If wanting to use an ALREADY REGISTERED HANDSET on an alternate base, and if if the INITIAL BASE isn't available to deregister the handset:
1a) Press "END" + "#" until it for 5+ seconds (wait for it to beep)
1b) Choose the "Base Unavailable" option
1c) That'll deregister the CURRENT HANDSET so that it can be re-registered on ANY base.
2) If a BASE has a handset registered to it which you no longer want registered but the registered handset is missing or broken:
2a) Grab another WORKING handset which is properly REGISTERED to the BASE in question
2b) Press and hold the "END" + "#" key for 5+ seconds (wait for it to beep)
2c) Choose the "Deregister HS" menu option
2d) Pick the REGISTERED HANDSET # to de-register. (Every other registered handset EXCEPT THE ONE YOU'RE ON will appear in the list!)
May 08, 2009 | Uniden TRU8866 Cordless Phone
Ge 27831 Cordless dual phone 2nd handset doesn't work
Another user (thank yoiu but I'm sorry I forgot his/her name) had the answer. It was ihe instructions but I missed it. Needed to set the 2nd handset into the main base for 20 seconds so that it could align itself.
Mar 21, 2009 | GE 27831 Cordless Phone
How to connect additional unit to base unit special code ?
Hello. Here is how you do register your handset below, and a link to the manual its on page 46. The procedure depends on how many handsets you have. If you only had one handset follow the directions below. If you have more than one handset follow the second set.
On the handset push menu, then dial 0 0
On the base, push and hold down the locator/intercom button until the charge light flashes
Press OK on the handset, and it should automatically register in a few seconds.
On the base, press select until you see the intercom number you wish to register it to. Stop there and push the Call button until the charge light flashes
Push OK on the handset, and it should register
Hope this helps
http://service.us.panasonic.com/OPERMANPDF/KXTG5631.PDF
Feb 28, 2009 | Panasonic KX-TG5632 Phone
Re-registering handset ge 27851
This should work. Unplug the base power and leave unplugged or a minute or two. Plug the base back in and place the handset you want to register as handset 1 on the base and leave there for 20 seconds. If you want to register more handsets then place each one in the base for 20 seconds in the order you want them numbered. If this doesn't work you may need to remove the batteries from the handsets as well when you unplug the base. I hope this helps.
May 17, 2008 | Uniden Cordless Phone
Handset wont register
To register the handset:
1. make sure phone is charged
2. hold down the "mute/program button on the phone 10 seconds.
3. you should see a message on the screen that says you need to push the "pager button" on the handset.
4. Push the pager button
Apr 10, 2007 | Uniden Cordless Phone
GE 27934GE1 Twin Cordless Phone Logo
66 people viewed this question
Top GE Lands Phones Experts
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
