Question about Dometic Rooftop RV Air Conditioner
Can a roof top AC be recharged? - Dometic Rooftop RV Air Conditioner
    Problem Solver:
  • 10 Answers
YES YOU LOOK FOR CAPS IF NO CAPS BUY INSTALL KIT.
Posted on Jun 28, 2009
Can I recharge a Duo Therm 600315.001 RV Roof mounted air conditioner? It uses R22 refrigerant. If not, where can I find a replacement or can it be serviced somewhere?
I would suggest that you visit an ac specialist shop as all air conditioners( car, truck , house and yours all use the same principle of operation
because it is roof mounted in an RV may be a caravan repair shop that has an ac specialist in the workshop or a truck service shop that installs ac units in truck cabins would be a good place to start
Mar 13, 2016 | Dometic Heating & Cooling
My carrier ac roof top ducted unit started spitting out small amounts of water now and then, I changed filter. Now with ac in off position I am hearing a humming noise coming from the unit, what can this...
Don't really understand what you mean by roof top duct unit .if it's a roof top unit and water is leaking down your vent then you have a clogged drain line .
Mar 02, 2018 | Dometic Rooftop RV Air Conditioner
Carrera roof is stuck
As is typical with all German cars this tops operation requires a scanner to analyze, off to the dealer with you.
Feb 22, 2012 | 1999 Porsche 911 Carrera
I have a roof top ac unit Model #7333C886 and someone is telling me that it cannot be recharged. Is this true cause it seems to be working fine other than not getting real cold. It is an older model I know...
It is a closed system, which normally they don't require recharge. It can be done but it is more or equal expense as buying a new unit. A lot of times a real good cleaning by someone who knows how to do it properly is all that is needed in cases such as yours.
Aug 23, 2011 | Coleman Mach 15 Air Conditioner
Was given a roof top ac for a popup camper need help
Make and model of unit should be on base of roof assy, please reply with that so we can be sure we have right wiring info for you. Although they are pretty common, let's be sure.
Jul 30, 2010 | Dometic Rooftop RV Air Conditioner
I put R-134 in my Coleman Roof top AC unit. I found out a month later i needed to use R-22. Will the R-134 damage the unit? the unit was empty when i filled it with r-134. any suggestions.
The oils used in the two different refrigerants are not compatible with each other. The will actually plug up some of the system tubing over time and will eat away at the compressor windings. The roof top unit should not have any rubber seals to worry about like a car.
The only thing you can do is remove the R-134A from the system, flush the system with liquid R-22, replace the compressor recharge it.
I know that is not what you want to hear but anything less than that will only be a short lived fix at best
May 11, 2010 | Dometic Rooftop RV Air Conditioner
Looking for schoolbus roof-top AC installer in Houston, Texas.
You can get lots of roofing companies in Houston TX. Just like CM Construction Remodeling, It is near to your location and helpful for you, get a fast response with reasonable price.
Apr 28, 2010 | Dometic Rooftop RV Air Conditioner
How difficult / expensive is it to install a heat strip in a Dometic roof top AC? The unit I have has a mark on the knob for heat, but I suspect it was never installed.
Fairly easy. The only thing that you must figure out is how many amps the heat strips will draw. Make sure the fuses and the breaker switch can handle them. And be aware your electric bills will shoot up.
Oct 20, 2009 | Dometic Rooftop RV Air Conditioner
Can my duo-therm air conditioner on my rv be recharged?
These unit can be recharged. 134A. You NEED A SERVICE TECH THAT KNOWS HOW TO CHARGE UNIT.RUS
Jun 24, 2009 | Dometic Rooftop RV Air Conditioner
How do you recharge a roof top ac unit
you will need to install access valves for charging.a set of gauges and r-22 . to by freon r-22 you need to be EPA certified. Tom
Jun 13, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
390 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
