Question about Midland 77-092 40-Channels Base CB Radio
Midland model no. 77-092, bought it used. did not
Midland model no. 77-092, bought it used. did not realize previous owner put in bigger fuse on hot wire. when i powered up something smoked. removed power source. cicuit board was hot by the transformers. any permanent damage? what could be wrong?
    Novelist:
  • Midland Expert
  • 500 Answers
Yeap when the magic smoke is let loose. does it work now? or did leave it alone? there will be a burnt diode, possible burt circuit traces. cb shop temple, tx on yahoo search.. and if lucky thats all and it should work fine. if the traces didn't burn they the audio transistor can get damaged. but most times it will burn the traces..
Posted on Dec 08, 2009
Midland 77-118. Three wires coming out of unit red,black,and orange. What is the orange for? Also need manual.
Its like the wiring in your house. That little three prong plug. There are three wires, one black,one white, and one green. The green is a ground wire , the black is neg flow and the white is positive flow. Well the red wire is hot ,the yellow wire is neg flow,and the black is ground. Some times the yellow wire isn't even connected. Look inside your radio and you will only see a red and black wire???you will have to google the radio model as such ( 77-118 owners manual)
Sep 01, 2015 | Midland Radio Communications
Blows 15amp fuse even when all but the main cable is connected to the speedo. *FIXED*
Hi Barry, you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. Good luck and have a nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 22, 2015 | GAS Motorcycles
Bought a Midland CB when I hook it up the fuse shoots.
Probably was a used unit. If so someone smoked it. If its new take it back to Radio Shack. Make sure you have OBSERVED THE PROPER POLARITY.
Aug 28, 2014 | Midland Radio Communications
What is the code to unlock garmin 285 w
you bought a stolen device and the code was locked by the previous owner. The only way to get the code unlocked without knowing it is to take it back to where the code was set (previous owner?) then it will let you unlock without the code. Otherwise you bought a paperweight.
Jul 25, 2014 | Garmin nuvi GPS
Re-jet carb and now idles rough with popping and stuttering
Try to adjust valves sometimes small gap will cause engine to respond rough if valves are not adjusted. Good Luck.
May 09, 2012 | 2006 Honda VT 750 Shadow
2000 FORD WINDSTAR PASSIVE ANTI-THEFT SYSTEM)
not knowing what the prior owner did, you do have a problem, you might try to remove that fuse, disconnect the battery and re-try it, if still NO-START and the THEFT light is flashing it because it lost memory for the key code and will have to be recoded at your dealer
Jul 04, 2009 | 2000 Ford Windstar
Can't figure out how to get a "channel" to lock on the handset
Here is a link to the owners manual for the LXT-330 420 Series radio:
http://www.hitechwireless.com/pdf/Midland/LXT-330-420 Owners Manual.pdf
I hope this helps.
HiTechWireless.com
Mar 27, 2009 | Midland LXT410 (14 Channels) 2-Way Radio
Heater coil has bone bad on 2000 Kia Sportage
what is your location?? just get it to a cheaper shop, ofcourse theyll offer you much lower rates,
Jan 15, 2009 | 2000 Kia Sportage
Runnig Hot
put a bigger fuse in...if that doesent work u have a short somewhere its a wire grounding itself out onto some other part of the car..its almost impossible to find the short tho..i would take it to a saturn dealer if the bigger fuse idea does not work..good luck
Jun 07, 2008 | 2001 Saturn SC
Midland 77-092 40-Channels Base CB Radio Logo
172 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
