Question about Belkin Computers & Internet
I have a belkin wireless router model FSD7633 I recently had my computer a desktop repaired which is wireless and since then have not been able to get any web pages to come up even though it tells me I am connected. My other computer is a laptop which is connected to the router to the wireless router and it is working fine could you help me resolve this problem
  • 1 more comment
  • kerrylorna Jun 28, 2009
    did as suggested and checked the firewall but all this did not work all I get is a webpage saying internet explorer cannot display this webpage
  • kerrylorna Jun 29, 2009
    I have tried all you suggested still no web pages( I think the solution may be a bullet) I have no idea why I am having this trouble as everything worked fine till the registry packed it in and was replaced the guys at computer shop say computer is working fine and the laptop is to so I throw my hands in the air unless you can think what else it could be
    i have tried just about everything done the ping thing and all ip address seems right I think I will have to call someone in do you agree
  • 10,515 Answers
It seems that there is something wrong with the wireless settings.There are 2 aspects of internet connection.
1. Router Setting :-
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx
2. Computer Setting ( Seems to be this reason in your situation ) :-
Check I.P address, Subnet Mask, DNS Server settings.
A Nice article :-
Go to each PCs Internet Protocol (TCP/IP) Properties for Local Area Connection (LAN) or Wireless connection, whichever applies.
You only need to set the TCPIP numbers manually if there is an error in your Router's configuration. As you've just ensured that DHCP is turned on, you should set your TCP/IP settings as follows: -
On the General Tab: -
Obtain an IP address automatically
Obtain DNS server address automatically
Click on the Advanced button.
Add a Default Gateway
Put the IP address of your router in here.
On many routers this will be 192.168.0.1 - on some others it will be 192.168.1.1 or 192.168.0.254 or 192.168.1.254 - but it could be in some other range - however, you can usually find this information in the Quick Start Guide OR somewhere in the Router's LAN settings. Anyway, I'm pretty certain you know which it is by now.
Ensure Automatic metric is also ticked.
The following settings can also be applied while in this "Advanced" mode.
Click on DNS and ensure "Append primary and connection specific DNS suffixes" and ensure there is also a tick in the "Append Parent Suffixes". Then tick Register this connection's address in DNS. (Not being a TCP/IP specialist, I'm not sure whether these are strictly required, but they work for me).
My WINS Tab setting also has "Enable LMHOSTS lookup" and Netios is set to Default.
My Options tab has Optional setting TCP/IP filtering, the properties of which are set to Permit All.
When you click on OK to complete the "Advanced" setup, check that the "Alternate Configuration" tab is set to Automatic private IP address.
Those settings should work for every router with the private side DHCP server working correctly. You should never need to set a static IP address with these settings. I would be more inclined to say that there was an inconsistent setting in the router.
However, you may need to set a fixed IP address if you intend using a file sharing system. This also means that you might need to configure your firewall - and is beyond the scope of this particular guide - that would be far too advanced for most users.
Update me once done!!!!
Thanks for using "Fixya'.
Posted on Jun 28, 2009
  • taran_2005
    taran_2005 Jun 29, 2009
    Thanks for your response.
    The ping would only define, if the network is working or not. There are so many factors that might hamper starting from Firewall to Virus to Motherboard. Being not there, we can only make intelligent guess that what might be an issue.
    It seems to me that , it has to be related with the security or setting of router. Either install the router settings from scratch or if you wish you can call the service provider to check the setting.More likely, it's a case where either you might have punched few wrong numbers or router setting needs to be checked.You can call the service provider and get this checked.
    Hope i helped you.
    Thanks for using "Fixya".
  • 854 Answers
Check the IP Address of your pc
For XP computer:
1. go to control panel
2. click network connections
3. right click Local Area connection
4. click properties
5. high light internet protocol TCP/IP
6. Choose properties
7. choose "Obtain IP address automatically" & "Obtain DNS automatically".
8. Click "OK"
For Vista
1. Click "Start" > Go to "Netework"
2. Click "Network and Sharing Center"
3. Click "Manage Network Connections"
4. right click Local Area connection
5. click properties
6. high light internet protocol TCP/IP
7. Choose properties
8. choose "Obtain IP address automatically" & "Obtain DNS automatically".
9. Click "OK"
Check Firewall settings. You may have "denied" the connection...consult your firewall tech support to configure this. The firewall usually is incorporated with the antivirus.
What is a belkin n wireless usb adapter model # fsd8053v4 used for and can u connect to the internet with it and where do i get the driver?
The wireless adapter is used to connect wireless to the internet, You can use it to make your desktop wireless and laptop.
You can connect to the internet as long as you have a wireless router in your place that will supply the wireless signal.
The driver can be download on this website
http://www.belkin.com/
cheers,
KA
Jun 15, 2010 | Linksys Wireless-G WRT54G Router
Accidently made my belkin router secured to just one computer
When there is another computer in your house and have also wireless lan connection.
Automatically can detect your Belkin Wireless Router with Name of it. But they are going to enter a passcode so that they can access the internet. And knows you have the passcode access to the router.
That's very easy because wireless lan obtain & detected network available on the area.
Hope this idea can help to you.
If i am helpful please rate me.
Thank you.
Yboyandrei
Aug 18, 2009 | Computers & Internet
Wirless router
nope...
your desktop can also go onlie using the wireless belkin router,so this router will now act as a distributor,you need to setup the router between the modem and the computer that is wired,i hope that when you say modem it is the one provided to you by your internet service provider,what you need to do is to conect the modem to the router and the router to you desktop computer,you desktop computer will go online using the wired connection to the belkin rotuer and you laptops will use the wireless connection..
vedhick
Feb 18, 2009 | Belkin (F5D7230-4) Router (587009)
Wireless Router use with Wildblue Satelite Modem
You should be aware of a class action lawsuit that Belkin and the complaintent settled recently. The lawsuit was filed complaining that certain Belkin routers did not obtain optimal speeds as advertised.
Belkin has agreed to provide affected customers a discount program to purchase a new router. You will need to search elsewheres for the details.
Sep 28, 2008 | Belkin (F5D5231-4) Router
Have belkin wireless/modem router, was using aol but now with the utility warehouse using there uwclub.net service. They sent a thompson speedtouch fixed line modem which we had to connect to get on i.e.,...
Try using a dynamic ip address. I think you only use the static if having problems. Just read this.
A dynamic IP address is assigned to a customer’s modem or router, generally via a remote server (such as our own UWClub server). This provides the user with an IP address from an available pool of addresses every time a connection is made. This is the most common type of IP address for our broadband/Broadcall customers.
Thats off The Utility Warehouse page.
Aug 04, 2008 | Computers & Internet
Problem with connection to router and DSL
I would go to run and type in cmd. then type in ipconfig, I believe that is right for windows 98. I would look on there and see if that is getting a correct IP and if the DNS server says 192.168.0.1 if it is a belkin router. ipconfig /? will give you the commands you can use with that. There is a ipconfig /renew that will refresh them all. You might have it set to be a static IP and you would want it to be dynamic and have it refresh by itself. You can go to http://hippo.colorado.edu/info/ipsetup/staticip_setup.cgi?os=win98 for directions to change it to dynamic, I would just do the opposite of what they suggest to make it auto config. It sounds like it is looking for a previous DNS server which is not there anymore because the DSL connection reset.
Dec 20, 2007 | Belkin (F5D7230-4) Router (587009)
Belkin WirelessG Plus Mimo
Consider securing the wireless connection if you have not done so your neighbors MAY be able to utilize your wireless connection and your bandwidth if you do not.
see http://www.fixya.com/support/t281214-wireless_security
Secondly if I understand you you have 4 computers using the router to access the modem connected to your Internet Service Provider; three using wires and one using the wireless. First have youneed to confirm that your internet service provider allows multiple devices to share the connection (which is what your router is trying to do). If so do you have to logon / login to your ISP to access the internet? (This login may be hidden from you in the modem provided by the ISP) Research if it is required to have your router logon to the ISP instead of either one of the computers or the modem in order to support multiple users. If that is the case you will need to determine if your router is capable of performing the logon for you and configure the necessary devices appropriately.
I can possibly help with the above but will need to know your ISP, and the manufacturer and model for your router and wireless card(s) to assist in configuring the components. The manufacturer and model information will also provide a basis for securing the wireless network if desired.
Dec 02, 2007 | Belkin (F5D7231-4) Wireless Router
D-Link wireless router and Belkin Wireless G USB Network adapter
Set your wireless network as a preferred network and to automatically connect to it. Also set it at the top of the list so that it takes precedence. If you continue to get conflicts, change the channel of the router.
Mike
Oct 31, 2007 | Computers & Internet
Computers & Internet Logo
50 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
