Question about Craftsman 25cc Gas Line Trimmer
Craftsman Weed eater, older won't stay running
The thing would not start, then removed and cleaned the carb. When putting it back together had to replace the primer button. THe original primer had two size line unsed and when I bought a replacement (That I could not find at sears) the primer function was reversed. Forced the lines on to work and actually had it running. Used it the other day and then ran it today for about 15 minutes
This evening I went to use it and it would start but not stay running. I would prime it, it would start then quit. This ran great this morning but not this afternoon it started acting up.
I have another smaller one that stopped running a couple of years a go. I also decided to work on this one over the past week. I took the carb completely a part because it would start after ptiming and then quit. after removing everything including the needle and putting it back together it leaks like a crazy. The needle application did not seem to move at all when I tightened the screw. In fact it seems that it has no function at all. Besides cleaning the inside and using gaskets that I bought some time back, I used a welding tip cleaner to try and clean te jet and openings. At first it ran when I primed it then quit, then after opening it all up and cleaning it now it just leaks.
Any answers besides buying new carbs?
Alan
  • Craftsman Master
  • 1,631 Answers
The symptoms you reported are commonly resolved when the following is checked, then cleaned or replaced:
  • fuel filter - located inside the gas tank
  • Spark plug
  • Spark Arrestor - at muffler. When clogged with carbon build up, the exhaust flow is extremely restricted, and causes problems
  • Carburetor - may need a new rebuild kit
And watch this...
And this one...
And one more...
Posted on May 19, 2015
  • 1,041 Answers
When cleaning the carb., this is key:
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Jun 28, 2009
  • Jim Parker
    Jim Parker Jul 01, 2009
    Did this solution solve the problem?
    Jim
When I pump the primer bulb, why doesn't it fill with fuel and stays collapsed?
new carbies start around $25.00 us on e-bay so get a new carby
take it to a mower shop for a service
rebuild the carby using a new carby kit
Nov 28, 2015 | Husqvarna 125 Bvx Leaf Blower Lawn Yard...
Weedeater PE550 will not stay on. Prior to placing this unit in long-term storage, the unit worked. Since pulling it out for this season, it would not start. I replaced the fuel lines and primer bulb. ...
Is the smoke coming from the spark plug hole or just near it?
There are three things that you need for it to work.
Fuel, air and spark.
If you are missing any one of those things, or if one isn't optimal, it wont work well if at all.
You say spraying carb cleaner into the chamber lets it start, but after a minute it dies?
That tells me you are getting a spark.
Have you taken the carburetor out and cleaned it thoroughly with carb cleaner?
Often when fuel sits around inside a carburetor it can build up gunk and make it not function properly. I recommend removing the carburetor and taking it completely apart, cleaning everything with carb cleaner and putting it back together. It sounds difficult, but I promise it is not, just take pictures to help you remember how everything goes together if you want.
Also while you are at it either clean or replace the the air filter, that should help as well. If its a foam filter you can clean it with gas, if its paper, just buy a new one.
Jun 07, 2011 | Poulan Pe550 Gas Edger
String trimmer won't start. How do I flush the
To flush system
Drain tank, use primer bulb to push out fuel in the lines, refill, use primer to bring in fresh fuel. You may need to pull the rope a few times with the choke on, and then push the primer several times again. Sometimes you may need to put a few drops of fuel into the throat of the carburetor to help it start to fire.
If the problem is severe enough, you may need to remove the carb to disassemble and clean. I have listed a few things to check.
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 12, 2009 | Homelite Mighty Lite Lawn Trimmer
Must keep pushing primer bulb to keep mower running, need manual
The main suction jet in your carb. is blocked.Remove the bowl and push a thin needle up the centre jet in the carb and blow the jet out with compressed air. Stephen.
Sep 22, 2009 | Briggs & Stratton Garden
Starts and idles but dies when i pull the throttle.
Either clogged or needs cleaning/ rebuild. ITS SIMPLE! ok If you have a Walbro WT series carb "without" a built on primer bulb here it is. First off if the fuel lines disintegrated you MUST disassemble it and clean it out. The MOST infintesimle speck of gas line trapped, can allow good prime and bad operation. OK? Don't be lazy on this. Just be delicate removing the flaps gasket and diaphram. ZAMA GND-12 Is the replacement Gasket and diaphram kit fot that carb. Use a cleaner, compressed air or blow good thru it. OK Now...Primer bulb, Carb, and Fuel tank, re connects: Smaller Diameter line comes from Gas tank (Connect filter screen to this in tank) to the short Straight brass carb connector. Primer bulb suction goes to the bent carb brass connector. If small line brings fuel "in" this other line sucks it back "Thru the primer bulb" and the blow side of the primer bulb sends it back to the fuel tank! So...Small Line brings fuel "TO/IN" carb thru short brass connect on carb. Other carb connect goes to bulb suction "IN", Then primer bulb "Pressure OUT" goes thru the larger tube "back to fuel tank". Trust me I know how frustrating a simple diagram is to find online fo this set up. And if you have a carb problem on top of the hook up uncertainty you got frustration. Not only was online help hard to find (Mfg...etc NFG at all!) My local repairshop in BBrook NJ could not tell me how!!! and thats no lie! Walbro has a "generic" carb diagram but no "hook up info" specifically. Poulan don't list it either. And these things routinly fall to pcs. all 3 of mine crumpled together on yr. 3 of use.
Jul 06, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Primer bulb on weedeater won't prime
when you prime the bulb it sucks gas from the tank with the small tube, any excess gassed pumped will be fed back to the carb via the big tube leading to the tank. If you prime it and the bulb stays pushed down, then you have a clog or kink. To fix , pull the small tube out of the tank through the fill hole. Pull off the filter on the end and put the tube back in the tank. If it primes, your fuel filter was clogged. If it still wont prime check the hose going to the carb and make sure isnt clogged or kinked.(take of carb and blow in it). If that doesnt fix it take off the bulb from the carb with two screws. The bulb assembly will come off too(rectange metal thing) Take off the two black gaskets, be carefull with them. Take off hoses from carb and bulb asembly. Blow carb cleaner in all holes and over surface. Put back together.
If the carb wont prime and the bulb isnt staying depressed. then you might have a bad bulb or carb gaskets. Make sure hoses are not cracked, cloged, or pinched.
Jun 17, 2009 | Troy Bilt Tb70ss Gas Trimmer
When the primer bulb is pressed it will not reinflate
Remove disassemble and clean carb. using carb. cleaner and compressed air. Make sure you clean all orifices. If the diaphragm and gaskets are hard or damaged replace. You should find all the parts you need on the Internet if you can find type and model of the carb.
Apr 05, 2009 | Oregon Scientific Garden
Can't start my Poulan Woodshark Model 1950
Replace the fuel filter. Sounds like you have the primer lines hooked up backwards.
Part list have mod & ser #
http://www.ordertree.com/cms/Illustrated-Parts-List/64.html
Mar 25, 2009 | Garden
New model ut08580 backpack will not start
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Nov 11, 2008 | Homelite Consumer Products Backpack...
Craftsman 25cc Gas Line Trimmer Logo
1,762 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
