Question about Whirlpool ARC4030 Stainless Steel Top Freezer Refrigerator
Whirlpool door alarm
There are many people I notice who have this problem of their door alarm going off when the door is shut. It has been happening to my Whirpool ( for months but my fridge seems to be working fine. Looking at web images, I think it is a top freezer ARC 4030, but there is nowhere I can see any model # on the front or back of the unit. My question - does Whirlpool have any remedy to what is clearly a common defect? Or do we need to cut our losses & buy a different brand? Scott
    Novelist:
  • 145 Answers
Is just a little switch on inside of the door hinge covers if you short it out the alarms will never go off again.
Posted on Jun 28, 2009
  • Charlie Harris Jan 14, 2012
    How Do you short it out?
  • lwkooy
    lwkooy Jan 15, 2012
    could you please indicate where and how exactly? having problems with sleeping now every night and mechanic could not solve it either! tnx
Whirlpool freezer display flashing 1
Hi Rachel
For your door to close properly take off the gasket from your fridge and wash it with hot water. It will be softer and stick to the fridge much easier.
Feb 15, 2014 | Whirlpool 10 cu. ft. Chest Freezer...
Car door alarm activation
Need more info. Is it an aftermarket alarm? What kind of car? If it is an aftermarket alarm, it is possible that the wiring to the alarm module could be configured wrong, making it think that someone is hot-wiring the vehicle. Or, it could be that the wires to the alarm are chaffed, and the power from the alarm is shorting to the door lock controls. If neither of those are an issue, then it could also be the settings on the alarm module itself (many aftermarket alarms are pre-programmed to lock the doors, as soon as the transmission gear selector is placed in "Drive", and if the wires are chaffed, shorted, or improperly connected, it could be that it's seeing the door pin switch, as that trans selector input). In any case, this sounds like an electrical problem for a skilled automotive electrical technician, because many of the vehicles panels may have to be removed, so that the wiring can be exposed & inspected. Without more details, I can only post a "professional opinion", rather than a "solution". I hope this helps.
Nov 26, 2013 | 1997 Volkswagen Jetta
My alarm cycles on and off on when vehicle is shut off.
  • Often times when this happens this is a problem with your door switch. The doors being locked or not does not necessarily mean that the alarm is not armed. When the door switch begins to fail the alarm senses the door being opened even if it is closed because the switch is sending a signal that the door is open. You could just need to reprogram the FOB as well.
  • Unfortunately the FOB must be programmed at the dealer or a technician with a proper interface. You might be able to ask the dealer to test your FOB first.
  • The switch you will notice on the inside of the drivers door and is activated by opening and closing of the door. You can pop that switch out and look at the wiring and give it a little cleaning and see if that helps. If it does it will be temporary and the switch will need replaced.
  • Hope this helps.
Nov 16, 2011 | 2006 Chrysler 300
Re; 1996 V/W Jetta Alarm system won't shut off . Happened to hit the door lock button when the car was running and it triggered the alarm. Tried everything with the key in the driver's door and it will...
Disconnecting the car battery will reset the alarm system. When you first connect the car battery, the alarm will sound briefly, then stop. You will have to retrain the alarm system to recognize your remotes. The procedure for that varies from one year model to the other. On my 1998 you do it by putting the key in the door lock and holding it full counterclockwise until you hear a brief beep from the alarm horn. Then press a button on your remote and the system will learn to recognize that remote.
Jan 22, 2011 | 1997 Volkswagen Jetta
I have a viper 5901 installed on my 2008 Impala SS and every now and then the alarm goes off saying the doors are open but they are closed. why would this happen
This is happening because they used the cars domelight to set the alarm off when the doors are opened. When the cars computer goes into battery save mode and shuts down certain parts of the car, the domelight is one of them and a slight ground or 12 volt positive is backfed to the alarm and sets it off. This usually happens after 30 minutes. they should take the alarms door trigger and actually go to the cars door latch wires. The colors are:
gray/black - driver door tan/white - pass door lt. blue/black - back driver door lt. green/black - passenger back door
Aug 31, 2010 | 5901 Security Remote Start System
My alarm wont go off not even when i start the car
Try opening and shutting the hood,and the doors,and the trunk,and activate the alarm,and then disarm the alarm,if this does not work,then the alarm system will have to be replaced,the receiver.
Jun 07, 2010 | 2000 Mercury Cougar
How do i make the alarm go turn off. it is beeping and car wont start but this has never happened before
all doors hood and trunk must be closed and locked unlock drivers door with key alarm should stop (this will apply to factory alarms ). if you have an after market alarm you should use the control box. If battery is low or bad you must replace it before you can shut off the alarm
Sep 03, 2009 | 1997 Volkswagen Jetta
My interior lights and door panel lights won't go out
One of the Dome/Interior Light Buttons is NOT WORKING at door
Jan 23, 2009 | 2000 Volkswagen Beetle
Whirlpool Frost Free 460 door open alarm
http://www.repairclinic.com check how to repace it with the schematic diagrams you'll see how
Dec 30, 2007 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ARC4030 Stainless Steel Top Freezer Refrigerator Logo
1,657 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
