Question about Kodak EasyShare DX6490 Digital Camera
Camera not turning on.
I viewed pics at night on camera after my daughter took it out at night. I noticed dampness under the battery cover.
Battery is fully charged. I removed the back cover to find slight dampness. I baked it in the oven at 40 deg for 2 hours to dry it out (Works well for a cell phone). Still not luck.
    Novelist:
  • 153 Answers
If it was working until you opened it.
It may be worth opening it again to check you didn't dislodge the ribbon cable for the mode switch.
if you could only half open it or had problems getting the diopter control back in (eyepiece focus) there is a screw under the stick on fascia that surrounds the eyepiece lens (not the rubber bit) use a scaple to peel it back...
best of luck
Posted on Jun 01, 2008
When I turn on my Canon PC 1130 to take a picture, the lcd screen and view finder just show a black screen. Camera is working fine in the play mode. Please help.
Set the camera in TV mode, (delayed shutter mode) set the shutter at 15 sec, click to take a picture and during that 15 secs (like, after 7 seconds) open the battery compartment which cuts contact with the battery circuit. Close the battery cover. At this point the camera works fine ... but only temporarily.... Here is the key to the permanent fix. While the camera is working via the temporary fix, take many, many pictures. Hundreds! I probably snapped 400-600 pics. The idea is to wear down the little patches of hardened oil on the shutter blades. For the next three days I took hundreds of pics each day. Basically, I just aimed the camera at the wall or whatever and snapped off several hundred pics.
Jan 05, 2011 | Canon Cameras
Fuji S7000 shuts itself down...without a reason
remove the xdcard and use compact flash. also put camera in set mode and run the battery drain function. it seems to reset the battery voltage meter. clean batery contacts with q-tip and rubbing alcohol. worked for me
Dec 27, 2009 | Fuji FinePix S7000 Digital Camera
I have a Canon camera, which worked fine. I had to recharge teh batteries often, that was all. Last night, i took it out. In view mode, the camera does not shut off. The moment i switch to camera mode, the...
I'm assuming you're talking about a point-and-shoot model, and not the 1000D as the category suggests. Camera mode has significantly higher power requirements than viewing mode. It is possible that your rechargeable battery has degraded to a point where it no longer can power camera mode, or it might just be discharged. Try with a freshly charged battery, or if you're lucky enough to run on AA batteries, get new ones. You might also try using the camera while plugged into the USB port of the PC, which might be able to supply power to the camera. I have noticed that when the batteries are near-empty, the camera "dies" rather abruptly.
Jun 29, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon 40d-used camera sunday-took cf card to store to make pics-
Try cleaning the contacts for the batteries with a pencil eraser. Make sure you hold the camera so the eraser debris falls OUT of the battery compartment as you clean. Also make sure the battery door latches properly, and that the batteries are correctly oriented.
Dec 12, 2008 | Canon EOS 40D Digital Camera
Cam not shutting off or recharging.
Sounds like the camera shorted out. Using a camera at night temperatures could cause condensation, especially moving from outdoors to indoors and vice versa. If it is under warranty, time to send it in. I would guess it needs a new system board.
Nov 12, 2008 | Cameras
Error Message
Have you tried resetting your camera? To reset your camera, open the battery cover and you should see a small hole inbetween the SD card slot and the battery release switch. Then use a small narrow object (i.e. mechanical pencil with its lead extended) and press into the hole. You should feel it "click" and then hold it for about 3 seconds. Try restarting your camera.
Note: Please backup all the data on your SD card before doing this.
Hope this helps
Aug 14, 2008 | HP Photosmart R727 Digital Camera
Err CF
TRy and reformat the CF card through the camera. Youll lose the pics for sure but you cant see them anyway. You can also check for bent pins in the CF slot. Sometimes if you shut down the camera in mid write to the card, itll mess up the cards FAT (file directory)
Feb 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
No take picture!
Hi John,
Try using the AC Adapter as your battery.
atdlee@netzero.com
Jan 06, 2008 | Canon EOS-5D Digital Camera
No picture on lcd screen
I have the same problem but sadly no solution.
As my camera is still under warranty I took it back to Jessops.  The camera is now with Olympus for repair.  The technician in Jessops hazarded a guess that the problem is a broken processor sitting behind the lens and as such the problem is "really bad".
Here's hoping you are still under warranty.
Oct 22, 2007 | Olympus Stylus Verve / ?-mini Digital...
Kodak EasyShare DX6490 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
