An error appear 0001002D at Epson 7880 and we want to reset counter for Cleaning Unit by adjustment wizard 2 program .
SOURCE: reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
SOURCE: service required error 0001002d
This happens when you let the "maintenance req. 0040" go for to long. The machine turns itself of to prevent damage.
Solution: Call epson and they will give you the reset code. Cannot find these codes online so if you do call please post instructions
SOURCE: Need to Reset Motor Counter
Here are 7 step to do:
The Reset is DONE.
Good Luck.
Peter Nguyen at Montreal
SOURCE: epson styllus pro 7800 service call error 0001002d.. help
http://www.largeformatrepairs.co.uk/technical/maintenance-error-code-0001002d.htm
Please rate the answer........
SOURCE: Epson RX420 needs resetting, lights flash and PC can't detect it.
In most cases, it's a waste ink pad full problem (the sponge that sucks wasted ink is full). But it probably isn't full yet (Epson claims it's full long before it really is!).
You'll have to download the service program for Epson printers (which gives you access to service functions of your printer):
http://www.eserviceinfo.com/downloadsm/22895/SEIKO%20EPSON_EPSON%20RX420-425-430.html
Run the exe file (it doesn't work in Windows Vista or 7 - you'll need old xp for that). Then Select Sequential Adjustment Mode. Select your printer model and then Waste ink pad replacement. Press Ok.
You might have to try a bit.
After you suceed, you need to turn off the printer and turn it on again. If all went well, you won't be seeing all the blinking lights on your printer ;)
Just like any other mechanical equipment, a printer requires attention to keep it running smoothly. So, just like when the check engine light illuminates on your cars dashboard so does your printer, but instead of a spanner the error 0001002D will appear on your control panel LCD which is informing you that a maintenance procedure is due to be performed. This will normally involve replacing the parts which keep the print head clean, hence the error "cleaning unit END OF LIFE" and the waste pads. This procedure can be undertaken here at Large Format Repairs for the Epson Stylus Pro 3800 right upto the beast that is the Stylus Pro 11880.
Worn flushing box
Worn cap assembly
Worn head wiper
Worn carriage waste pad
this error 0001002D means Cleaning Unit end of life
The only fix for this problem is you have to call Epson and state them
that you are facing this problem. They will provide you the codes to
unlock this error. Its a universal solution that only Epson can provide
you these unlock codes and you cant find in any websites.So contact them
and get your problem fixed soon.
techbelkin
