Question about Technics SA-EX320 Receiver
We have had a Technics stereo for 16 years and have had NO problems until the last couple weeks. If the volume gets turned up, the signal will come on that tells us that there is an OVERLOAD. We have tried new speaker wires but that did not resolve the problem. Is the anything else we can check or try..summer is here and we look forward to a couple BBQ's, and because we are always about 50 feet from the patio and DOWN on the grass, it would much more pleasant to actually be able to hear the music. (It cuts-out around 4-6 -out of 20) We look forward to your reply as soon as possible! Thanks! Andrea :) ****P.S. In order to be able to send this...I had to choose a product option from the site list....Our receiver is a SA GX350!
    President:
  • Technics Master
  • 1,114 Answers
Disconnect the speaker wires at the receiver, turn up the volume, if it goes into protection, it's an internal problem and needs service. If it does not go into protection, re connect one speaker at a time and test. If it shuts down check the speaker itself, if they are as old as the receiver, chances are good that the surrounds on the speakers themselves have disintegrated. Older speakers used foam surrounds, newer ones use rubber or plastic composite material that will not disintegrate. What will happen is dust and moisture will get into the voice coil and cause a short, even though the speaker still plays. Hope this helps. If you need more help or just advice, post a comment, and I'll help if I can
Posted on Jul 01, 2009
  • abelrojo Jun 10, 2011
    i have a reciver SA-GX670 should i do the same thing for mine thats the same thing i turned up to 7 or 8 and say power off overload please let me know i ready change the speakers wire.
    Habit-Forming:
    New Friend:
  • 106 Answers
If the amp shows overload...that means there is a short circuit in the out put . check the below .
1. Change the speaker wire(short circuit).
2. Change speaker .
3. internal short ckt ( IC ) take to a service center.
Posted on Apr 21, 2016
2 Suggested Answers
SOURCE: My Technics sa GX350 tuner
Hi mate, had the same problem with my amp.. Take the top off and there is a fan at the back, there are 2 piece's of copper flat wire that touch together and these do not touch anymore so when its turned up or the bass gets stronger it cuts off as the fan should kick in at this point. If you can get these to touch again (bend them) then the problem will be gone!! I have had to do this a few times now though so this is not a long term fix.. I may try soldering!
Posted on Jan 10, 2011
Older technics SA-GX100 sometimes left or right speaker will not work until volumes is cranked up
buy some turner cleaner or electrical contact cleaner(radio shack) with the power off take the volume knob off spray into the area where the knob goes(the little metal post) turn the post back and forth with your fingers or needel nose plyers several times (over time dust and dirt build up makes a bad connection) you may have to do this a couple of times dont worry this stuff drys realy fast this should do the trick
Sep 06, 2014 | Panasonic Technics Sa Gx100 Amplifier...
It became only while the car was idling, now it's anytime, anywhere, and never on a consistent basis. The engine simply dies, turns itself off. When it happens, the check gauges light comes on. Nothing...
is your stereo the OEM (factory original) model? Does the car have a factory-installed anti-theft system? If the answer to both is Yes, you may have a logic conflict since many anti-theft systems go to and through the car's stereo. If you still have the original owner's manual, check the section on anti-theft or security systems. It may list a reset procedure that returns the system to factory defaults. If you have an aftermarket anti-theft system, you may have to disable it until troubleshooting and repair processes have been accomplished. Incidentally, by the car sitting without a battery for five years, all E-prom programming may have been degraded or lost. As for the volume increasing, some GM/Delco radios have a volume compensation feature that increases volume levels as speed increases.
Oct 10, 2013 | 1997 Pontiac Firebird
I inherited a technics SL-6 turntable system and a very old sears audio by fisher am/fm stereo receiver along with 1 pair of kenwood ks-401ht front speakers and cant get any sound. I have the technics...
Your connections seem to be right.
Let's distill this down to its simplest configuration... does the onboard FM produce sound? If not, nothing will.
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Apr 17, 2011 | Audio Players & Recorders
Technics SA-DV290 Amp. Sound cuts out as volume is increased
hello it sound like the output ic may be in trouble you may have just dry joint on the ic which just resolder it . or there could be a capacitor leaking or they may have swelled up in which you will have to replace. it's best to do some visual checks first i'e look for any burnt parts any capacitor with bulging tops
regards
shaun
Apr 04, 2010 | Technics SC-DV290 System
My Tchnics Sa-Da10 shuts down on what appears to
Ahh technics. Technics always had overheating problems, trust me. Every since they started, their amps would get so hot they would hurt to touch. The reason the fan is not coming on seams to be something inside the circuit board. I'm sure that technics could fix this. If the fan works out of the receiver, then it must not be the fan. ;P
I would maybe get a computer fan, and just put it on top of the receiver and turn it on, or send it in for fixing. Also, do you have to crank the volume to get the speakers to play at your volume, and does the impeadence match the receiver. Because you may be pushing the receiver too hard.
Oct 11, 2009 | Technics SA-DA10 Receiver
Center speaker is dead or what it can be on my Technics SA-dx930.
More than like, the center channel is turned off on your receiver. Please see page 16 of the manual, which is located here:
http://service.us.panasonic.com/OPERMANPDF/SADX930.PDF
The manual says to do this:
Turn on the receiver.
Press Speaker A and B button at the same time.
The word Setting appears then changes to Front
Press A to select Center
Press B to choose Large, Small or None for your center speaker.
After choosing Large or Small, press A again till you see Complete on the screen.
If this helps, please rate my response.
Mar 26, 2009 | Technics SA-DX930 Receiver
Alesis Sr 16 stopped working altogether
I have never experienced this problem, but I know that you can reset the SR-16 to all default settings by doing something like holding down play when powering up. Try that & I'll look into the matter and get back to you with a definite answer. Peace and good luck until then.
Sep 21, 2008 | Alesis Sr 16 Stereo Drum Machine
Over Load light turns on and then we have no sound
please disconnect each speaker one by one and test it until you find the bad one-start with cable change and then the speaker itself.
Jul 04, 2008 | Technics Audio Players & Recorders
Technics SA-AX730 Receiver PLAYS FINE AT A VERY LOW VOLUME.
Your speakers are way tp powerful you should only use speakers just over what the amp is rated at the most and check your impedance is not lower then 6 ohms and turn the bass to half way i am using 60 watt bookcase psb speakers and they work just fine and they pound no problem
Aug 24, 2007 | Technics SA-AX730 Receiver
634 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
