Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
Bissell carpet cleaner won't spray water or cleaner
My Bissell proheat clearview carpet cleaner stopped spraying water and cleaner. I replaced the pump but it still does not work. It is only about a couple of years old
  • 13 more comments
  • tomex Nov 12, 2007
    I have exactly the same problem.
  • Kurt Baker Feb 09, 2008
    I have the Bissell Pro Heat 2x Steam Cleaner and the water is not spraying but the solution is. Is there a clog somewhere? How do I check it and/or fix it?
  • Anonymous Apr 11, 2008
    exact same problem will not dispense water, still extracts but will not dispense.
  • Anonymous Apr 08, 2009
    WILL NOT SPRAY WATER
  • wendydavis20
    wendydavis20 Mar 07, 2013
    Thanks for sharing! This was very helpful! I was wondering if you had any recommendations for carpet cleaning in Calgary?
  • Anonymous Aug 22, 2013
    If worse comes to worse, you could try carpet cleaners in Fayetteville NC. I haven't tried them yet, but my friend said they were very helpful.
  • Anonymous Oct 02, 2013
    I usually just call someone to do my carpet cleaning in Eagle River AK. It's much easier that way and gets a lot cleaner, too.
  • Janet DeBruyn
    Janet DeBruyn Oct 24, 2013
    Mine will spray the water but not the soap.
  • Janet DeBruyn
    debruynja mine spays the water but not the soap.
  • Anonymous Mar 12, 2014
    Bissell steam cleaner does not spray
    trying to clean carpets but it won't Put down water
  • Anonymous Mar 21, 2014
    i have purchased an older bissell powerlifter canister tan color and have no manual can u help me to operate
    1660-3 manual on this model canister carpet cleaner
  • Anonymous Mar 27, 2014
    tube in hand held unit stopped up.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Posted on Feb 13, 2008
  • bswift Jan 08, 2012
    Mine is an upright pro heat 2x with pet extra stuff. Where is the heater located on that one?
  • albradley69 Jul 05, 2013
    Hey, Geterdun, THANK YOU so much for posting this helpful tip. I opened it up (with your great instructions) and sure enough, the inside of my heater was completedly clogged with dried goo. Easy enough to clean it out, let it dry, put it back together (used my smartphone to take a snapshot of the tubes and wires before disconnecting), and good as new!
Mine wouldn't spray water...the hand tool did... I took it outside and sprayed the whole bottom (not the motor) with a water hoes...Workes fine again. I guess it was clogged up somewhere. I have to admit that I didn't clean it after each use and I have dogs. Good Luck!
Posted on May 02, 2009
  • hummingbi954 Jan 20, 2011
    s3xy76 Not sure I understand. You took it outside and sprayed the whole bottom with a hose -- the whole bottom of the SpotBot? Huh.
    President:
  • 1,673 Answers
You didn't give the model number, when you put the lid back on, the piston needs to be on the bottom on the mix valve knob, and in the water only position when you push it down. If it turns ok, then it should be ok. The heater could be clogged, water won't spray if it is. Is the seal on the bottom of the tank and not in the hole in the base where the tank sits.
Cleaned heater according to Geterdun's instructions (great detailed instructions) AND found belt in side compartment had come off and was stuck in the little red plastic piece. Had to go underneath and unscrew little red piece to loosen belt. Rebelted it and it works GREAT!.
Thanks Geterdun!!
Posted on Jan 25, 2009
  • tdonaghy Jun 26, 2011
    Found belt off..put it back on and now working fine.. Thanks!
    New Friend:
My bissell powersteamer turbo wont spray water on the floor
Posted on Jul 15, 2013
  • 1 more comment
  • Anonymous Dec 10, 2013
    This is why I always call someone to do my rug cleaning in Toronto. Much easier that way.
  • All Star Chem Dry
    All Star Chem Dry Apr 21, 2017
    You can also use our service please visit our site for more info about that - www.naturalcarpetcare.ca/carpet-cleaning/ Thanks!
  • Anonymous Jun 03, 2018
    Maintaining a cutting-edge cleaning equipment is a profession that requires knowledge and experience. If you need a deep cleaning, hiring a professional is always the wisest choice. Besides the high-quality cleaning, you won't have to deal with equipment-related technical problems when you work with a professional cleaning company. When it comes to carpet cleaning in Toronto, Golden Line Green Care is my favourite. Here is how they do it:https://www.goldenlinegreencare.ca/blog/...
    New Friend:
  • 9 Answers
I recently fix one and have a detail tutorial here: http://www.diyvacuumrepair.com/carpet-cleaners/how-to-fix-a-bissell-proheat-that-wont-spray/
Posted on Jan 25, 2016
  • Anonymous Jun 20, 2016
    Is this site dead? Doesn't seem to return anything no matter what browser I use.
    New Friend:
    Problem Solver:
  • 8 Answers
The repair facility will always tell you to buy a new machine. But here are the things you should check first:
  1. Make sure there is water in the main tank and cleaner (or water) in the detergent tank.
  2. Make sure that if you press on both tanks that water (or cleaner) comes flowing out fast. If it doesn't, you'll find you can clean these and there is in fact a filter on the big tank on the other side that you never see since you never take it off. Mine was clogged. So unscrew both of these black tank caps and clean all sides. Put them back on.
  3. Make sure that the two red rubber gaskets are attached to the removable tanks (and seat properly on them) and NOT attached to the machine. So when filled with water, both tanks should dispense lots of water freely when depressed. And the red gaskets are on the removable parts.
  4. Make sure that you seat both tanks firmly in the machine. The detergent tank should "click" when seated (press back and down to seat it and you'll feel it click).
  5. If you are using the hand attachment, make sure the machine is upright, the seals are in place, and the power cord is routed away from the machine and isn't preventing any seals from making contact.
  6. When you turn on the machine, do NOT spray it. WAIT. Run it for 60 seconds in order to prime the pumps.
  7. If that fails, you can try running a mixture of water and vinegar to try to clean the lines.
Posted on Jul 02, 2011
  • 1 more comment
  • Steve Kirsch
    Steve Kirsch Jul 02, 2011
    Also:
    Also:
    Put some hot water in the tank and run it on clean only through the hose. Remove the nozzle at the end. When you press the button on the hose, the water should squirt out at least 12 inches and maintain that until the water in the main tank is nearly out.
    Check that the red part inside the main tank is freely moving. Not sure what this is, but it might be some sort of "full" bypass.
  • catwoman31ab
    catwoman31ab Aug 05, 2012
    i inherited a bissell quick steamer carpet cleaner light weight i think it is an older model #1960 -w jj 05131 it won't spray water i cleaned the bottom thing where it sprays and took it apart and it still won't spray help
  • Steve Kirsch
    Steve Kirsch Oct 16, 2014
    My Bissell wouldn't spray on the bottom or the handle.
    The cause was remarkably simply: all three nozzles were plugged. Solution: take out the nozzles and stick a pin in them working from the inside so when you blow, air comes out.
    So for the handle, you detach it and then you can stick a pin in from the inside.
    For the jets to the floor, you release the jets from the housing, slide the clamps down, then pull off the jets. Clean with a pin.
    There is an EXCELLENT tutorial on how to do this at:
    http://www.bissell.com/FAQDetail.aspx?id...
    I thought I had to throw the cleaner away, but this procedure makes it spray like new.
    One thing, when you test with the water container like in that link, the water will flow out from one floor hose only. You must block that hose to get it to flow out the other floor hose.
    Also, you can keep the vacuum unit upright while troubleshooting using the link above. Set it to "rinse". You do NOT have to tilt the handle. You can get water out of both the hose and the floor sprayers by pressing the appropriate button.
SOURCE:
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
My Bissell Proheat carpet cleaner/hose for cleaning will not spray anything
My ProSeries Carpet Cleaner won't spray. What ... - Bissell
www.bissell.com > Support > Helpful Resources > FAQs
BissellLet's start by figuring out where your carpet cleaner can spray. If you have no spray at all, start below. If you have no spray at the floor but can spray from the hose, scroll down for the ... Turn the unit on after cleaning and see if water sprays to the floor now. IV. .... My ProHeat® Self-Propelled's Powerdrive isn't engaging.
Bissell Carpet Cleaner Won't Spray. Easy Repair - YouTube
? 1:48
https://www.youtube.com/watch?v=nccdrjpGp34
Dec 20, 2013 - Uploaded by Cecil Argue
You may have a bad pump, clogged hoses or a clogged heater. ... Just want to tell you that this was the perfect ...
Nov 30, 2015 | Bissell Vacuums
Bissel pro2 carpet cleaner stopped sraying how to fix
Hey Diane! Sorry you're having difficulty with the spray on your ProHeat 2X. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Jan 15, 2013 | Bissell 2X Proheat 9200 rug cleaner
WON,T SPRAY CLEANER/WATER CARPET IS DRY.THE TOOL ATTACHMENT WORKS OKAY.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 08, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
My bissell stops spraying water, carpet not wet
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
rtetrhgd
May 30, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
How to replace belt on a bissell proheat clearview plus carpet cleaner
heatman101
Jan 27, 2010 | Bissell 7901-R Clearview Proheat Plus...
Won"t dispense water
heatman101
ytoi
Mar 03, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell ClearView powersteamer carpet cleaner does not seem to be dispensing water in the pre-treat mode
Pretreating (optional)
Note: Pretreating is recommended to improve
cleaning effectiveness for heavily soiled carpet in
high traffic areas such as entryways and hallways.
A.
Spray the BISSELL Tough Stain Pre-treat formula
onto heavy traffic areas, soiled areas, or stains.
B. Allow to penetrate for at least 3 minutes.
Maybe isn't su[pposed to dispense water, just the Pre-Treat solution. Then after a few minutes, shampoo normally.
Mar 29, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
43,705 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
