Question about Karcher K 5.85 M Electric Pressure Washer
My karcher washer stops for no reason at all then wait a few minutes then starts again
4 Suggested Answers
  • 92 Answers
SOURCE: karcher washer went dead
Dear jimbocom,
The problem is that the spill valve got stuck. When the machine is working and the gun is closed, a valve( spill valve) moves with the accumilated pressure and switches the machine off. So what happened is that when the spill valve did its job, it found no water...and remained stuck. This leaving the machine in an off position. Service and lubrication to the spill valve must be done or completely replacing with a new spill valve. In my opinion you have no serious damage, but this job must be carried out by an expirienced technician.
Regards,
MG.
Posted on Nov 05, 2008
jmgldsmth
  • 2005 Answers
SOURCE: new Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Posted on Aug 31, 2009
  • 429 Answers
SOURCE: I have a Karcher electric power washer. The
do you mean the gfci that is normally at the end of the cord or the switch on the unit itself. if its the ground fault circuit interrupter its detecting a short to ground and protecting you from recieving a shock.must inspect inside unit for possible moisture around motor or switch i don't think its overloading
Posted on Aug 08, 2013
Why does my karcher powerwasher starts and dies after 2 minutes
dirty carb , clean carb, install a fuel cut off valve ( or start using it if you already have one) when you are done washing, turn off the fuel valve and continue spraying water until the engine stops. That will empty the carburetor bowl and the carb will stay clean until you want to use it again.
Sep 07, 2014 | Karcher 2500 PSI Pressure Washer
Bikegit
Replace the switch! It shut down when battery get depleted. and then when you start it again the cycle is shorter because the batery regenerate but not as previous cycle.
Jul 16, 2014 | Karcher WV50 Window Vacuum
What is this problem - Karcher 3.86 electric pressure washer: humming noise, plug gets very hot, then unit shuts down?
Your pressure washer is either not fitted with a run/stop device in which case like mine you have to switch off within a few seconds of closing the trigger. Check your model features?
The humming noise is the motor stalled out against the pump because there is nowhere for the water to go. The shutoff is caused by the safety overload switching off after overheat.
Or, it has a pressure operated run/stop which is not working. Because water and electricity don't mix, I would suggest getting more specific help. You can download Karcher manuals /spares lists online from Karcher specialists but remember electricity is the silent killer.
May 20, 2014 | Karcher Garden
The trigger on the wand of my Karcher model K 368 M will not re-engage for several minutes after the trigger is released. If I repeatedly squeeze the trigger for a few minutes, eventually the switch will...
it sounds like a flow switch that is installed in the inlet of pump can get stuck at times if you have a soap nozzle select it usually more flow moves the flow switch try and clean the flow switch if possible.
Aug 10, 2013 | Karcher K3.68MR Electric Pressure Washer
I have a K2400 HH pressure washer. When I started using the machine this year, the pressure would last for a moment or two than quit. When I would shut off the pressure and wait a few minutes and start...
sounds like a weak or worn out unloader valve spring.
MODEL DESCRIPTION PRICE SN-060-216 Pressure SpringKarcher/53323910 $5.90cart.gif
You can find parts online through Karcher or Ebay if you wish.
I hope this helps!
Feb 23, 2011 | Karcher Garden
I have a coleman powermate 2400. It started fine
Did you try a new spark plug. Old one may have fouled.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 25, 2009 | Karcher 2500 PSI Pressure Washer
John- power stopped -rest the GFCI STILL POWER WON'T COME ON-KARCHER K2.26M NEW -USED ABOUT 15 MINUTES WHEN THIS HAPPENED
these small power washers are tricky. Keep working with it. It may just be waiting for u to squeeze the trigger to activate. Make sure you have the water connected and turned on.
Apr 27, 2009 | Karcher K2.26 Electric Power Washer
Code F 40
Hello homefolks
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, Your washer starts to wash and code come up it stop then starts runs for a
few minutes then code comes up again and does this over and over
can't finish a load. Model # 2709
Sounds like we need to try to reset the system!
Huuum At your service!
Lets try this,
Like with an error code.
This can reset the system if it is electronic!
Unplug the washer and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Let me know how it works! Waiting for your reply!
Please remember to leave a rating when you are done!
thank You huuum
Sep 25, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Karcher K 5.85 M Electric Pressure Washer Logo
207 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
