Question about XFX GeForce 6200 Graphic Card
No signal on first boot
I have a Dell Dimension 8250 desktop with an Nvidia GeForce 6200 card and a Nokia Multigraph 445Xpro monitor. It has XP Professional with up-to-date drivers. The last few weeks when I turn on my PC the only thing that is displayed is the Nokia self-test screen. This has the following information: Red [a red bar displays]
Green [a green bar displays]
Blue [a blue bar displays]
Signal: No Signal
Input D-Sub Selected
Cable: Connected
This message stays on the display no matter how long I wait. What I need to do is to turn the CPU off then turn it back on. Then the monitor gets the signal from the CPU and I can see that the CPU is going through its memory check and then I get the logon display.
I have tried using an Hitachi monitor and different monitor cable and it doesn't get a signal on first boot either.
  • kinematic Nov 12, 2007
    Thexder1, thanks for all of the ideas. Each possible cause that you have suggested seems reasonable given the information that I provided.
    I have not yet decided how I will proceed at this point. With so many possible causes to consider I may wait until I am unable to boot up at all and then try to identify what has caused the failure.
  • scythefalcon Nov 30, 2007
    I have had the exact same problem. Although i have worked out that it must be something to do with my graphics card and/or the drivers. When i have the drivers (which came with the graphics card itself on cd) installed and i try to run windows xp normally, the screen comes up woth a error 'no signal'. Now if i run the pc in safe mode, i can actually get on the pc without the error. Obviously in safe mode, graphics cardsdo not work and therefore is the reason i can get on.
    I am wondering if my graphics card is broken or something is wrong with the drivers. I have been using the graphics card for almost 2 years without problems until recently. =/
Sometimes it is enough to unplug your power cord, wait 2 minutes and plug it back in. ATX power supplies always provide power to MBO, even when computer is off, so it might help to "fully reset" your MBO.
Posted on Jun 23, 2008
  • 99 Answers
This would usually indicate that there is a problem that is causing your computer to not boot correctly all of the time. What you have described could be many different problems and without more information I cannot say which one it is.
1. Hard drive. I have ran into Hard Drives that for some reason do not start up correctly right away when you put power to them. This can cause the initial startup to hang possibly indefinitely.
2. Video Card. Something probably firmware is causing your video card to not start up properly when power is first applied.
3. PSU. The power supply could cause similar problems if it cannot supply enough power because the highest power draw is when you first turn on the computer. When you push the reset button the power is already being supplied to most of the components and the ones that did not have enough power to start properly before can do so now.
4. CPU. If the CPU has some minor problems it can cause similar problems. In any case to fix it you can try clocking down the CPU but you are better off replacing it.
5. RAM. I have had similar problems with RAM. Clocking down the RAM fixed the issue.
6. Settings in BIOS. I would check to make sure the setting for init display on boot is set for PCI-e.
Posted on Nov 12, 2007
Have a dell dimension e520. Trying so install geforce 6200 pci graphics adapter. Tried to do what has been suggested online. Disable previous onboard adapter in device manager. Now wont boot to allow me to...
You don't disable it in Device Manager: reenable it immediately. The correct steps to replace the video card:
1 - you uninstall its driver and reboot at least twice.
2 - You install the new card, plug the Monitor in it and reboot at least once.
3 - you enter in the BIOS and disable it in there, and only in there, and you reboot at least twice with a check in the BIOS that it has remained disabled in between.
3 - you install the new driver.
Jan 04, 2011 | Nvidia GeForce 6200 AGP Graphic Card
Geforce 6200 / dell dimension 4600 resolution problem
if this is a relacement for an old card 1st make sure the old drivers are ubisnatlled and the goto and install the latest wqhl drivers and that should remidy it you may also need to reset you monitor settings
Feb 02, 2010 | XFX GeForce 6200 Graphic Card
Will an Nvidia GeForce 6200 graphics card support dual monitors?
I would say yes one on your old computer montior connect and one on the card unless that card has two tv outs
Jan 28, 2010 | Evga nVIDIA GeFORCE 6200 TurboCache 256MB...
What video card
i recommend a nvidia 9500gt 1gb vga card. It's phenomenal and purely insane graphics^_^
Jun 15, 2009 | Dell Dimension 2400 PC Desktop
EVGA e-GeForce 6200
Try downloading and installing this one
May 27, 2009 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
No sound no 3d grafphics
Ok first, I am sorry to tell you the Dimension 8250 is not VISTA compatible. Especially with that video card. Vista is a power hog and has high demands of your PC. You should really revert back to XP if you want things running normal.
May 11, 2009 | Computers & Internet
GeForce 6200 PCI when drivers are loaded, screen goes blank
the problem is with display resolution setting which ur monitor doesnt support
press f8 on startup and choose enable vga mode
then widows will boot up in 640x480 mode
then change the resolution to 800x600 or whatever u want
Apr 11, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
I think is a power supply problem,,
Mar 10, 2008 | Nokia 445 Pro 21" CRT Monitor
Monitor is blank when plugged into Nvidia Geforce 8600GT
is video card pluged in tell bios pci express video snaped down good
Jan 19, 2008 | Dell Dimension E520 PC Desktop
XFX GeForce 6200 Graphic Card Logo
888 people viewed this question
Top XFX Computers & Internet Experts
Alun Cox
KG John Justin
KG John Justin
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
