Question about Pioneer DEH-P6600 CD Player
Pioneer DEH-P6600 clock reset
I have downloaded the manual from the Pioneer website, but pressing function key does not get me to the clock or clock reset options. I purchased the used car with this radio so I don't have the remote for this. Is there some way to reset this unit? Thanks!
robotek
  • 1512 Answers
SOURCE: pioneer cd radio deh-11 clock set
For most Pioneer single CD players, you can set the clock using the following steps:
  1. Press and hold the SOURCE button until the unit shuts off.
  2. Press and hold SOURCE again until the clock appears. With some models you will press and hold the FUNCTION or AUDIO button instead of the SOURCE button.
  3. Press the left or right arrow to select the segment of time you wish to adjust.
  4. Press the up or down arrows to increase or decrease the numbers in the blinking segment.
  5. Once the clock is set correctly, press the SOURCE button to exit.
Posted on Apr 11, 2008
  • 17 Answers
SOURCE: Pioneer DEH-P4800MP - Can not get into INITIAL mode to change settings
Actually, TRY powering OFF the unit, and release the volume button. Then, press and hold ONLY THE VOLUME BUTTON, until the initial settings appear. Pioneer really needs to get their act together on this issue. I have read all over that MANY people have had this issue, and the website is just a repeat of their lame printed manual.
Hope this helps. In review:
From OFF, press and hold ONLY THE VOLUME BUTTON. The initial settings shall appear at this point after about three seconds...
I just read these instructions, and while trying it, I found that my FUNCTION KEY had ABSOLUTELY NO FUNCTION IN THIS.
Posted on Oct 07, 2008
  • 124 Answers
SOURCE: SETTING CLOCK FOR PIONEER Deh p49001b' CD AM/FM/
shut it off then hold the function button
Posted on Dec 27, 2008
SOURCE: Pioneer DEH-P4900IB Changing Time and Date
when the radio is off hold the on the left bottom side for about 3 or 4 seconds and a menu should come on....keep hitting that button till the time comes on. use the up down left right to change it and once ur done just turn on the radio...good lucj
Posted on Dec 29, 2008
shawnsz
  • 64 Answers
SOURCE: pioneer DEH-P500UB set the clock
1 Press SRC and hold until the unit turns
off.
2 Press MULTI-CONTROL and hold until
CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select clock set.
1 Use MULTI-CONTROL to select
CLOCK SET.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
# You can also perform the same operations by
pushing MULTI-CONTROL up or down.
Posted on Feb 18, 2009
I need see the manual. for adjusted the clock
    • Turn the stereo off by pressing the "source" button on the bottom left corner of the stereo's face. Press the "function" button, the lower of the two buttons to the right of the stereo display, until the clock appears on the display. Press the arrow keys at the far right of the stereo's face to adjust the time. Use the left or right arrows to toggle between hours and minutes. Use the up and down arrow to increase or decrease the hour or minute numbers. Press the "function" button once you have set the display clock to the correct time.
Source- http://www.ehow.com/how_6881633_do-pioneer-deh_p6600-cd-player_.html
Jun 23, 2011 | Pioneer DEH-P6600 CD Player
I have a pioneer deh-p6600 head unit and when I put a disk in it says error 17 and error 12 what does that mean?
Error codes 12 and 17 are for a dirty or scratched disc. First thing to try would be a different disc. If this does not work most higher-end pioneer head units have a software reset button which is not well marked but usually located behind the face plate and you can use a pen or a pin to push this. It needs to be held down for a few seconds and this will reset all of the settings to factory standard. This does mean that you will lose all saved radio stations, clock settings, audio settings etc. If it still wont play any discs after that it will likely need more detailed attention from a technician. Cheers, Dan
Apr 27, 2011 | Pioneer DEH-P6600 CD Player
How do you set the clock on a pioneer deh-p6600?
Go to the link below then scroll down to product details. Then click on product manual. On page 32 it will tell you how to set the clock.
http://www.amazon.com/Pioneer-DEH-P6600-player-Full-DIN-dash/dp/B00025YP6S
Apr 24, 2011 | Pioneer Audio Players & Recorders
I just bought this truck with a pioneer DEH-P2500 radio and I don't know how to set the clock
According to the user's manual the following procedure is used to set the clock.
Manual is at this link http://www.retrevo.com/support/Pioneer-DEH-P2500-Car-Receivers-manual/id/23227dj392/t/2/
Here's the procedure indicated in the manual
1 Press SOURCE and hold until the unit turns off.
2. Press FUNCTION and hold until the clock appears in the display.
3. Press FUNCTION to select clock.
4. Press the Left Triangle or Right Triangle to select the segment of the clock display you wish to set.
5. Press the Up or Down Triangle button to change the digit up or down.
Jan 12, 2011 | Pioneer DEH-P2500 CD Player
I have a pioneer super tuner3d it has a mute wire where does it hook up to
This is directly from the installation manual from pioneer website for model DEH-P6600
(Yellow/black
If you use a cellular telephone, connect it via the
Audio Mute lead on the cellular telephone. If not,
keep the Audio Mute lead free of any connections.)
Basically, you don't hook it up unles you have a cellular telephone in your vehicle, not a personal cell phone.
Mar 09, 2010 | Pioneer DEH-P6600 CD Player
How to set clock in pioneer deh4000ub
here is the link for your manual:
http://www.pioneer.co.uk/uk/support/manuals/DEH-4000UB/index.html
Setting the clock
This function is available only for DEH-4000UB.
Use these instructions to set the clock.
CLOCK SET.
setting mode.
Hour—Minute
right.
Turning the off clock
display on or off
If the off clock display is turned on, the clock
appears on the display when the sources are
off.
OFF CLOCK.
2 Press MULTI-CONTROL to turn the off
clock display on.
# To turn the off clock display
Cheers!
Feb 07, 2010 | Pioneer DEH-P4000UB CD Player
Setting the clock on a pioneer deh-p6600 car radio
1. using the Source button put the unit in "stand-by" which is where only the clock is displayed but no radio, cd is playing just clock.
2. press and hold the "F" or function button will get you into the set--up mode where you toggle thru the choices using the ff/rw buttons until "CLK ADJ" appears press the display button and that will bring up the blinking clock which you adjust hours with the same FF/RW arrows when you get the correct time hit "F" button to return to menu.
Aug 03, 2009 | Car Audio & Video
Set clock how to deh p6600
press function to select clock
press function repeatedly until clock appears on display
press < or > arrows to select part of clock to adjust
press Up or Down arrows to change hour/minute
Here is the address link for a download for your exact owners manual:
http://www.pioneerelectronics.com/PUSA/Unassigned+Content/ci.OPERATION+MANUAL+DEH-P6600+20040225.Protected
May 10, 2009 | Pioneer DEH-P6600 CD Player
DEH-P6600 and DEH-P6700
if you still have that deh-p6600 faceplate i'll buy it from you
Sep 25, 2008 | Pioneer DEH-P6600 CD Player
Setting the clock
Hold source button till radio turns off and clock turns on. Hold Function till clock blinks. Press arrow keys to select direction of time. Then press Source again. All done
Sep 02, 2008 | Pioneer DEH-P430 CD Player
Pioneer DEH-P6600 CD Player Logo
60 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
