Question about Nikon Coolpix 990 Digital Camera
Coolpix 995 CF Card error
I have a similar problem. I tried 3 different memory cards. One works slightly better than the other one but basically I get first "this card cannot be used" and then sometimes it will still shoot a pix if I manually push the card in snugly and then after a few shots it will show either another card error or even a system error. Then the camera does not want to turn off for a few extra seconds even after I turn it off it will still say card or system error. I find this a progressive problem, it started over a year ago and increased ever since so I can almost not shoot any more pictures independent of the card I use. I think it maybe camera related but I hope its not going to be extremely expensive. I would like to keep it as its a nice camera. Any suggestions so I do not get ripped off at the camera repair dealer? One place said $150 - $200 !!!
I have formatted the card and am thinking its not the card. Its also not the battery as I used the power cable as an alternative power source and still the same error message. I tried to look inside the place where you put the card in the camera but I could not see any visible damage.
I would say my camera has only normal wear and tear no mistreatment.
My Nikon 995 began having trouble communicating with the CF card. At first it was intermittent then later there was nothing. After a couple of years of non-use, I decided to open it up to see if there was anything obvious. If I destroyed the camera in the process, no big loss. All the card slot pins were there and non were bent or coroded. Removing the drive, I could see under a microscope about half the pins on one side solder connections had broken. I assume from the repeated insertion and extraction of the card. (I use a card r/w drive in my pc instead of an interface cable to the camera). After I reflowed the pin solder connections and re-assembled the camera, all is good again.
You should know the disassembly/assembly of the camera is complex, and tedious. The connector pins are very small. I repaired the pin solder connections using a small high quality soldering iron while looking through a microscope. Witthout the scope, I couldn't even tell the connections were bad much less be able to repair them.
Posted on Aug 11, 2009
Testimonial: "Thanks:) I am thinking that it is a similar issue in my case and appreciate your solution description, it sounds very complicated to fix:("
I have same problem
Posted on Jul 24, 2009
4 Suggested Answers
SOURCE: hi i've a problem.. when
Same thing happened to me. I was told the cf 2GB is compatible while the cf 4GB is not. I found the cf 2GB at walmart.com.
Posted on Mar 08, 2011
informatica
  • 1114 Answers
SOURCE: CF Card for Coolpix 995
Hi - You can download the manual by clicking the link underlined in blue below:
Coolpix 995
See page 162:
So it seems that only 128 Mb is officially supported, however elarger cards may be OK but you would need to try, don't forget to format the new card in the camera. You may find a friendly high street shop that will let you try various card to see.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 03, 2008
karan4aaki
  • 68 Answers
SOURCE: "CF CARD CANNOT BE USED"
If you are not able to find your connecting cable. Well what you can do is you can take out the memory card and fix it into the card reader (you will get a card reader vey cheap anywhere.). and connect it to your comp. Now your card will work as a flash drive and format the card once.
May be you got a corrupted card. Hope this helps you out.. :))
Posted on Mar 10, 2009
Nikon Coolpix 995 gets a CF.Er card is not formated
bens pins inside on the camera , need to fix the card holder unit
easy to fix
Oct 09, 2017 | Nikon Coolpix 995 Digital Camera
Nikon 4300 CF Card Erro
The Nikon Coolpix 4300 only supports the FAT16 filesystem, so it can only support a 2GB partition. To support 4GB you need a FAT32 filesystem.
Put the card in a CF writer and attached to a PC or Mac. Partition 2x2GB partitions, then format them as FAT16. Now put it into the Coolpix 4300 and it should work.
Jul 29, 2009 | Nikon Coolpix 4300 Digital Camera
Trying out new 4G SanDisk cf memory drives in Nikon Coolpix 5700
Not sure if this helps, but it worked for me on a Coolpix 5000.
I tried a 4Gb card, and the camera formatted it and reported out-of-memory. The problem seams to be that that max 2Gb is supported
What I did was partitioned the card into 2 sections with 2Gb on each. I then formated them to FA16.
This worked - but you can only use half of the card (i.e. 2Gb)
For the tools I used a Linux laptop with CF reader. The tools are build in here (fdisk and mkdosfat). I don't know how to do it on windows.
May 18, 2009 | Nikon Coolpix 5700 Digital Camera
Mar 10, 2009 | Nikon Coolpix 990 Digital Camera
CF 4GB out of memory!
Yes..its most likely an issue with the card. Try a different card if you have one, and see if this resolves the issue.
Sep 28, 2008 | Nikon COOLPIX Cameras
Coolpix 995
See page 162:
Informatica
Sep 03, 2008 | Nikon Coolpix 995 Digital Camera
My Nikon Coolpix 2100 Lexar starter memory card has become unreadable
It sounds like your Dazzle is not compatible with the sandisk. Maybe the Sandisk CF UltraII card have a new update software in it.
Artgirlny
Jun 13, 2008 | Nikon Coolpix 2100 Digital Camera
Switch on - Switch off! Coolpix3100
Coolpix uses SD cards, not CF. Anyway, try using the camera without memory card, only with internal memory. If it works, then replace memory card.
Oct 01, 2007 | Nikon Coolpix 3200 Digital Camera
CF card problem
A slightly similar experience in that a Memory Stick Duo inexplicably set itself to write protect. No matter what I did, I couldn't format it. I was forced to buy another card. If possible, test it with another card or two. If it happens with more than two or three cards, then I would suspect the camera.
Sep 13, 2005 | Olympus Camedia E-20N Digital Camera
Nikon Coolpix 990 Digital Camera Logo
853 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
