Question about Garmin Nuvi 350 Car GPS Receiver
Download 2010 maps to Nuvi 350
How long should it take to download from a sd card to the Nuvi 350? Ours has said software loading for several hours.
    Brigadier General:
  • 4,090 Answers
About 20 mins try downloading to the desktop first. It could be a problem of communication between sd and the internet
Posted on Jul 01, 2009
Need to know how i update the maps card for it
The latest version of Garmin Express provides the ability to install a map update directly to an SD card.
The SD card installation option will only appear when updating a compatible device that does not have sufficient internal memory for the largest allowable map region. When using the SD card installation option, critical files are loaded to the SD card so it must remain in the device after the update to ensure full functionality. For the largest size SD card a device can use, refer to: What is the largest size Secure Digital (SD) card that an automotive device can accept?
The SD card support during the map update will only function with up-to-date software. It may be necessary to update the device's software with Garmin Express prior to updating the maps. These devices do not support the SD card option:
  • Nissan 700
  • nuvi 295
  • nuvi 300 series
  • nuvi 500 series
  • nuvi 600 series
  • nuvi 800 series
  • nuvi 805 series
  • nuvi 5000
  • StreetPilot series
  • zumo 450
  • zumo 550
  • zumo 665
For devices that do not support using the SD card with the map update application, any maps that do not fit in the internal memory can be installed to the SD card manually, using these instructions:
Try the link.it may help.Under support.
Garmin United States Home
Nov 09, 2015 | GPS
I have 2010 maps on a SD card for my Nuvi. Does
If you already have a map on your unit, you will have both maps. You may have to enable the map on the SD card. At the main menu, press the wrench symbol, then the map icon and then "map info". You should see all of your maps that are available to your unit. Make sure that the square boxes next to each map are checked. Thats how you turn on/off (selct) each map. If the SD card map isn't working, make sure it has a unlock code assigned to the map or it won't work on your unit. Also, the map file name on an SD card is different than the name on your unit. - Jim
Jul 21, 2010 | Garmin Nuvi 660 GPS Receiver
Can't unlock maps on the SD card
I am still waiting for the promised free solution suggestions
Jun 12, 2009 | Garmin nuvi 350 GPS Receiver
Nuvi 350 System Software Missing
If you have a nuvi 350 download the software to your computer and then load the software onto a formatted sd card. Insert the sd card and bootup the Nuvi 350. The sofware will then load onto the Nuvi 350. If you have a Nuvi 200 I would think it works the same but I have not tried it.
Hope this helps
May 12, 2009 | Garmin nuvi 200W GPS Receiver
How to switch between maps ?
Please click on the wrench symbol, then map icon and then "map info". You will see (2) maps listed with check marks next to them. Uncheck the map you do not want to use. Check mark the map you want to use. This is how you switch between maps.
- Jim
SHARCNET-USA
Jan 09, 2009 | Garmin nuvi 350 GPS Receiver
Nuvi 200w map download and sd card
Guys and or ladies... I know that you have to create a folder named "GARMIN" in the sd card so the maps can be recognize. Maybe this solves your problem. Let me know if it works.
BR from Spain,
Carla
May 11, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Map loading
Nope, the data will stay there, you just insert the SD card, use the wrench symbol/select map/select about/ tick the Australia map on/the usa map off/ and you're garmin just went Aussie.
Apr 23, 2008 | Garmin nuvi 350 GPS Receiver
Updateing maps
You have to purchase Map updates from Garmin. They are available in SD Card form, or CD form. Once you purchase them, you can download them to your unit. You can update the firmware for free from www.garmin.com. You must first download the WebUpdater software.
Mar 16, 2008 | Garmin nuvi 350 GPS Receiver
USA MAPS
You need to buy a preloaded SD card, purchase maps from Garmin and download them to a blank SD card.
Dec 10, 2007 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
382 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
