Question about IBM ThinkPad G40 2388 Notebook
My G40 won't switch to the external display. I've tried everything I can think of. I've updated the display driver and still nothing. The external display works with my R40, so I know it's my computer and not the monitor.
    Novelist:
  • 166 Answers
Go to your desktop and go to the display settings and check to see if there is twomonitors.if not and there is only one monitor you can't extend to another monitor but you should be able to connect your monitor and then hold the fn and another button called crt/lcd if not look for another button with monitors on it
Posted on Jun 28, 2009
Laptop goes
You must, when using an external monitor, either press the relative 'F' key to switch the external signal on or boot with the external monitor plugged in to get it to work.
Mar 24, 2014 | MSI A6200-059US Laptop
Ibm thinkpad audio drives G40 2384
You can get the driver from the computer manufacturer's website. If you want all drivers covered and updated, then you can install an automatic driver updater like RadarSync. You don't have to go to different websites to find the different drivers because the software will do all the work for you.
I hope this helps!
David
Feb 15, 2013 | IBM ThinkPad G40 2384 Notebook
Iomega floppy usb-powered external floppy drive on windows 8
Hi, Sounds like driver related problem to me. Try use this tool to update the drivers: Driver Update Software for XP Vista 7 8. Wish you best of luck.
Nov 30, 2012 | Iomega Floppy USB-Powered External Floppy...
IBM Thinkpad G40 not recognizing replacement hard drive
my recommendation is to format the drive and see if that helps. do it via usb.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 05, 2012 | IBM ThinkPad G40 2389 (2389HEU) PC...
Imac to jvc
Hi. A couple of things to try.
Switch everything off. Make sure your connections are sound then switch on the TV. Then switch on the mac. With luck the system should sort itself out. However, I have heard of others who have had nothing but grief trying to get similar arrangements to work.Normally ther Mac does it's own thinking, works out what is at the other end and puts up the display without any problems - other than the picture width being invariably wrong until you find the correct size.
There are no drivers to download - the issue is generally that the TV is not reporting back to the computer the correct resolution and scan rates.
You may have to dive deeper into the TV's menus to locate the means of altering the parameters.
Jan 07, 2012 | Apple iMac Desktop
After i plugged external speakers into my laptop, the laptops speakers stopped working. I've tried driver updates rollbacks re installs and pretty much everything else i can think of, being a mildly
The laptop speakers should only be cut out when the externals are plugged in. This is done by a little switch inside the jack. If it will not switch back and the external speakers still work fine then I would say that is definitely the problem. There is not much you can do if that is stuck. All the switch really looks like is a strip of metal that is like a spring. When you push the plug in it pushes this to the side and disconnects the internal speakers. The jack is mounted on the main board so you would have to locate the proper one and solder it on or replace the main board. Short of going that far I would see if inserting a jack a few times will get it to spring back. If there has been any spills on the laptop or it is gummed up inside you can use proper electronics connector cleaner. This is risky as it can damage the plastics but doesn't take much at all to work. I would look inside the plug and see if you can see debris or gunk. I'd also try knocking it. This is literally knocking around the switch like you are knocking on a door. You don't want to hit it really hard but just a few short sharp knocks will loosen things up with out causing damage. If you knock like the landlord looking for rent money then it might ;-]
Nov 22, 2011 | Sony Computers & Internet
I installed win XP over the old win XP operating system , when completed, everything worked except the (ACCESS IBM) and volume control BUTTONS.pressing them gets no responce at all
You need to install the drivers for those. Xp will try to use the existing driver if it can or use drivers that it comes with. Certain functions such as hot button or other hardware specific stuff will need the driver from the manufactuers web site.
This is the download and support page for the G40.
You should save that off in case you need something else. You may find that some things will not work or work as well if you don;t use the IBM/Lenovo driver versions. I think what you need are the hotbutton drivers and mayb keyboard customizer. Those are in the system utilities section. Download, save to desktop or other place and run them to install.
http://www-307.ibm.com/pc/support/site.wss/MIGR-50513.html
May 26, 2010 | IBM ThinkPad G40 2388 Notebook
Ibm thnikpad g40 powerup but screen remains blue with nothing on it.
You can check the display by connecting it to the external monitor through the vga port of the laptop, if there is a display, then take your laptop to the technician and check it there
Nov 01, 2008 | Lenovo Computers & Internet
IBM ThinkPad G40 2388 Notebook Logo
129 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
