Question about Valor Multimedia DV-170 DVD/CD/MP3 Player
" warning video disabled for your safety"
I have my ps2 plugged int o the aux n that is what comes up on the screen how do i enable video?
In my 2006 ford fusion 2.3L whenever I put my key in the ignition and turn it a weird solid ringing sound start and stops 5 seconds later hat could it be?
Not surprisingly, many others have experienced problems with the ignition switch on this car. Historically, it is not a sound, but that the key is stuck in the ignition. http://repairpal.com/key-will-not-come-out-of-ignition-570 Your problem sounds different, but it may be related. Although I do not recommend the fix in the link above, it is possible the previous owner of your car did perform this fix and it has resulted in the problem you now have. My better guess is that the chime/buzzer has failed due to moisture or dirt and is no longer producing the sound that it should, but instead is altered to the ringing you describe.To disable follow these instructions:
1. Turn the ignition switch to the RUN (or ON) position. (DO NOT
START THE ENGINE)
2. Wait until the safety belt warning light turns off. (Approximately 1
minute)
Step 3 must be completed within 50 seconds after the safety belt
3. For the seating position being disabled, at a moderate speed, buckle
then unbuckle the safety belt 9 times, ending in the unbuckled state.
(Step 3 must be completed within 50 seconds after the safety belt
warning light turns off.)
After Step 3, the safety belt warning light will be turned on for three
seconds.
4. Within 10 seconds of the light turning on, at a moderate speed, buckle
then unbuckle the safety belt.
This will disable the BeltMinder feature for that seating position if it
is currently enabled. As confirmation, the safety belt warning light will
flash 4 times per second for 3 seconds.
This will enable the BeltMinder feature for that seating position if it
is currently disabled. As confirmation, the safety belt warning light will
flash 4 times per second for 3 seconds, followed by 3 seconds with the
light off, then followed by the safety belt warning light flashing 4 times
per second for 3 seconds again.
I hope this helps. Good luck.
Jun 12, 2014 | 2006 Ford Fusion
How to use a usb keyboard
as a P/S2 keyboard.plug it in the USB contact in the back.in any USB port.
Apr 08, 2013 | Dell Inspiron One 2305 Desktop Computer...
This is probably very simple but I'm having trouble: How do I access my PS2 on my Toshiba tv? I've tried all the different inputs but I can't seem to get the game to show up on the televis
Make certain that you have the audio\video plugs in the right holes. Take note of where you plugged the cables in at, there should be a label like "aux input3" or something similar. After ensuring the cables are in their right place turn the PS2 on and navigate to the aux input.
Feb 10, 2012 | Toshiba Televison & Video
Seat belt buzzer , how do you turn it off.
Hope this helps ya.. Cobra.. :-)
Belt-Minder® Deactivating/Activating Vehicles Built After 5/27/03
Preparation
  1. Before deactivating/activating the belt minder, set the parking brake.
  1. Place the transmission range selector lever in PARK.
  1. Place the ignition switch in the OFF position.
  1. Close all the vehicle doors.
  1. Unbuckle the driver and passenger safety belts.
  1. Turn the ignition switch to the RUN position. (Do not start the engine.)
  1. Wait until the safety belt warning lamp turns off (approximately 1 minute).
  1. NOTE: Step 3 must be completed within 50 seconds after the safety belt warning lamp turns off or the procedure must be repeated.
    For the seating position being disabled, buckle then unbuckle the safety belt 9 times, ending with the safety belt unbuckled.
  1. NOTE: After Step 3, the restraint system warning indicator lamp turns on for 3 seconds.
    Within 10 seconds of the safety belt warning indicator turning on, buckle then unbuckle the safety belt.
  1. The beltminder activation or deactivation is confirmed by the following sequences:
    • If the beltminder is enabled, this procedure will disable the beltminder for that specific seating position. The safety belt warning indicator lamp will flash 4 times per second for 3 seconds to confirm that the deactivation procedure was successful.
    • If the beltminder is disabled, this procedure will enable the beltminder for the specific seating postion. The safety belt warning indicator lamp will flash 4 times per second for 3 seconds followed by a second series of 4 flashes per second for 3 seconds to confirm that the activation procedure was successful.
  1. After confirmation, the deactivation/activation procedure is complete.
Vehicles Built Prior To 5/27/03
Preparation
  1. Place gearshift in P (Park) (automatic transmission) or the neutral position (manual transmission).
  1. Unbuckle the driver safety belt.
  1. Place the parklamps/headlamps switch in the OFF position. (if vehicle is equipped with Autolamps, this will not affect the procedure.)
  1. Turn the ignition switch to the RUN position (Do not start the engine.)
  1. Wait until the safety belt warning lamp turns off (approximately 1 to 2 minutes).
  1. NOTE: Steps 3 through 5 must be completed within 60 seconds or the procedure must be repeated.
    Buckle then unbuckle the safety belt 3 times, ending with the safety belt unbuckled. This portion of the procedure can be done before or during belt minder warning activation.
  1. Turn the parklamps/headlamps on then off.
  1. Buckle then unbuckle the safety belt 3 times ending with the safety belt unbuckled. After this step the safety belt warning lamp will be illuminated for 3 seconds.
  1. Within 7 seconds of the safety belt warning lamp turning off, buckle then unbuckle the safety belt. This will enable the belt minder if disabled and disable the belt minder if enabled.
  1. The following sequence of events confirm the belt mnider is enabled:
    • flashing of the safety belt warning belt lamp 4 times per second for 3 seconds
    • 3 seconds with the safety belt lamp off
    • flashing the safety belt lamp 4 times per second for 3 seconds again
  1. The safety belt lamp flashing 4 times per second for 3 seconds provides confirmation of belt minder disabled.
Jun 15, 2010 | 2004 Ford F150
I cannot get back to change warning sounds on my tomtom
Tap on the screen, go to PREFERENCES -> SAFETY PREFERENCES and choose the warnings you want to enable/disable
Apr 01, 2010 | Tomtom ONE 3rd Edition GPS
How to disable seatbelt alarm on 2003 F-150?
There is a procedure in the owners manual on page 110.
BeltMinder activation and deactivation procedure
1. Turn the ignition switch to the RUN (or ON) position. (DO NOT START THE ENGINE.)
2. Wait until the safety belt warning light turns off. (Approximately 1–2 minutes.)
• Steps 3–5 must be completed within 60 seconds or the procedure will have to be repeated.
3. Buckle then unbuckle the safety belt three times, ending with the safety belt unbuckled. This can be done before or during BeltMinder warning activation.
4. Turn on the parklamps/headlamps, turn off the parklamps/headlamps.
5. Buckle then unbuckle the safety belt three times, ending with the safety belt unbuckled
• After step 5 the safety belt warning light will be turned on for three seconds.
6. Within seven seconds of the safety belt warning light turning off, buckle then unbuckle the safety belt.
• This will disable BeltMinder if it is currently enabled, or enable BeltMinder if it is currently disabled.
7. Confirmation of disabling BeltMinder is provided by the safety belt warning light flashing four times per second for three seconds.
8. Confirmation of enabling BeltMinder is provided by:
• The safety belt warning light flashing four times per second for three seconds.
• Followed by three seconds with the safety belt warning light off.
• Once again, the safety belt warning light will flash four times per second for three seconds.
9. After receiving confirmation, the deactivation/activation procedure is complete.
If you did not get an owners manual with your truck ( purchased used ), you can download one from Ford :
https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
Dec 20, 2009 | 2003 Ford F150 Regular Cab
Safety lock enabled
if safety lock enabled then some options are disabled.
Simply stop moving (stop driving) and all options will come back!!!
and go to Preferences and select Heart icon and select "Disable safety lock"
Apr 05, 2009 | Tomtom One XL GPS Receiver
I need a copy of teh manual for my 2004 Ford Explorer manual.
Wear your safety belt, or simply unplug the harness located at the seatbelt receptacle.
Jan 13, 2009 | 2004 Ford Explorer
Seat Belt Chime
Belt Minder Deactivating/Activating
Preparation
Place the transmission range selector lever in P (PARK) (automatic transmission) or the NEUTRAL position (manual transmission).
2. Place the ignition switch in the OFF position.
3. Close all the vehicle doors.
4. Unbuckle the driver safety belt.
5. Place the parking lamps/headlamps switch in the OFF position.
2. Wait until the safety belt warning lamp turns off (approximately one to two minutes).
3. NOTE: Steps 3 through 5 must be completed within 60 seconds or the procedure must be repeated.
Buckle then unbuckle the safety belt nine times, ending with the safety belt unbuckled. This portion of the procedure can be done before or during belt minder warning activation.
4. Turn the parking lamps/headlamps ON then OFF.
5. Buckle then unbuckle the safety belt nine times ending with the safety belt unbuckled. After this step the safety belt warning lamp will be illuminated for three seconds.
6. Within seven seconds of the safety belt warning lamp turning off, buckle then unbuckle the safety belt. This will enable the belt minder if disabled or disable the belt minder if enabled.
7. The following sequence of events confirm the belt minder is enabled:
-flashing of the safety belt warning belt lamp four times per second for three seconds
-three seconds with the safety belt lamp off
-flashing the safety belt lamp four times per second for three seconds again
8. The safety belt lamp flashing four times per second for three seconds provides confirmation that the belt minder is disabled.
9. After confirmation, the deactivation/activation procedure is complete. user_offline.gif
Apr 02, 2008 | Car Audio & Video
Sony cdxm9905x
There are specific steps to take in order to display video. Simply going to AUX won't do it. Refer back to your user manual. The e-brake wire must also be properly connected in order for the video to work.
Jun 16, 2007 | Sony CDX-M9905X CD Player
Valor Multimedia  DV-170 DVD/CD/MP3 Player Logo
267 people viewed this question
Top Valor Televison & Video Experts
Are you a Valor Televison and Video Expert? Answer questions, earn points and help others
