I opened the back, the hard drive fell out, i put it back in and now my computer is saying check cable connection...reboot and press key
SOURCE: Acer aspire 3515 reboot
Hopefully, though, there's just some craziness going on with the Boot
....suggests that the error messages you are seeing are from a failed
attempt to boot from a network source.
Check the boot order in your BIOS to insure that the hard drive is
fairly high in the list. Generally, I have it something like this:
(1) Floppy Drive
(2) CD-ROM
(3) Hard Drive
If you do this, will it boot from the hard drive?
Will it boot from a bootable CD?
SOURCE: My computer fell
Usually, your computer tries to "boot" from multiple sources:
1. 3.5" diskette drive, if installed, functional, and a boot-diskette is inserted
2. CD-ROM drive, if installed, functional, and a boot-CD (such as the Windows XP CD-ROM) is inserted
3. disk-drive, if installed, functional, and the "boot" record can be read from the disk-drive
4. from the Ethernet network, via a "networked boot server"
So, "check cable" means that either no Ethernet cable is connected to the computer, or that the "networked boot server" is not installed, or the boot-server did not reply.
What this means is that your disk-drive was damaged by the fall, and the "boot" information cannot be read from the disk-drive.
So, you need to replace the disk-drive.
SOURCE: My dell inspiron 1720 keeps rebooting. Pressed
Yes. You'll need to replace the hard drive with that error code.
No matter you can't use that computer without replacing the hard drive.
If you have a warranty for the computer contact tech support for your dell, give them the error code you have
and they will immediately replace your hard drive.
Re seating the hard drive won't fix it.
Hope this helps!
SOURCE: my Toshiba at start up
If I understand you well, before Windows loads, you get a notification
about the ethernet controler which is waiting for a boot data stream to come from a local server. If you don't use a client-server network setup, you'll need to
go to BIOS and change the boot options, so that your hard drive is set
as first boot device, then DVD as second boot device, then USB drive as
fourth boot device, and lastly LAN as fifth boot device.
What happens is that your PC thinks that the LAN is the primary boot
device, and in corporate networks PCs get such a setup so that there's
one large server feeding data to the local cubicle PCs. In some cases the server-dependancy is set to such extent
that these cubicle units are just "dumb terminals". In your situation,
your PC thinks it should also get boot infro from the LAN, but as your PC
is not a part of a corporate network it waits in vain, and after a
while it should move on to the second/third boot device, and eventually find that
it has Windows installed localy and starts loading the OS.
So, to wrap up, you'll need to go to BIOS and set your local hard drive as the primary boot option. This will fix the problem only if your hard drive is OK and you've installed Windows on it.
If your hard drive is failing/gone, then your laptop may not even recognize it and therefore moves on to the next bootable device, which is usually the DVD, and then a USB drive and lastly LAN boot.
Anyway, go to BIOS, and see what is the current setup. If the hard drive is set as first boot option, then this is a good sign that you'll need a new drive.
If this was informative please give it a Thumb Up. Thank you.
SOURCE: my computer says check cable
This error occurs because your hard drive is not detected by your PC. If you can open the tray of your hard disk and try to tighten the cable that is connected to the HD it may fix the problem.
Thanks for using Fixya.
