Question about Sharp AR-5316 Advanced Digital Imager Copier
Prints dark black instead of grey tones
On all docs with grey tones prints them in dark black
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
Your drum is going bad. or your light or dark adjustment is set too dark ( it should be in the somewhat in the middle).
change drum
Posted on Nov 07, 2007
Black in coming out grey
Ensure that cartridge are not refilled, then only you do the following process:>Got to printer properties>printing preferences>color>select print in grey scale>apply>OK.. Then check..Reason why its act like this: In printer properties if its selected as print in color, printer mixes colors to create black(which is visible look like dark grey).Select in properties as above said before clicking OK for the print command, then only printer uses mono cartridge..
Dec 18, 2011 | HP Deskjet F4210 All-In-One InkJet Printer
My printer is reading check alignment, is it because my color cartridge is out of ink?
No, that's not what it means.
If printer heads are not aligned, CMYK colors (Cyan, Magenta, Yellow and blacK - the usual colours in a printer) will not print in the correct place.
Assume a dark grey dot is to be printed. For this C, M and Y colored dots have to be placed exactly on the same spot. But if heads are not aligned, the three color dots will not be exactly in the same place. Therefore you will see Cyan, magenta and Yellow dots adjacent to each other instead of one dark grey dot.
It is always a good idea to align the print heads every time a new cartridge is installed.
Sep 23, 2011 | Lexmark X3650 Printer
My hair is naturally black but at 44 it is 90% grey. I used the med natural for 10 min and it has brown highlights. Some guys have used the dark ash and said they're hair went reddish something I...
Hello Dear
The Dark natural is the best choice but when your hair grow they are naturally grey or white, the show a great different that look odd sometimes. Try one tone down in darker shades. Ash grey is a good option if that suits you and your complexsion. If you need further assisstance tell me your complexsion tone.
Hope it will help you.
best wishes
regards
NOTE: Please rate the answer if you found it helpful.
Mar 12, 2011 | Redken Color Camo Dark Natural
I have a Dell 2135 cn that is currently printing word docs in grey instead of black. Some PDF files print in a bluish black. How can I get them all to print in true black?
is the contrast up all the way? to do that go into the settings of the printer and make sure that the black contrast is up all the way first the if not then there is a control issue with that printer
Mar 04, 2011 | Dell 2135cn All-In-One Laser Printer
Only prints color items so a word doc in black won't print it at all
CHANGE BLACK CARTIRDGE OR REFILL IT.........
IN PRINT OPTIONS PUT PRINT IN GREY SCALE
Mar 16, 2010 | Epson Stylus C66 Inkjet Printer
Epson pro 4800 r prints grey not blank and says to set cartridge
I am having the same problem If anyone has an answer or whether judy you have found an answer.
If I do a greyscale strip to print my black is coming out as a dark grey. the bead off of the greyscale strip would appear that the pbk photo black is not actually printing.
This has been a problem for a few months but as I haven't been doing much printing didn't notice it just thought something was odd. Now I look at previous prints and the blacks are black I print it out now and it is a dark dark grey. Nothing has changed in my profiles or my workflow. I have tried hours of profile paper printing option changes and workflow adjustments but nothing changes, If I print 100 percent black from a file it comes out 95% grey I have tried it from three computers to clarify. It appears is a 4800 problem.
Perhaps it is not recognising that it is a PB catridge.
I have no idea.
I have tried adjusting the settings from the printer but there is no option to clarify catridge from the printer.
This is odd, if anyone has any idea.
Mar 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Canon MX310 - print is gray instead black. How to fix it.
I wish someone would REALLY solve this, but I've found two (time-consuming!) workarounds:
1) Despite using plain paper, tell it you're using "Matte Photo Paper" (this is necessary in order to...) then set the print quality to the next-to-highest level (default is middle of five quality levels). The doc will print in black as it should, not grey.
2) Instead of the above, use the printer dialogue option to print to a PDF file; then open the pdf and print it. It will print in black, not grey!
WHY WHY WHY WHY WHY?????????!!!!!!!!!!!!!!!!!
Dec 31, 2008 | Canon PIXMA MX310 All-In-One Printer
Epson R265 printing colours incorrectly
For the black and white issue, check the settings and make sure that it isn't set on "sepia". As for the color issue, it is quite possible that you are out of ink. Printers may use more of one color than another depending on what you're printing. Change your color cartridge.
Jul 02, 2017 | Epson Stylus R265 InkJet Photo Printer
Dark edges
It depends... never use a Reman cart in these machines... only use sharp...especially if the machine is under warranty.
Does this happen when,
Using the Doc Feeder
When making copies from the Glass
Or when you print from a computer (assuming you print from a PC)
If you print something and this happens then it is inside the machine
Probably toner or developer dumping...
Take a few pieces of large white paper and cover the entire glass surface... make a copy is the line there? If so see the answer above... if not then close the top and make a copy with no paper on the glass... is that black line there.. If so then your top needs adjustment...
One more test
If you make a copy using the doc feeder, this black line only occurs when making copies with the doc feed, clean the **** glass, and try again...
Oct 25, 2008 | Sharp AL 1215 Black and White Copier
Grey tone problems
Hi,try this: in the printer driver choose imaging and find "color reproduction" button. Just adjust that balck and gray will be printed FROM BLACK TONER ONLY(print black text and graphic from black toner only)
Regards
Mar 17, 2008 | Kyocera FS-C5030N Led Printer
Sharp AR-5316 Advanced Digital Imager Copier Logo
410 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
