Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
JD 2510 wont start
My 2510 gas wont start if I let it set for a few weeks. If I shoot it with starting fluid it fires right up ?????? any help appreciated thanks
  • gstaxidermy Jun 28, 2009
    Thanks I'll give it a try
    Scholar:
  • 48 Answers
Gasoline may be leaking away from the carburetor during the weeks layover or it may be evaporating away also.
I'm thinking you've already got your solution, but I'l like to add a twist to it to prevent future problems. Shut off your gas supply to the carburetor and let it run out and die when you start your weeks off for this mower. That way no gum deposits can form and mess with your air/fuel mixtures.
Then turn on the gas and give it a shot of starting fluid and forget all your possible troubles with gumming. I have a 1944 JD 'A' that I do the same thing with sans the starting fluid - because I don't need it. Those old puppies are still around running fine because this is standard operating proceedure with 9 out of 10 owners of these old steel machines. It's just the most trouble free way to get the job done - then and now.
Posted on Jun 28, 2009
Ran out gas 3020 now will not start
try squriting some stating fluid in it the carb it should start if does look for water are dirty gas replace it with clean gas fresh gas dont use old gas chang fuel filter changs hydrostatand filter and oil do a service on it use a fuel additve called`sea foam in only one that i no that works follow instruction on bottle how to use see if that wont get you going
Sep 03, 2014 | John Deere Step 2510 2520 3010 3020 4000...
1989 TLC Gas engine...wont start
Check to ensure fuel pump fuse hasn't burned out. Try spraying starting fluid directly into the throttle body to see if it tries to catch.
Nov 16, 2013 | 1989 Toyota Land Cruiser
My 2510 tracktor won't start
drain the fuel out, get rid of all the fuel additives. take the carburetor off and take apart and clean with spray carburetor cleaner. clean the bolt that goes in to the bottom real good. clean the holes in it good. put it back together and it will be good. it sounds like it has debris in there some where that needs cleaned out.
Jun 14, 2017 | John Deere 420,1020,2010,2020,2510,2520...
Onece in a while turn over wont fire. runs great other wise
your injector or fuel pump may be going out, next time when you check the issue, check your distubutor again and making sure you getting sparks, if you do have sparks than it has to be your fuel problems.
Jun 25, 2009 | 1991 Honda Civic
Model 180 John Deere garden tractor won't start
*cyliniod sticking... try banging on it with the blunt end of a good heavy screw driver / or the handle of a hammer. might free up the contacts, or it might be too rusted inside...
*yes to the first part about starting fluid...the starting fluid should have fired off the motor for a few seconds...so since you didnt get anything after this, it sounds like your not getting adequite fire to the cylinder (s) .
i would try a new spark plug since that would be the cheapest thing to start with first.
Jun 24, 2009 | John Deere 420,1020,2010,2020,2510,2520...
98 plymouth neon (automatic) starting problem
shoot some starting fluid in the air intake and try to start again. If it starts you have a fuel problem. If still no start could be an ignition problem.
Apr 08, 2009 | 1998 Plymouth Neon
2000 Chevy Blazer Cranks but wont start...
What about the fuel filter????? Have you changed it out??? If you can spary something like a started fluid, that means it is a fuel problem. My last check, it has to be above 50-psi on the fuel pressure to make it run right. I had 35psi, but whould not get over 30mph or down hill maybe 45mph. Check both filter & pressure, but check pressure with a New fule filter!!!!
Jan 18, 2009 | 2000 Chevrolet Blazer
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
329 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
