Question about Acer Aspire 5040-3810 Notebook
Connect to a gemini writer via bluetooth all com ports full
My computer is telling me to disconnect a com port to open up space but I do not know how to accomplish this task. I did find the com port in the device manager but I just do not know how to disconnect and I don't want to do the wrong thing
Hello...i am using sony ericsson k550 i had a trouble in that i cant send any files through bluetooth my bluetooth is not working pls any one tell how to solve this prob
Make sure your phone and the other Bluetooth device are charged, switched on and within range of each other. Make sure Bluetooth wireless technology is turned on, and that the devices are set to be visible for other Bluetooth devices. Check that the two devices are paired, and have found each other. If there are still problems, you'll have to reset the connection and pair the two devices again.
In some Bluetooth installations, you must activate a COM port manually in your computer. This is done differently for different brands and models of Bluetooth devices. Please see the manufacturer's product documentation.
If a COM port is not activated
1. In many cases, you can right-click on your phone icon in the window where all found Bluetooth devices are shown, and select a 'COM port activation' item in the menu. Make a note of the COM port number of the activated port.
2. Open Sony Ericsson PC Suite and click Tools/Phone Monitor Options.../Com Ports. Enable the COM port you activated in step 1.
3. Keep the Bluetooth wireless technology turned on in your phone, restart the computer and try to connect again.
Feb 08, 2011 | Sony Ericsson K550i Cellular Phone
To transfer pictures from iphone to computer
Use the bluetooth to connect your Iphone to the PC.
Open menu - connectivity and click bluetooth to ON.
You can also open the picture and use right key to send via bluetooth. The laptop must be On as it will detect the bluetooth, accept and get all the files send.
Sep 17, 2010 | Apple iPhone 3G Black Smartphone
Text memory full states on notification cant receive texts but i have no messages saved so i st .arted clearing out stuff tha had a storage i still have full memory. HELP PLEASE
Dear Sir\Madam,
I had a similar problem, and I was able to solve the problem by simply following the below steps. 1. If probably your phone has a bluetooth device and you have been receiving gallery files(i.e. Photos, Musics or Videos) via bluetooth, note that this files are stored too on your phone memory not the memory cards and this may consume space on the phone memory. So, try and move those files that you received via bluetooth in your received folder on your phone memory to the location of your memory card. This may probably free the space on your phone. 2. if you have been receiving bluetooth files as a message into your phone depending on the type of phone you are using, simply save them into your memory card by selecting the memory card path and delete them after saving so as to free space on the phone memory. Then try to delete as well some unwanted or junk messages from your phone in have more space on your phone memory.
Hope the information actually help. Regards
Sep 03, 2010 | Cell Phones
I cant figure out how to connect my jornada to my pc.. can you help?
Are you connecting from dock to USB on computer, or serial to USB via a USB-serial adapter? UBS-serial adapters are notorious for not recognizing attached serial hardware. What kind of errors are the Jornada and the computer throwing? Can you give any specific error numbers?
If you are connecting using the serial cable to a serial port on your computer you need to make sure that the Jornada is trying to connect to the correct COM port (and that the computer is allowing connections through the correct COM port). Do this by:
1. Open Device Manager (R-Click on My Computer - Properties - Hardware - Device Manager)
2. Expand the "Ports (COM)" plus sign
3. Beside each COM port's name it will say (COM#) - the # tells you which port the COM is
4. Go into ActiveSync and open Connection Settings (in the File menu in ActiveSync 4.5 - the latest)
5. Make sure all the check boxes are checked and that the correct number COM port is selected in the drop down menu under "Allow connections to one of the following:"
6. Connect your Jornada via the serial cable, make sure the Jornada is on and connected to power cable (I have had more success with the power on - may or may not affect your problem)
7. Click the "Connect..." button in ActiveSync. The Jornada should be detected.
If your computer has an infrared port you could try that, I have had a lot of success with infrared connections with my Jornada. Also, try installing ActiveSync on another computer that has a serial port and try connecting the Jornada to that computer. It may be a problem with your computer.
An older version of ActiveSync should not make a difference. The facilities are the same, just slightly rearranged.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 01, 2010 | Computers & Internet
Router cant handle two pc's connecting to same server
Try to do port forwarding. Search for the port number that the game uses and open it on the router's Setup Page using Port Forwarding.
Apr 25, 2009 | Linksys (WRT54GC) Router
Not able to connect to BT Homehub wireless Toshiba Satellite Pro
  1. Click the Start button getcontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=signed1, click Control Panel, and then double-click Bluetooth Devices.
  2. Click the device that you want to change, and then click Properties.
  3. Do any of the following:
    • To change the name of the device, click the General tab, type a new name, and then click OK.
    • To enable a service, click the Services tab, select the check box next to the service, and then click OK.
    • To disable a service, click the Services tab, clear the check box next to the service, and then click OK.
    • To make your computer discoverable to Bluetooth enabled devices, in the Bluetooth Devices dialog box, click the Options tab, and then select the Allow Bluetooth devices to find this computer check box.
    • To make Bluetooth enabled devices discoverable to your computer, in the Bluetooth Devices dialog box, click the Options tab, and then select the Allow Bluetooth devices to connect to this computer check box.
    • To be notified when a Bluetooth enabled device wants to connect to your computer, in the Bluetooth Devices dialog box, click the Options tab, and then select the Alert me when a new Bluetooth device wants to connect check box.
    Warning
    • To help protect your computer, only make your computer discoverable when you want a Bluetooth enabled device to find your computer.
Some computer programs require a COM port (also called a serial port) to communicate with a Bluetooth enabled device. For example:
  • A program that synchronizes contacts with a mobile phone
  • A program that extracts Global Positioning System (GPS) coordinates from a GPS receiver
When you use the Add Bluetooth Device Wizard to add a Bluetooth enabled device to your computer, you create an incoming COM port, which permits your device to connect to a program on your computer, and an outgoing COM port, which permits a program on your computer to connect to your device. Usually, you only need to use one of these COM ports.
To decide which COM port to use, you can check the information that came with the program or your Bluetooth enabled device, or go to the manufacturer’s website.
If you're still not sure which COM port to use, try each COM port, one at a time, and use the one that successfully allows the program and your device to communicate.
Mar 31, 2009 | Toshiba Satellite Pro L300 Notebook
Hp jornada 720 handheld pc
Try a older version of active sync. 3.0 or 3.1
heres 3.1
http://www.tucows.com/preview/32548
Feb 17, 2008 | HP Jornada 720 Pocket PC
I thought I had Bluetooth in my computer...
Yes, you can use bluetooth mobile devices. COM 3 os the port that the bluetooth uses to connect to a device. You can think of it like a wireless modem. You can also configure other COM ports for communication with bluetooth devices using the connection wizard. I would suggest not to do this unless you know what you doing. From my experiences with bluetooth devices they can b a little touchy, and you have to careful you don't want to pick a port that another program is already using. ConfigFree is capable of configuring this bluetooth connection, but there are also other programs out there that you can use as well.
Nov 07, 2007 | Toshiba Satellite A105 Notebook
Imate jam PC synch
dear abid, connecting the i-mate to computer using bluetooth is a good and a fast way and give you the an option to connect more than one device, you can connect through bluetooth with this procesure : step one: set up a bluetooth COM port : 1- Open the Bluetooth Devices Control Panel. On the Options tab, select Turn discovery on and Allow Bluetooth devices to connect to this computer. 2- On the COM Ports tab, click Add. 3- Select Incoming (device initiates the connection) and click OK. 4- Note the number of the COM port that was added. The COM port number must be no higher than 20. 5- Click OK to close the Bluetooth Devices Control Panel. step two: 1- In ActiveSync on the PC, on the File menu, click Connection Settings. 2- Select Allow connections to one of the following. 3- Choose the COM Port with the number you noted in Step 1 Set up a Bluetooth COM port. 4- Click OK. Step 3 Start Bluetooth sync from your device: In ActiveSync on the device, tap Menu, then tap Connect via Bluetooth. that's all... and i am waiting for your replay
Jul 27, 2007 | i-mate JAM Pocket PC
Activesync via bluetooth
I have bluetooth Activesync working on my hw6515 connected to a Dell x300. Followed the instructions in the User Guide Chapter 9. Need to take note of the com port assigned to bluetooth serial port on the PC. Connection must be initiated each time from the IPAQ ie go to buetooth manager and connect the activesync shortcut.
Sep 08, 2005 | HP iPAQ hw6500 Pocket PC
Acer Aspire 5040-3810 Notebook Logo
75 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
