Question about Acer Aspire 5100 Notebook
The computer just dies while using it whether on battery or power supply. When I try to start it back up, I have to push the power button several times before it will run.
  • Acer Master
  • 2,404 Answers
Make sure the battery is out and your only using the ac adapter. If its still dies on you and your having to push the power button several times to get the machine back up and running that means the motherboard is bad.
In fact when your laptop turns off, check to see if you feel any part of the laptop that feels very hot or very warm to the touch, thats a sure fire way to know that the motherboard is bad as long as you can feel air then you know the fan is running.
If you only hook up the ac adapter and the machine runs fine then its a faulty battery.
Posted on Jun 28, 2009
Acer AM1100-E1304a do not start.
Try removing the battery. It may be the battery is eating all the power that the supply can produce, leaving nothing to run the computer. That could happen with a shorted cell or a completely dead battery. IF the power supply you are using is the correct one for your laptop.
Oct 27, 2014 | Computers & Internet
Gateway gt4016 wont turn on you can hear the fan and light flicks on for a second but then nothing changed the power supply nothing
try rebooting your coumpter is in sleep mode it takes a long time but you will get it back on .... keep pushing the power button aventally it will start up
Jun 30, 2012 | Gateway GT4016 Desktop PC
The power button doesnt start the laptop
Toshiba Satellite R15-S822 Tablet: Battery is charged and operational power supply (charging light is on) is plugged into power port on back side of laptop: Problem is sliding "power on" switch does not start laptop - no sign of any electrical activity...
Nov 04, 2009 | Toshiba Satellite R15-S822 Tablet PC
Laptop won't start
remove battery and check if is charged.
put back battery and connect power supply.
keep ON button pressed few seconds until it flashes.
if not started wait few second and try switching on normally.
if unsuccessfully check both power supply and battery with manufacturer
Jan 11, 2009 | Computers & Internet
Dell e510 won't make it to post
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on). If you purchased a non dell power supply, you might try this with the original one installed.
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Nov 09, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Oct 11, 2008 | Dell XPS 200 PC Desktop
Will Not Power Up
the middle one with the A is Caps Lock....
Try removing the Battery from the System.... There is a power indecator on it....... Push the button on the battery Five lights full battery.... No Light Dead.... If Dead Your Power supply might be at fault....
Is the power Supply Light Lit? If No.... Bad Check connections..From Wall to Brick ect.... Still No... PSU Looks Bad....
Jan 07, 2008 | Dell Latitude D600 Notebook
Toshiba satellite a135-s23876
if I'm not mistaken there is no reset button ot this Satellite. Try unplugging the charger and removing the battery to reset it. Let me know what happens
Alex
Nov 09, 2007 | Toshiba Satellite A135-S2386 Notebook
Philips GoGear 3GB WILL NOT START UP
the combination is "UP" and "Volume+"
Dec 10, 2006 | Philips HDD070 MP3 Player
Acer Aspire 5100 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
