Question about Acer AL1916W 19" WideScreen LCD Monitor
I have an Acer AL1916W the power switch lights up brightly but when computer is switched on switch goes dull and and screen stays blank...Found two Capacitors that were bulging they were 220mf 25volt....I replaced those with new ones but still not working nothing shows on screen still
  • 1,684 Answers
Can you send me a picture of the boards in your monitor? We work on Acer units all the time.
Buddy
Corporate Computer
www.ccl-la.com
buddy@ccl-la.com
Over 21 years of PC and printer support/repair
Posted on Jun 28, 2009
My monitor comes on and then goes off
Time for a new monitor. I have the same problem. Tried the monitor on three different PCs and it turns on for 2 seconds then goes blank, power stays on (green LED on power switch).
Temporary solution that worked for 1 day was to turn the brightness to 0 if you can manage to keep it on long enough to use the menu.
Jan 01, 2013 | Acer AL1916W 19" LCD Monitor
Usually when i plug in the charger to computer the screens gets brighter, it no longer does that, my screen is very dull and not bright how can fix?
you can change that in power settings right click on the battery bottom right of the screen hit change power settings u will get options u want to change power settings look at the options you want to make it stay brite all the time right now you have it set to be brite only when plug is in change the option when its unplugged to brite also
Aug 10, 2012 | Acer Aspire 7741z
I am using acer P205H monitor ,when i plug in it will start and shows acer symbol on the screen but goes blank as computer starts ,i checked all power cables they are OK ,and some switches are provided on...
that switches r made basically changing dvi to vga r vga dvi,if that switches r malfunctionig display goes to blank that means if u connect vga system will have dvi
Jan 30, 2011 | Acer AL1916W 19" LCD Monitor
Acer AL1916W about 2 years old. Turned on this
Bad caps in the power supply, common problems with 2-year old monitors, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 25, 2010 | Acer AL1916W 19" LCD Monitor
When I turn on my monitor which has been plugged into my laptop; the Acer name shows on the screen and then it fades and the message shows "no signal" and then the light on the power switch goes red. I...
Try pressing the AutoSet button and if this fails try a different cable. Make sure that you press the external monitor select key on the laptop and that the brightness and contrast is not turned all the way down.
Dec 30, 2009 | Acer AL1916W 19" LCD Monitor
Acer Monitor Not Staying On
It sounds like there's a problem with the monitor itself. It may be that the lamp in the computer is dying, which would explain why it keeps going out. Other possibility is that the monitor isn't receiving power properly either through the cable or inside the monitor itself.
If your're not the kind of person who wouldn't mind opening the monitor up and hopping in there, then I recommend you take it somewhere it can be diagnosed like Best Buy.
Hope I helped :)
Nov 28, 2009 | Acer X223WB 22" WIDESCREEN LCD Monitor
Display coming for 2 sec and then it goes off
Does it work well with other computers?
If you are connecting to a laptop, try switching display modes (like you would do for a projector)
Sep 03, 2009 | Acer AL1916W 19" LCD Monitor
ACER Al1916W goes blank in 3 seconds. It shows ACER splash screen for a sec., the desk top for .5 sec, then goes black. There is a very high pitch squeel each time there is any display. Power switch turns...
Yes, The inverter is the problem on your monitor. We have a step by step guide to dis-assemble and repair your monitor posted on our web site at:
www.ccl-la.com/monitor_repair.htm Your model is the same as the westinghouse L1875NW. We have a parts kit for $12.00 if you need it, it can be purchased on the guide page. If you don't want to do the repair yourself we can do it for $35 + shipping. This is a common problem with that series of monitors but the repair will get you back going.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Acer AL1916W 19" LCD Monitor
Acer aspire 3000
Could be a bad memory chip or a hard drive crash. Can you hear the hard drive engage? If so, is there any clicking or dull thunking sounds? Both of these are indicators of a hard drive failure.
Jun 21, 2008 | Acer Aspire 3000 Notebook
Computers & Internet Logo
272 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
