Question about Mk Diamond Benchtop Wet Tile Saw
Breaker Keeps Popping
No matter what electrical outlet I plug my MK tile saw into (I've used different breakers) every time I turn the saw on, it pops my breaker. I tried it at my sister's house as well with the same result. Help?
    New Friend:
You've definitely got a short.
Posted on Nov 18, 2012
    Sniper:
  • 54 Answers
There is something wrong inside the saw.
if you are trying different amperage breakers ( trying a 15 AMP breaker and then trying a 20 AMP breaker) or if you are trying all 15 amp breakers try a 20 AMP
Posted on Jun 28, 2009
Why did my treadmill stop abruptly while in use?
Your assumption is correct, if you have a household circuit breaker popping, you have a short or over current situation. If you have too many other things plugged into the same circuit you could be overloading that breaker. Depending on how your home is wired, you could have a few (older homes may have quite a few) outlets feed by a single breaker. If you have used the treadmill in that outlet (with the same items plugged into that circuit), the breaker it's self MIGHT be going bad (popping at too low of current).
For safety, inspect the power cord, for any damage, and be replaced if there is any.
If the power core is undamaged, I would try plugging the treadmill in another circuit. Choose an outlet that was not affected when the breaker popped. It you use an extension cord to get to another outlet, be sure it's rated for enough current. If it still pops the same breaker it's the same circuit, and you need to plug it in somewhere else (probably in another room). If a different breaker pops, then the short in in your treadmill. At this point you will need to know something about electricity to further isolate the short.
May 19, 2014 | Endurance T3 Treadmill
Pops Circuit breaker when plugged in
Have you tried plugging it in to a different outlet? You may have too many things using that same circuit. Seems worth a try - hope it helps. We found that our fridge was using the same circuit as our washer and microwave and this kept it from popping the breaker after we used another outlet.
Nov 23, 2013 | Hotpoint HSS25GFP Side by Side...
My Maytag Portable Air Conditioner Model #M6P09S2B keeps popping my breaker. Can you help me solve this problem?
This can because by a couple of things. An electrical fault within the AV Unit or the electrical circuit the unit is plugged into has other electric appliances on the same circuit. Thereby, overloading that one circuit. Try plugging the unit into another outlet that is on a different circuit. If it trips a circuit breaker then, the problem is within the unit. In which case, you will need to have the unit checked and serviced.
Hope this helped you and thanks for choosing FixYa.
Jul 29, 2011 | Maytag M6P09S2B Portable Air Conditioner
Brand new saw trips 20 amp breaker every time I turn on the saw. It starts to turn and after about a second the breaker trips. Have tried different plugs on a different breaker. Still it will not start....
How long of an extension cord are you using? Is it at least a 14 gauge wire? It should be 12 gauge. If it 16 or a long 14 it will cause the problems that you mention.
If this is occuring when its plugged directly into the outlet then it is likely a problem with the saw. Before you take it back tho try another outlet on a a different circuit.
Jun 30, 2011 | Dewalt DW744XRS 10-inch Job Site Table Saw...
Start capacitor keeps blowing. saw starts up
SOUNDS LIKE THE CENTRIFUGAL SWITCH IS NOT WORKING.
THE MOTOR IS STARTING ON THE START WINDING AND NOT SWITCHING TO THE RUN WINDING. THAT IS THE REASON IT IS RUNNING SLOW.
May 13, 2010 | Diamond Products Mk - 101 10" Tile Saw
My refrigerator keep popping the electric outlet
What do you mean by "popping"? If you are plugging it into a GFI receptacle it will do that. Use a different receptacle. If it is popping the circuit breaker, you may have an electrical problem in your house.
Dec 30, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Tile saw tripping breaker even after letting it cool down for 24hrs .
2 things first what is the motor rated at for AMPS and second the circuit you plug it into what is the rating. The saw will draw more than the namplate rating for startup but it would still pull a lot and if you have something else on that circuit it could be causing the problem assuming there is no major electrical problem with motor
Jul 02, 2009 | Mk Diamond MK 101Pro Tile Saw
Samsung AC keeps popping breaker
use larger extention cord with thicker wiring,as short as possiable!
Jun 25, 2009 | Heating & Cooling
Mk Diamond Benchtop Wet Tile Saw Logo
398 people viewed this question
Top Mk Diamond Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Mk Diamond Saw Expert? Answer questions, earn points and help others
