Question about Palm TX Handheld
Cannot turn Palm TX on after listening to music. Button protection was set to "on". Now I cannot turn it on with any buttons. Tried charging with wall charger overnight. The case normally gets warm on back side during charging. Now it does not. I don't think it is charging.
  • d_p_perryatl Jul 09, 2009
    Tried your solution several times, still no TX. I will order a battery and replace it, then we'll see what happens.
Something similar happened to me. I finally gave up on my wall charger and tried connecting my PDA to my computer and pressed reset button several times. I left it connected overnight and It was working by the next morning. My guess is that my battery was completely drained and my wall charger quit working.
Posted on Jul 09, 2009
My Palm TX is new (received in Dec) and is fully charge but it does not turn on. I have pushed the rest button and nothing. Help!!!
If you cannot get it to fire up on either the charger or just the battery then it needs to go back to the store or to Palm for repairs. Should be under warrenty for the store and Palm.
Mar 22, 2010 | Palm TX Handheld
Have to reset Palm TX to power on sometimes
I have a palm TX and it usually just sits for a minute or two when I use blazer. I have also found out that the pda will always reset itself and it only freezes when it has a lot going on. It stays frozen for a while, but eventually unfreezes. As for the home button, it's probably worn down. My power button and my up button have almost completely stopped working.
Sep 09, 2009 | Palm TX Handheld
Palm tx wont turn on
When the battery is discharged, it is best to charge it overnite.
Have you reset the TX?
Hold the power button down and push in the reset button on the back of the TX with the stylus. Hold the power button down until you get the screen where it ask you if you want to erase/reset the unit. click yes to reset.
Then when it comes back up, re-sync it with the Palm Desktop on your computer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 17, 2009 | Palm TX Handheld
Palm TX handheld
First you need to reset the TX:
hold the reset button on the back of the unit, then turn the power on. Hold the power button while releasing the reset button. The TX will power up to the screen where it will ask you if you want to reset it to factory default.
Afterwards go to this link,
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=1568,E=0000000000263321976,K=3877,Sxi=4,case=obj(32859)
and download the Palm Desktop/Sync software and install it onto your PC. After installing the the Palm Destop software, connect the sync cable to the PC via the USB, then connect the cable to the TX and push the sync button.
Click on this link or copy and paste the complete link into your browser.
Thanks, Joe
Mar 29, 2009 | Palm TX Handheld
My Palm TX device is not initializing. it says "palm powered" then a loading bar starts at the bottom of the screen, then it turns off...and it repeats the same thing over and over again.
Have you tried a hard reset? In case you need to know how...Hold Power button on Top of Palm down, then press reset button, then release reset button and continue to hold power button down until second Palm logo comes on screen and progress bar at the bottom of screen completes. If you release the power button and it asks which language you want to use you have done this correctly.
Jan 21, 2009 | Palm TX Handheld
Palm Tx problem after hotsync
I had the same issue, the palm is stuck in a loop,
I got mine out of this by pressing the power button while the palm was on the screen where the bar goes across the bottom, it asked me if I wanted to erase all data, I said yes, and it reboot normally, I went thru the setup, and all is o.k.
I did have to try this several times, but it eventually worked. Hope this helps, although it looks like this is an older question. I hope you have resolved it.
Oct 12, 2008 | Palm TX Handheld
Palm Pilot tx will not switch off
Could be a malfunction with the power button.  Go to settings and make sure the sleep timer is set.  That will save your battery life.
Oct 03, 2008 | Palm TX Handheld
Palm TX not powering up
Your Palm will auto-off after 30 seconds to 3 minutes of not using it, depending on the auto-off setting. If that's not it, you may have conflicting software installed. I had a lot of software installed on mine before and it got to where it wouldn't come on. I had to do a hard reset by holding the power button in while pressing the reset button until the screen comes on. This restores the device back to original state. You will have to reinstall all additional software that you want to add, but it will take care of the conflict. If that doesn't work, then the battery is probably no good, or the device is no longer functional. Hope this helps.
Mar 20, 2008 | Palm TX Handheld
The palm powered icon
To do a hard reset, hold down the power button, press the little reset button, release it, then release the power button.
Make sure you back up your TX first.
Jan 29, 2008 | Palm TX Handheld
Palm TX
Hey mike.
First, i have a question,
have you tried to reset it.
if not try it. press the little button at the back using your stylus and check if it will reset.
good luck
Nov 19, 2007 | Palm TX Handheld
Palm TX Handheld Logo
207 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
