Question about Canon PIXMA iP4300 InkJet Photo Printer
Black text printing not using large cartridge
Have an iP4300. When printing just black text it still uses the smaller black color cartridge - never the larger black cartridge. How can I change this?
  • Canon Master
  • 365 Answers
Change your setting to plain paper and normal quality.
This printer uses the small black for photos and high qau;ity papers.
Do this and you should be good to go.
Posted on Aug 10, 2009
Canon ip4300 color ink empty but I only want black
No, Canon does not have this facility. Also mostly greyscale is not light black but rather a mixcture of the 3 primary colours. You should have a reset/resume button on the printer - hold this in for a slow 5 seconds to de-activate ink warnings per cartridge that is giving alarms. Proceed carefully and only print text that is black so that the colour printheads do not burn out.
Feb 18, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Canon IP4300 - the two black ink cartridges
No!
The large cartridge is used for text only printing.
The smaller black cartridge is used for black in images such as pictures.
You have a "C (cyan) M (magenta) Y (yellow) and B (black) color system. This actually saves the color inks for you. If the Black was not there, you would need to make a composite black from the color inks.
Don
Jan 31, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Canon MP610 Printer
You cannot switch to the larger black cartridge. You are using a CMYK (Cyan, Yellow, Magenta, Black) format for printing color images.
The larger cartridge is used for text only. The smaller black cartridge is used for color or graphic images.
If the black cartridge was not present, every time you needed black in an image, it would have to come from the composition of Cyan, Magenta and Yellow. This would greatly reduce the life of the color cartridges.
Don
Dec 12, 2009 | Canon PIXMA MP610 InkJet Printer
I have run out of black ink in the large cartridge. Can I make the rpinter use the smaller cartridge to print black and white?
No, the larger cartridge is used for text printing only.
The smaller cartridge is used to add black to images instead of using the color ink to make a composite black.
Don
Oct 23, 2009 | Canon MP610 Photo All-In-One Printer
Can i print black and white text only when colour cartridges are empty but black is full on an ip14300?
you can make a selection from the File->Print option of your word processor or whatever package you are using. it is your command that sets the printer to B&W or color. If your Black ink finishes then the printer even if set to color will print black as near black with color inks.
Sep 14, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Ink cartridge running low will it default small cartridge
It won't default to the small one...I emailed Canon support; this is the response I got.
The reason for the two different black ink tanks is for the different types of printing your unit is capable of. They are not intended as backups to each other. The larger black tank is pigment based, and is primarily used for standard black text printing or output. The smaller black ink tank is dye based like the color inks, and is used for photo and graphics output. They are designed to complement each other, allowing the printer to produce the best possible black text output or photo quality as appropriate.
Feb 25, 2009 | Canon PIXMA MP610 InkJet Printer
Pixma MP610 - fab machine - only problem is that the large of the black cartridges empties - never uses the smaller one (No 5) why? It refuses to print if the No 8 is empty. What do I need to do please?
The large of the black cartridge (5) is for ordinary paper in printing menu of computer. Selecting photo paper uses only the small black cartridge (8) and the color cartridges are used to make black even for gray black printing. Choosing ordinary paper, you can print in black 10 even 20 times with the large black cartridge (5) (by refilling and quoted as empty) . You simply need to press a long time the hold button, as explained in the manual on the printer CD, to continue to print with an empty cartridge. (at least in Europe)
The color cartridges are slightly used even when printing only in black and become empty, even if you never use the colors!
Jul 28, 2008 | Office Equipment & Supplies
Does not recognise the smaller black ink cartridge
This machine is not meant to switch between the two black cartridges. The large one is used when you are using black only, and the small one is used when you are printing in color.
Jul 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Two black cartridges required??
The printer does recognize 2 different catridges. My understanding is that the smaller is specific to photos,
but the larger is used for everyday text and pages.
I would get the cartridge and then wait to see if the printer
won't print photos when small cardtridge is out. If it does
print, pictures may not be good enough for you.
Apr 18, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Can't I print with only one black ink
I have a similar machine ip5000. Currently have a problem getting the big one to print and have posted for a solution elsewhere. If I print withjust the small tank it does some black work i.e. type but it needs the other big tank to give full photo pictures.
If you are just looking to print typing try changing your font collour to a dark blue or other. This gets round the black problem but you will need the 2nd black cartridge for full colour work.
Hope this helps.
Mike
Mar 07, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
265 people viewed this question
old marine
old marine
