Question about E-Machines (308714) Motherboard
No signal display on monitor for emachine T5086
I've checked the cable and the monitor on a different computer and they both work fine. I didn't see any additional video cards and I'm not sure how to find out what components were originally installed on the computer. Everything is still original, will a missing or corrupt video driver cause this issue? Need a diagram of mother board
  • ldrury69 Jun 28, 2009
    do u have an idea of where I can get a diagram of the motherboard. I have an extra video card that I can use temp. what would be best way to check mobo?
  • ldrury69 Jun 30, 2009
    thanks will give it ago. unfortunately having to run back and forth to different location. Will update if repair works later. Thanks
    Sniper:
  • 54 Answers
Add a external (slot) card for video temp, and see if signal comes up, and boots to Bios, it might have the onboard video disabled if so you should be able to enable it and then pull video card and check the MOBO
Posted on Jun 28, 2009
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
Plugged in my emachine LE1938 to my dell without the DVI cable, screen displays 'no signal'. Shouldn't the monitor work without the DVI cable?
The DVI cable transports the display signal from the video card to the monitor.
I think what Ron is asking is if you used a different cable to connect the monitor to the computer. (I'm assuming you used an old 15 pin monitor cable or whatever those old cables were?)
Without getting into your BIOS:
So on your computer, you probably have an onboard video card (a video card built into the motherboard itself), and a dedicated video card (probably where you're seeing the DVI out).
It may be possible that you have the on board video card (with the traditional connection) disabled, when the dedicated video card is plugged in.
This isn't rocket science, so don't worry. Phillips head screwdriver is all you need.
Pull the side panel off your computer (assuming it's a tower... if not, it's the top panel). Once you have it off, you'll see that video card plugged into a slot on the motherboard, with 1 phillips head screw holding it in place (inside, near the back, where the DVI port is).
Pull the screw, and the video card should come out. From there, the BIOS should recognize your card is missing, and thus revert to using the onboard video card.
Sep 02, 2012 | eMachines E-machines flat screen CRT 17"...
The display on screen says check digital cable... i replace the one which is working with another monitor
If it's giving you a missing signal and you've tried a different cable it would be in your best interest to try a different monitor. It's very possible that you have a either a bad graphics card or a bad monitor.
font.f1 {font: 12.0px 'Lucida Grande'; color: #000000} I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jun 29, 2011 | Samsung SyncMaster 910T 19" LCD Monitor
The monitor i see selt test G check your
Connect the monitor to a different computer, e.g., a laptop, to see if the monitor works at all.
Connect a different monitor to your computer, to see if your video-card is outputting any signals.
May 10, 2011 | E-Machines eMachines Desktop PC
Computer monitor wont turn on when you hold the power button a small orange light turns on. What is wrong?!
CONNECT THE MONITOR DIRECTLY TO THE WALL OUTLET
CHECK WHETHER YOU GET CHECK AUDI SIGNAL OR NOT OR ANY MESSAGE---HTEN CHECK FOR THE CABLE---IF STILL THE ISSUE PERSISTS CHECK IT WITH A DIFFERENT CABLE---
THEN CONNECT IT TO THE COMPUTER MAKE IT SURE THE COMPUTER IS TURNED ON AND THE POWER IS GIVEN TO THE MONITOR AS WELL----CHECK THE COMPUTER WITH ANOTHER MONITOR---IF THE OTHER MONITOR IS WORKING FINE THEN CONNECT YOUR MONITOR TURN IT ON AND THEN FLASH A FLASH LIGHT OR TORCH LIGHT AND THEN SEE IF YOU CAN SEE A DISPLAY INSIDE..
WHILE CHECKING FOR ALL THESE STEPS YOUR ISSUE WILL BE RESOLVED IF NOT TYOU GOTTA CONTACT THE MANUFACTURER FOR A FAULTY MONTIOR---
STEPS IN BRIEF:
DO A MONITOR SELF TEST
CHECK FOR THE LIGHTS
CHECK FOR THE CABLE
CHECK FOR THE PHYSICAL SIGNAL
PUT THE MONTIOR ON A DIFFERENT COMPUTER AND CHECK
CONNECT THE COMPUTER WITH A DIFFERENT MONITOR AND CHECK
FLASH A FLASH LIGHT AS A LAST STEP TO SEE A DISPLAY
IF THE ISSUE IS NOT RESLOVED THE MONITOR IS FAULTY..
HAVE A NICE DAY!!!!
Jun 22, 2010 | Gateway FPD1975W 19" LCD Monitor
Computer not communicating a signal to monitor
You can fix that by getting a new graphics card
I'm assuming you have a T3830 emachine.
here's the link to replace video card
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
Mark
Apr 09, 2009 | E-Machines eMachines T3830 PC Desktop
Message: check your PC and signal cable
That Means the Monitor Does Not Detect Your PC..Check The Video Cables And See If they Are Fully Connected
Apr 01, 2009 | Computers & Internet
Samsung 17" Flat Screen PC Monitor
Problem from motherboard side.
- No display from motherbaord circuit (Display IC)
- Try to figure out with PCI Display card or
- Try to connect different monitor or this monitor to different computer to cross check your dignosis
Jun 02, 2008 | Samsung Computers & Internet
E-Machines (308714) Motherboard Logo
460 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
