Question about Canon PIXMA MP780 All-In-One InkJet Printer
Black will not print
In the middle of printing a large document my printer ran out of the 3e black ink cartridge. I replaced it, but when I went to resume printing only gray and the colors printed - no black. I went and bought another new 3e cartridge and replace the other. Yet, still NO black will print. Every other color and every other feature is functioning fine. HELP!!!!
  • movember Nov 07, 2007
    SAME PROBLEM AS ABOVE ALL COLOURS WORK EXCEPT BLACK
  • Sminky Nov 08, 2007
    That was it !!!!! I used Q-tips and some rubbing alcohol on the one printer head and is working perfectly . THANKS !!!!!! Sometimes it really does help to state the obvious.
This may seem obvious but have you tried cleaning and refreshing the print heads? I've had a similar problem with only certain colors and the cleaning seemed to help.
Posted on Nov 08, 2007
The Black ink cartridge (3e) ran out of ink. I removed the cartridge and sent my wife to the store to get a replacement. while she was gone, I had forgotten that the cartridge was missing and tried to...
Many printers require you to print a test page and go through a process to align the new cartridge. If you haven't done this I would suggest this as your first step. This will confirm if the printer is working.
If still no joy, disconnect printer from computer, uninstall it then reinstall it. Can often save hours of messing using this method.
Apr 28, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Will not print in black. will print in color. I
Sounds like a badly clogged nozzle. If you are using aftermarket/refilled cartridges, the changes are the ink is not up to manufacturer specs and has dried and clogged the nozzle. The best way to clear this is to take a new black ink OEM cartridge and run the deep cleaning a number of times (at least 3) to see if the nozzle can be cleared. If you continue to use non-OEM cartridges, I would keep a set of OEM cartridges around for nozzle clearing purposes. Also, take the aftermarket ink cartridges back to the vendor and either get an upgraded cartridge or refund.
Let me know if this corrects the problem. Thanks.
Mar 18, 2010 | Canon PIXMA MP780 All-In-One InkJet...
IP4000 - How can I force the printer to use the large black (6) ink cartridge?
Do you mean the large black ink as in the 3e vs. the 6? If so, the large black, 3e, is a pigment based ink and the printer should only use it when print text and black and white things. The 6 black is a dye based ink and the printer should only use it when printing photos.
Jan 14, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Large black ink cartridge won't print
please send me your printer show any signal
Jul 22, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Ran out of color ink on cnnon mx310 ... want to
If when you attempt to print only with the black cartridge installed but it won't print, then this specific printer requires that color ink also be installed. Typical with most inkjets.
Jul 07, 2009 | Canon MX310 Office All-In-One Printer
Won't print black ink 3E
I got a paper jam while printing.Know my brother mfc-290 will not print black
Apr 25, 2009 | Office Equipment & Supplies
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
3e Black cartridge won't print
I'm not an expert but I go through a lot of ink.. I have found that even with new ink some of the tanks of ink aren't any good especially with compatible which i buy a lot of because it's a lot cheaper (ebay). With that ink I have gone through 10 cartridges in a row before finding one that worked correctly again (I mean out of 100+ cartridges hitting a run of 10 that where bad but the rest good.)
Also, a tech for epson once told me to hit deep clean 7 times in a row before a head check to clean their nozzles.. That has helped with my printer and at Fry's electronics, they have a cleaning solvent in kit, haven't tried it, but i have run alcohol through mine but I'm told that is very ******* the print head (dissolves the glue).
Hope that helped..
Apr 03, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
I have a Canon Pixma IP 5000 inkjet printer and am using Mac OS 10.3.9. It has 5 ink cartridges: 2 black (3e and 6) and one each yellow, magenta and cyan. I use it all day every day. After printing...
Thanks for getting back to me.
Sorry this ain't a solution but it seems to be the only cash-free way to contact you. No problem not solved - though I have tried everything. Dismantled the printer; washed, dried and replaced the waste ink pads; washed the print head; blew compressed air through the print-head sponge; replaced the cartridge 3 times; printed hundreds of test prints. I can't think of anything else to do and so I think the only solution is to replace the printhead (probably not even available) or replace the printer. The latter is looking most likely.
Feb 10, 2008 | Computers & Internet
Canon PIXMA MP780 All-In-One InkJet Printer Logo
231 people viewed this question
old marine
old marine
