Question about Polaris Pb4 - 60 Booster Pump
Pump comes on for about a minute...then shuts off..
I have a brand new Polaris booster pump,,,,When I turn it on, it only runs for about a minute...then stops....feels very hot but does not trip breaker....any thoughts as to what might be wrong?
  • kenstickercr Jun 28, 2009
    It does pump water....But then stops. It is not a self priming pump. I have the suction end hooked into the discharge end of the pool pump.
    Genius:
  • 1,114 Answers
Has this pump worked at all -pumped water?
When it's running for about a minute, is it pumping water?
Is this a self priming pump or do you need to prime it?
Posted on Jun 28, 2009
  • Joel Friedenberg Jun 28, 2009
    There are only two things I can think of-
    - The pump may be air-bound and has to be primed and purged. There should be a small plug on top of the pump. Loosen the plug to allow water to come out, and then turn on the pool pump. Let the water flow, and then tighten the plug. This procedure should purge the air. Once this is done, and the system is up and running, you should not have to prime it again. Air pockets have this property of compressing and not moving, as in the case of auto brake systems.
    - The other thought is that the pump is defective; probably not the case, since it's brand new.
    Hope this works for you.
  • Colleen Johnson Aug 04, 2012
    thank you. I will try
Pb4 booster pump is trying to engage. It has a humming noise every 10 to 15 minutes but will not engage
turn off try spinning the back shaft of motor then try if still doesn't work need new pump or motor
Sep 01, 2013 | Polaris Pb4 - 60 Booster Pump
Polaris Booster Pump Brand New keeps shutting off
if wired 120 check side of motor rewire for low voltage
Jul 22, 2013 | Polaris Pb4 - 60 Booster Pump
PB4-60 Overheating
if it shuts down then it most likely is a bad motor. If the voltage is properly wired to the motor then the motor is bad. Sometimes new items turn out to be bad out of the box.
Rod
US Parts Center
Jun 25, 2013 | Polaris Pb4 - 60 Booster Pump
Polaris Booster Pump PB4-60 Overheating
see side of motor make sure wiring correct if ok maybe you got a bad one
Aug 29, 2012 | Polaris Pb4 - 60 Booster Pump
Did rabbit break my polaris pb4-60 booster pump?
coincidence motor overheating replace motor or pump
Jul 20, 2012 | Polaris Pb4 - 60 Booster Pump
New polaris pb4-60 booster pump shuts off when polaris recycles, why?
sounds like weak motor the back pressure is overheating the motor replace
Jul 14, 2012 | Polaris Pb460 Polaris Booster Pump...
My brand new Polaris 380 booster pump is noisy. What do I do?
Thank you for posting your question here on Fixya.com.
It is likely due to cavitation in the booster pump impeller. The easiest way to correct the issue is to slowly close a throttling valve on the booster discharge. If there is not one present install a ball or gate valve near the pump discharge line and slowly close it with everything running until the noise stops. Generally speaking closing the valve about a quarter of the way seems to be when most pumps run quietly but the setting is unique to each installation.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
May 14, 2011 | Polaris 380: Polaris Booster Pump
Polaris booster pump runs for minute but quits. Tries to restart
The motors are usually dual voltage and factory connected for 230V. Are you sure it is properly wired and set for the correct incoming line voltage?
Aug 24, 2009 | Polaris Pb4 - 60 Booster Pump
Polaris booster pump overheats and trips the breaker
The motor may be repairable. Check with local electric motor repair shops in your area. The motor may need to be replaced though and if so, we sell it at www.arrowmotor.net
May 29, 2009 | Polaris Pb4 - 60 Booster Pump
Polaris Pb4 - 60 Booster Pump Logo
1,145 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
