Thermostat blank, system not operating reset breaker, worked for a bit, then quit again
  • 146 Answers
You have a short ether in the force air unite or the condenser you can usually tell buy what breaker flips. and there is where you start look for a short
Posted on Jun 28, 2009
My Pentair easy touch control panel quit working. I power it down with the breaker power it back up and the screen comes on for a bit and I can even turn the filter on but then the screen goes blank and...
I would call the Pentair technical support at 800-693-0971 number and they should be able help determine what to do next.
Pease let me know how this works out. Thank you.
Aug 31, 2011 | Pentair Easy Touch Indoor Control Panel...
I have a Rheemglas 250 litre electric hot water system. It seems to have stopped working. Is there anything I can try to get it working again? Otherwise I'll need a technician but hoping it's...
Make sure you have power to unit. Check the breaker in your breaker panel and look around unit for a timer or disconnect that may be having problems. I don't know if you are electrically inclined so if you are scared to take off front panel, don't do so. If you believe your breakers and/or any disconnects etc., are on and working, you can remove the screws holding the inspection panel on and press the reset button on the thermostat. There may be insulation covering the thermostat. The thermostat should have a plastic cover on it shielding the live wires while making it possible to press the reset switch. Again, if you are electrically inclined, you can check for power at the thermostat. These are the simple things you can check. If you reset the button, within about 3 to 5 minutes, you should here noise from inside the unit if it is working.
Jun 05, 2011 | Rheem 81VP6S/430126 Water Heater
On the water heater the circuit breaker was tripped. Reset and heater started working ok. Main service breaker was still on/ possible reasons for this problem.
Circuit breakers for water heaters generally operate at their maximum current. Once in a while a circuit breaker will trip for no apparent reason. The other reason may be a fault with the element or the thermostat. If this is the case it will generally happen again. If it does the element and thermostat need to be tested. If there is a fault the c/b on the HWS should always trip before the one at the switchboard providing that they are the same rating.
Feb 24, 2011 | RELIANCE ELECTRIC WATER HEATER
My heater are has no heat and i have the problem that i can't swich on any heat so please give any help you can able.
there could be alot of things going on is this gas or electric heat first off? do you have a heat pump system does the outside unit normally run during the winter if so then probley a heat pump...
does the fan come on when you put the thermostat in "fan" position if so ok we got power still to unit... try resetting the breaker first to the heater at electric panel the one marked heat or furnace if not marked go to indoor unit see if it has a plug or breaker on it reset there. try operation again watch it and see what it does if a gas unit there is a series of operation whee does it fail most gas units have a fault light inside you can look at and will help...if electric go back after resetting and try again if nothing remove cover to thermostat do you have good batteries in it if so the take a small wire and jump the terminals "r" and "w" ehich is power adn heat see if it works that way... if nothing then you got an issue with the indoor unit most likely and will need more explanation if it does work then thermostat is either programmed wrong or faulty.. make sure you have it set on hold rather that program... repost if you need more help
Jan 06, 2011 | Honeywell CT3200 5-2 Day Electronic...
Thermostat resets itself to 85 degrees a couple hours after I set it to 74 degrees
To manually operate the thermostat set the system to cool and fan to auto then press the HOLD button one time then release, you will see the hold word on the screen after that up the UP or DOWN arrows is setting the desired temperature.
Jul 22, 2010 | White Rodgers White-Rodgers 1F85RF-275...
A/C not turning on - Digital screen is blank
Your honeywell should have battery back up but the primary power for this is a 24 volt transformer located in the air handler probably in your attic. All these controls run on 24 volts
Jul 11, 2009 | Honeywell Programmable Thermostat Heater
Furnace is not working, digital thermostat does not register
sounds as if your low voltage transformer might have bit the bullet will need replacing all of the devices you mention are powered by this one low voltage t-stat
Dec 09, 2008 | Bryant 462AJC021BA Air Conditioner
Lost operating system
Try an Hard Reset : Press the reset button and hold the Power button. Hard Reset erases everything on the Palm and reinstall PalmOS
Jun 26, 2008 | Palm Tungsten C Handheld
Honeywell T8000C Thermostat Problem
If you have a volt meter, remove the thermostat off from the mounting plate and check for 24 volts AC across red (R) and White (W). Then check across Red and Yellow (Y). If you do not find any voltage, follow wire as much as you can all the way back to the air handler that is connected to it. Look inside and see if there is a small Auto (car) type of fuse in the wiring harness. Test and replace if necessary. Jump out the Red and Green terminals on the air handler and replace the door. See if the blower turns on. If so, you have narrowed it to the wiring to the thermostat. If not, you have a power problem and will need a technician.
Sep 28, 2007 | Heating & Cooling
Heating & Cooling Logo
173 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
