Question about GE AJCQ08ACB Air Conditioner
AEW10AJS1 a\c digital panel keeps climbing to its
AEW10AJS1 ac digital panel keeps climbing to its max of 86 degrees. i cannot operate any of the buttons except the temp down. i have to hold it down because the unit keeps climbing back up to 86. its a losing battle!
I have the same problem, 4 little kids in the house trying to keep them cool. Did you find out how to fix this?
thanks
Ian
Posted on Jul 30, 2009
  • SouthrnStyle Jun 09, 2011
    Mine is doing the same thing. Does anyone know why the a/c is ramping up to 86 deg between the hours of 2: AM and 4:AM?
Low Temperature
250 is not low, it is just about to boil over, coolant boils at 260 in a closed system, water boils at 120.Your car should not exceed 200, 220 max. Or just 100 degrees over the outside temp, like 87 degrees out, your car should be running at 187. Until you stop at a light and it idles for a minute, then it will climb.
Aug 04, 2012 | Cars & Trucks
Just need to know if the temperature should be higher to keep the room cool or lower...mine is in F and goes from 68 to 86 degrees F...Please advise if it should be lower at 68 degrees to keep the room at...
Lower temperature will keep the room cooler. For efficiency sake, lower the temperature gradually to
68 degrees.
Hope this helped you. Thanks for choosing FixYa.
Jul 21, 2011 | Sunbeam Heating & Cooling
AEW10AJS1 ac digital panel keeps climbing to its max of 86 degrees. i cannot operate any of the buttons except the temp down. i have to hold it down because the unit keeps climbing back up to 86. its a...
Greetings!
I have the same model. Symptoms: Unit works great, Expect..when operating the menu buttons, they do don work properly. Example, pressing the up temp works great, but when pressing the lower temp button, the temp will go to 86 degrees F.
The problem is the control board. I took it out, clean it well with soapy water, rinsed with clean water, blew dry, took a tooth brush with alcohol and rebrushed again, rinsed with water, blew dry with compressed air.
Upon close inspection with a magnifying class, you can see the top of the board connections, did not solder well when manufactured. This is a hint... My problem was with R32 a 0804 resistor not being soldered properly during manufacture.
I replaced the resistor an all is well.
All the buttons have ground at the bottom of the switches, while the top is 5v volts dc with a standard meter, but I do believe all the keys are multiplexed, as seen when pressing one of the buttons, the display may show a different function changing.
Thus the most likely problem, will be with one of the 10K ohm resistors associated with one or more of the buttons. The resister is black in color with 103 written on the top, and is a 0804 size.
Hope this helps.
PS I have found no replacement of the control board, so I just fixed mine. If you have electronics friend, he/she might like the challenge.
Jul 15, 2011 | GE AJCQ08ACB Air Conditioner
The air conditioning on my 2007 hyundai getz takes a very long time to cool the car down, operating conditions, The AC is on, the system on recycle, the fan speed on maximum, using a digital thermometer in...
first I would have someone recover the R134a from the system then add dye and recharge to the correct level R134a and check vent temp levels this system would work half way normal if R134a is low by .4 oz's but would take a long time to cool the car down
Mar 26, 2017 | Hyundai Accent Cars & Trucks
The dealership replaced my AC evaporator component because the hose had been draining water on the passenger side floor board. Since replacing the system, my AC doesn't blow as cold (on normal setting),...
Make sure you have it on recirculate. Need to know how much freon is in the car with a gauge. If the outside temp is above 96 degrees you must run on max to get the car cool. Do you have tint on your windows. Window Tint keeps your car 33% cooler and you will not have to run your ac on max.
Jul 10, 2009 | 2006 Nissan Armada
Air conditioner model AEW10AJS1 wiring problem.
That is the temp prob it belongs in the air flow, its only connected on one end
Mar 29, 2009 | GE AJCQ08ACB Air Conditioner
GE AJCQ08ACB Air Conditioner Logo
617 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
