Question about Kenmore Kitchen Ranges
75585891 gas range will not preheat oven. Everything seems to work. but oven will not show that it is preheated.
  • 999 Answers
If I understand it is working just no lighting the preheat lamp? May just be a burned out lamp. Connect a jumper from any of the other indicators to the preheat. If it lights there is a problem in the oven control/thermostat. If it does not light when the other lamp you connected to it lights, it is the lamp.
Eric
Posted on Jun 28, 2009
SOURCE:
Orange glow after oven burners were lit, thenflames in oven
Sounds like maybe some grease or something had been spilld and then caught on fire while you preheated the oven
Jan 07, 2018 | Kitchen Ranges
Oven preheat times
It gas not electric. There is NO hidden element. It a bad sensor.
Mar 08, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
It take a long time for the oven to preheat and some time you can smell gas during the preheating
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 08, 2011 | Amana RanARG7302 Gas Kitchen Range
KitchenAid gas range superba not reaching/registering right temp.
Always preheat your oven and let it cycle at least 2 times. Your unit may show 350 but the manufactures know that it is not 350. When it registers preheated, it really means that it is at an acceptable temperature to start cooking. If you think that it may not be calibrated correctly, your owner's manual will have instructions on how to recalibrate your oven. You will be able to raise or lower the temperature by + 25 degrees or - 25 degrees. As far as the gas smell, you will from time to time smell a gas smell with a gas oven especially if you are right at it when it ignites. If you are smelling gas when it is not in use then you should be extremely concerned.
Mar 14, 2009 | KitchenAid KGST307 Gas Kitchen Range
Magic chef gas range; oven takes about an hour or so to preheat.
most common issue, and it sounds like what your experiencing here, is a faulty ignitor, replace the bake ignitor ( located under teh oven floor, attached to the burner bar)
Feb 27, 2009 | Magic Chef CGR3742 Gas Kitchen Range
Whirlpool gs475lems range oven problems
my oven was converted to LP gas we move overseas.It worked for about a year then all of a sudden the oven stopped working. The burners work perfectly but the oven just keeps clicking after preheat is finished. We replaced the upper electronics board so what could it be now
Dec 02, 2007 | Whirlpool GS475LEKS Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range
try changing the oven sensor its in the oven looks like a small rod coming out you need to remove 2 phillip screws the take it out
Jun 08, 2007 | Hotpoint RGB745 Gas Kitchen Range
Kitchen Ranges Logo
346 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
