Question about Canon PIXMA MP830 All-In-One InkJet Printer
I have a Canon MP830 inkjet printer, about 2 years ole. When I print there is a thick black line on the back of the pages. I tried using the "Bottom Plate Cleaning" procedure three times and that helps a little but as soon as I print the problem returned. I called Canon and after having me do bottom plate cleaning they said I should either have it serviced or buy a new one. Is this something I can fix myself, and if so how? If not, will it be expensive to have it repaired?
  • ffscambridge Jun 28, 2009
    How do I take it apart?
    Sergeant:
  • 326 Answers
This problem is occured due to the over flow of the waste ink collector. in the printer replace it with new one u r problem will be solved
Posted on Jun 28, 2009
  • 250 Answers
Anyway the bottom of your printer could be getting full of ink. Or you may have had a older ink cart leak one time and now the ink is on the lower rollers. There are some techniques that are useful in cleaning rollers but the best way is to take the printer apart and get down to the problem and clean it up. While you are down there you need to clean out all the waste ink that you have dumped over years.
try this,it gotta work-if not call Canon and do as they say
-sultan
Getting a black line on the back of the pages.
I am also getting a black line on the back of everything I print. I have gone through all the steps to clean the ink heads. I even had, (by chance) more black ink in the house and tried replacing the cartridges.
The black line came out bolder. This problem is a expensive because it uses up ink, and doubles the printing.
Oct 23, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I keep getting a black line on the back of most printed pages
Hi there
This is a leak from the ink or it is your waste ink pads full, you will have to clean all the inside out, the ink getting on to the rollers.
All the best Pineworks
Apr 26, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Leaking Ink Cartridge
You need a shop to clean the extra ink that's coming up on the rollers and install a mylar strip to prevent that in the future. It's the waste ink being forced up thru the exit rollers and getting on the prints.
Sep 10, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Thick black line printing on the back of every page
your printer needs to be serviced and check printer alingnment
May 21, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Getting a black line on the back of printed pages Obviously the ink IS leaking. Now what?
Go to the print menu and look for "Self- Clean" or  "Nozzle  Cleaner". Select it, and the printer should fix whatever problems you are having.  The printer will use up some paper doing this, so put in junk or used paper. Repeat until the page comes out clean. Hope this helps.
Apr 25, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Printer is putting a 1/2 dark black line on the back of the pages
dear friend
looks like problem related with refilled cartridges
are you using refilled cartridges??
if yes then you have to check whether they are leaking or not,
if they are leaking, you have to maintain cleaning level
thats all you can do
thanks
Apr 10, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830 printing with interlacing shades of black
your printer cartridge or head unit ink channel (some of color or black ink channel) constipated, you may try:
1) if your ink cartridge is not new, take out the cartridge put the bottom surface touch cleaner liquid(special for ink printer) or water for 1 hr (you can see ink spread water), then set back and test. refill enough ink maybe necessary.
2) still trouble, you need clean print head ink channel to do same thing above, if your print head is separated from the cartridge.
Feb 05, 2009 | Canon PIXMA MP830 All-In-One InkJet...
MP830 prints a black stripe down the back of the paper
the waste ink pads are full ..when the black line appears it is an indicator that the waste ink pads are full it is usualy because the printer has reached its life expectancy the solution is either buy a new printer or pay a tech about 170 dollars to repair it
Jan 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Printing only in black
When you get the printer option page click on properties, in the main page there select gray scale printing. Click OK to get back to the print page and ok there to print.
Dec 03, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Printing
when you have this problem of your printer disconnect it remove ink catridge colector and clean .
Feb 29, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
old marine
old marine
