Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Frost build up in freezer (ice maker section)
I do have a ge profile side by side. I have a problem with frost/ice build up around the ice maker especially at the bottom of the ice maker box.
    Novelist:
  • 145 Answers
Your ice maker is overflowing and asking for to mush water to make the ice, you may have a real hi water pressure on your water supply
the is a easy way to adjust that but you are going to have to take
your ice maker out
then using a flat head screw driver remove the white square cover
you will see a gear and a adjustment screw and a lever like this
( - I + )
turn the screw to the minus sing a quarter way and install the ice maker back up.
Or a easier way is just closing the water valve before your fridge a little so it wont have so mush pressure and will not fill your ice maker so fast.
the ice maker feel up buy time not buy water level.
Posted on Jun 28, 2009
I have a GE Profile side by side refrigerator. It has not been cooling very well, it stays between 38-41 degrees. also the ice maker doesn't make a lot of ice and the cubes are smaller in size.
Ice maker want work if freezer bus not around 0F. Are fans running? Is condenser coils clean? Is there any frost build up on inside back freezer wall?
Nov 06, 2017 | GE Refrigerators
I have a GE Profile pfss6pkx. The ice maker has stopped making ice and makes a clicking sound. Do I need a new ice maker or is there something I should try first?
Hello Dave;
My name is Peter. I am a retired field service refrigeration technician.
1.) Press the test button while hold the bottom freeze light switch in. The light switch is in the front top part of the freezer. Observe what happens.
2.) Your ice maker will not work if unless you reach temperature. look in the back of your freezer wall. Is there frost or ice build up?
3.) Do you have ice on the bottom of your freezer section? Then you have a frozen drain, ice built up and can not reach desired temperature.
4.0 You have a non repairable ice maker. Sometime these flex types become jammed with a ice cube in the mold. Check this out.
5.) Your ice maker has a sensor. This may be bad, but I do not think this is the problem.
Get back to me on what you find from the above.
Jan 16, 2015 | GE Profile PFSS6PKX Bottom Freezer French...
GE Profile refrigerator Model # PFSF6PKXCWW motor is noticeably louder
if you are talking about the motor in the freezer the ice build up could be causing the fan to beat against the ice... could be a defrost cycle problem,,,, if ice is building up on rear freezer wall you have a defrost cycle problem and the ice is forminf around fan causing fan blades to hit the ice (loud noise)
Aug 28, 2014 | Refrigerators
Side by Side GE Refrigerator freezer will not defrost which allows frost/ice to build up. I have cleaned all the areas behind the unit as well as under the unit. After I manuely defrost the freezer it...
The defrost circuit has failed in your fridge. Typical failure is with the defrost heating element. To troubleshoot, you need to remove the remove the contents of your freezer section and remove the freezer back panel to access the evaporator coil. You will need a hair dryer to melt the ice on coil. The heating element is attached to the coil. Use a meter to confirm that the element is bad. Hope this helps you.
Nov 08, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Oct 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
No water to ice maker, but water to despenser.
check water valve or ice maker or check for frost build up in freezer
Mar 10, 2009 | GE Profile PSI23NCR Side by Side...
GE Profile PSC23MGNA too cold on frig side & icing up on freezer side
Check your thermostat if it is still functioning well.
May 02, 2017 | Refrigerators
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refridgerator freezer GE
Frost is due to outside air leaking into unit. Check on back wall to see if hole for ice maker fill tube is still plugged. If not and you have no ice maker cover hole with tape. Also look for water or ice build up in bottom of freezer or ref. sections. May have a plugged drain. Let me know what you find.
Nov 11, 2007 | Refrigerators
Refrigerators Logo
1,313 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
