POWER LIGHT FLASHES ONE SHORT AND ONE LONG FLASH.
What is the problem? THE PROBLEM IS THAT ONE OF THE LED's STRIPS IS BAD!
SHARP AQUOS LC60LE810UN RESET INSTRUCTIONS
1)Plug in TV to electric current First then wait until LED start flashing.
2)Press Volume DOWN HOLD ALL three buttons until LED stops flashing and then release.
·This will reset the TV in order to fix the problem.
·THE FIX IS TO REPLACE ONE OF THE LED's. You need to open the back of the TV and you will also need to remove the front cover and panel to get to the LEDs. The TV will need to be placed facedown and on the backside. This is a 2 person job to turn the TV on its sides. Be careful with the white computer connectors (wide white strip) at the base of the TV where the TV stand sits. You will need to disconnect this in order to get to the LED's.
Once you have the LED's exposed, you will need to unplug one by one by placing the new strip next to it until the unit turns on. You will have to use the RESET procedure above if the Power lite flashes. The Power lite MUST BE ON SOLID - no blinking in order to test the strips. The LED's will flash, but still one of them will be burned. Even if you stare and all the strip light-up, you will still need to check one-by-one!
Once the TV lights up, your face will also light up with joy! Put everything back together and you are set. If you need the complete instructions which come from Sharp as to how to disassemble the unit, please send me an e-mail to
[email protected]. Please note I don't check this address daily, so a few days wait may take for you to receive the instructions.
Where can you buy the LED's - try searching
Sharp LCD/LED parts web site -
Copy this link:
http://www.encompassparts.com/item/8459814/SHARP/RUNTK4459TPZZ/LEDPWBUNIT(LC-60LE810UN),_X4
Yahoo.com or Google.com for resellers.
SHARP AQUOS LC60LE810UN LCD STRIP INFORMATION
LONG STRIP (49 LED's)
FRONT SIDE BACK SIDE RL 94v-0
E329419
1029
LFa
Sn-Ag-Cu
Ps-1
K4458TP
4458ZZ
0921FM
104863
ee03A
SHORT STRIP (30 LED's)
RL 94v-0
E329419
1025 LFa
Sn-Ag-Cu
Ps-1
K4459TP
4459ZZ
0714FM
302213
Mm05A
