Question about Philips SA5125/37 MP3 Player
Phillips go gear will not turn off and the screen is blank. How can I fix?
    Novelist:
  • 166 Answers
Are you talking about the computer go gear or the mp3 player.if it is the computer press ctrl+alt+del and
bring up the taskmanager and look for you mp3 model file name in the proccess section and also
check if there is a file in the startup folder.you can try to uninstall the program.for the screen make sure
that the hold is off and that the battery has enough juice.if all of that is clear you can try to format it wich
restores the factory settings.you will lose all of the music but i can tell you a way to get free music and videos
just email me.if the format doesn't work(if you don't know how to format ask me in a email)your screen
might be bad.feel free to email any question or other problems about other devices and machines.at
gamecrazy944@yahoo.com
Posted on Jun 28, 2009
White screen appears at start up
A laptop suffering from a blank screen can fully impede all computer productivity, but fortunately there are a number of common problems that you can swiftly troubleshoot for in your own home, even if you have no prior computer troubleshooting experience. The power adapter, monitor brightness settings, inverter cable or otherwise may all be possible causes for your screen's problems, but all can be repaired with only a Phillips screwdriver and a potential replacement screen.
Check the power adapter of the laptop and ensure that it is still properly plugged into the back of the machine. Check the monitor brightness settings for your screen. There are dedicated monitor brightness keys on the keyboard, typically located just above the numeric keys. If the brightness has accidentally been turned all the way down, this will result in a screen that appears completely dark or blank. Turn the brightness up. Open up your display to check on the backlight's functioning. Remove the screws that run around the bezel, or perimeter, of your laptop's screen. Use a Phillips screwdriver. Pull the bezel carefully off the display, starting at one corner and working around the bezel until it is completely detached. Find the inverter board, which will now be visible with the bezel removed. It lies at the bottom of the screen. A black inverter cable connects into this board via a connector that lies atop the board. This cable is instrumental to the operation of the screen's backlight, so if the cable has come loose, then the backlight will fail to function and the screen will be dark and blank. Reconnect the inverter cable into the connector by inserting it and then snapping the connector down into the flat, "locked" position, which will put it parallel to the inverter board. Consider full replacement of the screen if the inverter cable fix does not restore the screen's proper operating state. Ensure the inverter cable is disconnected, then remove the metal brackets on either side of the screen. These brackets are held in place with two screws that must be removed with your Phillips screwdriver. Pull the laptop's screen slowly up and out. Slide in the replacement screen, then restore the screen brackets and reconnect the inverter cable. Slide the bezel back into place over the display and replace the bezel screws. Hope this helps
b>
Dec 10, 2012 | Computers & Internet
Phillips 47pfl3603d blank screen with sound
if the Tv have back light the problem is t-con if not the problem is inverter
Jun 06, 2012 | Philips 47PFL3603D LCD TV
I have a phillips go gear MP3 player and when i turn it on it freezes only the words www.phillips/welcome.com screens shows. how to i fix this?
Hello
Your GoGear is freezing because there is an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
If the GoGear freezes after uploading a file to the device or if one song or sound file freezes the device each time you play it, the file is likely corrupt and needs to be removed from the GoGear. Connect the GoGear to a computer and delete the file from the device.
Sep 02, 2010 | Philips SA3025/37 Flash MP3 Player
My Phillips GoGear 16GB won't come on.
I have a phillips go gear 8 MGB.numbers on inside of mp3 is 4901v3.68 and sstm12 080929 . I have tried reset & charging it but nothing will make it turn on. I spent alot of money on this thing for it to work a short period of time.What can I do???????????
Apr 14, 2010 | Philips GOGEAR SA6045 MP3 Player
When I turn it on the screen stays blank and there
this a defective power supply, normaly the HV circuit is burned, needs to be repaired. send to repair shop
Jan 29, 2010 | Philips Magnavox 9P6034C 60" Rear...
Phillips Go Gear MP3 Player Is Dead
have you tried resetting the player and reinstalling the software
Aug 24, 2009 | Audio Players & Recorders
Screen is blank, can't turn odff
Sir,
Try taking the battery out and put it back in, all you need is a small phillips screw driver. Don't worry, nothing will fall out or break, it is set up to be able to do this.
If that don't work, I suggest you get in touch with manufacturer.
Thanks
Good Luck
Aug 17, 2009 | SanDisk Sansa e260 MP3 Player
How do i fix my go gear phillips mp3 player..it froze
Steps to Repair:
  1. Open the Phillips SA-31xx device manager.
  2. Connect the player to the computer while pressing and holding the on/off button of the device (the inner round button.image_thumb%5b1%5d.png). Windows will tell you that a USB device is connected in the repair mode.
  3. The device's screen will look like:
  1. On the device manager, click on the Repair tab.
  2. On Repair tab, click the Repair button. It will show the message that the device is repaired. The device will also show that it's being repaired.
3. After the device has been repaired, below message will be shown.
4. BEWARE ALL DATA WILL BE LOST from the Phillips Go Gear SA-31xx Media Player without any warning.
Aug 19, 2008 | Audio Players & Recorders
Philips SA5125/37 MP3 Player Logo
722 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
