Question about Jenn-Air JCB2280HES Side by Side Refrigerator
I have a Kitchen Aid refridgerator. My freezer
I have a Kitchen Aid refridgerator. My freezer seems to be working fine but my fridge is not cold at all. What's wrong? Please Help!
  • alfred448 May 16, 2011
    i replaced the thermostat and its still freezing over
    President:
  • 1,136 Answers
Hi, Check the rear inside panel of the freezer section and see if there is a frost build up. Also check and make sure the evaporator fan motor in the freezer is running.
If there is a frost build up, remove the rear indise panel and check the defrost heater and bi-metal switch for continuity. The bi-metal switch located on the top of the evaporator has to be tested while it is still cold.
If either of them show an open circuit, it will need replaced. If both of these parts show ok, you will need to replace the defrost timer/board.
Please let me know what you find and if I can assist you further.
Vic
Posted on Jun 28, 2009
My freezer seems to work fine on the AC but the fridge will not get cool any idea what the problem might be Dometic model RM2652
Move your temperature control (slider) down. If it is close to the freezer it does not get the signal that it is warmer.
Sep 18, 2014 | Dometic RM2652 Refrigerator
Kitchen Aid bottom freezer KBRS22KK is frosting up
Replace the "defrost thermostat" located on the coils in the freezer. Here is the part to order.
Dec 01, 2012 | KitchenAid KBRP20EMSS Bottom Freezer...
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
The freezer seems to be working fine but refridgerator not cooling at all.
the damper vent door between the freezer and fridge is either frozen shut or jammed shut so cold air from freezer cant get to the fridge part
Jun 12, 2011 | Maytag Refrigerators
Fridge isn't cold
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
Freezer has frost building and the refridgerator is too warm.
make sure the evaporator fan is working, open door and push switch in if fan works make sure opening from freezer to fridge is not blocked. if door was removed make sure light in fridge is shuting off if temp in fridge is in the 50 degree range your light switch is not being deactivated check spacers between door and hinge . sometimes when door is removed a spacer will fall on floor and light switch is not hitting door
Jan 26, 2009 | KitchenAid KTRC22EL Top Freezer...
Kitchen Aid Fridge problem
ok first the freezer does all the cooling for the whole unit and in order for it to cool properly the freezer needs to be a certain temp it should be around -10 -6 if its not reaching that temp it will still freeze and apper to be working right also check to hear if the freezer fan is running as it pulls air from the fridge and cools it then blowes it back look in the freezer on the back wall toward the bottom see if frost is building also in the refridgerator section on the left hand side of the cabnit is a return vent make sure its not blocked and see what the thermostat in the freezer is and let me know we need to know things like this to help narrow the promblems and people dont reply to the questions so we cant answer appliance repair is a skill
Jul 13, 2008 | Refrigerators
Frigidaire frige not getting cold but freezer working
my refridgerator is not getting cold but the freezer seems to be working fine. can anybody please give me some advice on what this could be. We had a new defrost element put in a few weeks ago and we now have moved house so fridge is cool but not really cold enough model E402B any help would be appreciated.
thanks pam
Apr 29, 2008 | Refrigerators
Jenn-Air JCB2280HES Side by Side Refrigerator Logo
204 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
