Question about Garden
I have a 1988 318 John Deere garden tractor and it revs really high when i turn the throttle up and revs comes back down after a few seconds. But overall,, full throttle engine is over-revving, can only run have throttle. Sometimes surges up and down when cutting grass also. Was surging up and down before the over-revving of the engine started. Tried removing carb and blew out with air, didn't help, any ideas?
    Sniper:
  • 197 Answers
If your rpm's are high/sluggish and slow reacting its do to your govenor inside your engine needing to be fixed.There is a plastic housing with fingers on it that will break and allowing metal balls to free float.Another problem with them is that the washer under the retaining ring will fail or loose tolerance,also located inside engine.
Posted on Nov 16, 2009
    Scholar:
  • 48 Answers
For some reason the throttle linkage is binding or is gummed up preventing it's free movement which also prevents it from responding to the governor properly resulting in your overspeed incidents.
You could try spraying the outside of the carburator with carburetor cleaner from a parts store like NAPA or checker auto but I like using Brake cleaner for the same purpose as it's a tad more powerful in disolving the nasty stuff away and it does absolutely dry up totally. Both of these products come in a pressureized spray paint type of can and with nozzles so you can get right onto the gummy parts and clean them out. Move the throttle open and closed with your finger as you clean the carburetor to ensure that the throttle no longer sticks open or shut.
Posted on Jun 28, 2009
John deere z225
Either timing is off or you may have turn key off with engine hot and running in high speed. Always return engine to idle for at least 30-45 seconds before turning engine off.
Jul 19, 2014 | John Deere EZtrak Z225 Zero-Turn Riding...
I used my John Deere L110 Lawn Tractor all day yesterday. Turned the engine off, it popped. Then went to start it today and it just pops, seems like the timing is off.
throttle down your engine before turning it off . this reduces amount of fuel going into a hot engine ,just a few seconds before switching key off , should stop back firing issues.
Sep 09, 2013 | John Deere L100 Series
Every time I pull the throttle, or pull down any I have to pull the choke out for a few seconds or it will sputter and die. EVERY TIME
Sounds like its a little lean. Back out the high speed adjustment(bottom of bowl)about half turn, that should do it. If its blowing black smoke turn it in a little.
Dec 20, 2010 | John Deere 3010,3020 Tractor Basic...
My john deere rideing mower idles up and down at
The motor has a governor that controls its speed, and if one of the pivoting parts or linkages is sticking this would happen. Look for the throttle linkage on the engine carburetor (move your throttle up and down, watch what moves). The governor will be a second linkage attached to the throttle arm. Squirt some WD-40 on any rotating parts and make sure a foreign object isn't stuck in there. It could also be the part of the governor that's internal to the engine -- harder to get at, but not expensive to fix.
Jul 01, 2010 | John Deere Garden
My 1979 111 john deere lawn tractor deck blades shut off
If it has a clutch, that would be the problem. An electric clutch will kick on and off when it is hot if it is bad.
Sep 27, 2009 | John Deere 420,1020,2010,2020,2510,2520...
I have an Older John Deere riding lawnmower with a
ck anti backfire selanoid on carb see if its moving and if it is then ck for 12 volts
Jun 07, 2009 | Garden
Garden Logo
698 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
