Question about Smart Pool Inc Dolphin Diagnostic Automatic Pool Cleaner Ne250
DOLPHIN DIAGNOSTIC AUTOMATIC POOL CLEANER STARTS AND STOPS
POOL cleaner starts up and runs normally for afew minutes then just stops. Climbs walls no problem, cord twists every which way no problem so I dont think theres a break in the line. Had it 9yrs this is the 1st time theres been an issue
There may be moisture building up inside the motor housing. Try to Open it. http://www.i-love-my-aquabot-automatic-pool-cleaner.com/Maytronics-Dolphin-Repair.html
Then make sure no moisture accumulated in the circuits. Mine got the same problem.. after running trouble free for several years it suddenly stop running after the first few minutes..when i opened it a lot of moisture in the circuit. I tot it was toasted. so i took my hair blower and sealed it back and replace the moisture absober (it was soaked).. after first run it would run only the SELF TEST mode.. i tried several method to make it run all the way to the main program.. the solution.. start it and make sure it will not tilt in the first 10 minutes before you let i run sideways to the walls, this makes the program run back to normal.
Posted on Jan 27, 2010
Take off yellow top strainer. Turn fan by hand(Kick Starts the motor) and it will complete the cycle.
Posted on Jul 25, 2009
    President:
  • Smart Master
  • 1,378 Answers
The motors inside the cleaner have a life of about 3000 hours give or take. 9 years is a above average for the life of those motors. You may be able to have it repaired but it is costly.
Try contacting us at www.arrowpools.net for service information or you can contact the US rep, MaytronicsUS, at www.maytronicsus.com
Posted on Jul 05, 2009
Goes to wall and turns itself over. It is clean.
Maytronics-Dolphin pool cleaner, Dolphin Diagnostic ...
? 3:44
www.youtube.com/watch?v=-x8hwghv8BE
Apr 4, 2012 - Uploaded by Swimming Pool Tips, Reviews & How To -MrDgvb1 Maytronics-Dolphin pool cleaner, Dolphin Diagnostic ... Solar Breeze: The Robotic Solar-Powered Pool Cleaner Review: http://youtu.be/jzWfClbOnIc ... Pentair Kreepy Krauly Legend Review, Troubleshooting & Tips:
Aug 08, 2015 | Dolphin Maytronics Diagnostic Robot...
Dolphin diagnostic motor replacement
May be the circuit board - There is an on-line group called Circuit Board Medics who can test and repair the board.
Jun 22, 2012 | Dolphin Maytronics Diagnostic Robot...
Dolphin starts to climb walls and then tips over.
There are several things that could cause this problem with these automatic pool cleaners. Try the solutions below.
1. Your pool cleaner might be too heavy. To correct, empty and wash the filter bag and add floats if necessary.
2. There may be too much algae growth on the walls that is preventing traction. Brush the walls prior to vacuuming if you have excessive algae growth.
3. The water temperature could be too low. Make sure pool water temp is at least 65 degrees.
4. Make sure there is not water inside the handle.
5. Make sure the brushes are not worn. You might have to have them replaced if they are worn.
6. Pool cleaner might be too light. Remove handle floats and attach 8 oz. weight to bottom inlet cover if necessary.
7. Debris could be caught in impeller.
Jul 24, 2010 | Smart Pool Inc Dolphin Diagnostic...
Stops running after about 2 minutes
Question the manufacture about a new circuit board.
The Pool Tech
Jul 10, 2010 | Dolphin Maytronics Diagnostic Robot...
It stops after 30 min. Lays on it's back then starts up again. Has trouble climbing the walls to the very top
There are several problems that could make these automatic pool cleaners fail to climb the walls. The cleaner could be too heavy. Empty and wash the filter bag and add floats if necessary. If there are excessive amounts of algae on the wall, you will need to brush the walls first. The algae can prevent the cleaner from climbing. Make sure that the temp is at least 65 degrees in the pool. Make sure that there is no water in the handle and that the bushes arent worn. If the cleaner is too light, add weights. Make sure there is nothing caught in the impeller.
Jun 25, 2010 | Smart Pool Inc Dolphin Diagnostic...
My dolphin begins to work, then stops. What could
There are several problems that could make these automatic pool cleaners fail to climb the walls. The cleaner could be too heavy. Empty and wash the filter bag and add floats if necessary. Make sure there is no water in the handle and that the brushes arent worn. If the cleaner is too light, add weights. If there are excessive amounts of algae on the wall, you will need to brush the walls first. The algae can prevent the cleaner from climbing. Make sure that the temp is at least 65 degrees in the pool. Make sure there is nothing caught in the impeller.
Jun 14, 2010 | Dolphin Maytronics Advantage
Dolphin Interactive pool cleaner stops running
If the dolphin is falling backward when it meets the water line, there is an easy fix. The automatic pool cleaners often have this problem. The easiest solution is to remove the handle floats and attach an 8 oz weight to the bottom inlet cover.
May 23, 2010 | Smart Pool Inc Dolphin Diagnostic...
The robot only works for about 10 minutes then stops.
For warranty and non-warranty repair service contact us using the dolphin service form at www.arrowpools.net or you can try the manufacturer at www.maytronicsus.com.
Jul 20, 2009 | Smart Pool Inc Dolphin Diagnostic...
Stops after a few feet
It can be in the power supply or the motor pack. You can contact us using the dolphin service form at www.arrowpools.net or try the manufacturer at www.maytronicsus.com.
Jul 16, 2009 | Smart Pool Inc Dolphin Diagnostic...
I have the exact same problem with my unit!
It is probably the motor unit and should still be under warranty if it is less than 2 years old. You can use our Dolphin service form at www.arrowpools.net or contact the manufacturer at www.maytronicsus.com for service information.
Jul 12, 2009 | Smart Pool Inc Dolphin Diagnostic...
Smart Pool Inc Dolphin Diagnostic Automatic Pool Cleaner Ne250 Logo
5,147 people viewed this question
Top Smart Pool & Spa Experts
Thomas Perkins
Thomas Perkins
Robco Water
Robco Water
Bill Boyd
Are you a Smart Pool and Spa Expert? Answer questions, earn points and help others
