I have a trane XL 1600 heat pump pkg unit the coil freezes up the filter is new and the fan is running any ideas
  • Bob Evans Jul 08, 2009
    The unit has a bad expansion valve and is not opening all the way.
Concur, the coolant could be low and it will cause the coils to freeze up. However, other things can this is as well.
I had the exact same problem on my unit. The first couple of times it happened, I would defrost the coils and it would work for 2-3 days. Over the course of a week the blower motor quit working. You could see it trying to start, it would move 1-2" and stop. Experts will tell you the starter capacitor(s) are bad. This is true 95% of the time. The part they leave out is, the starter caps for the variable speed blower motor is a part of the ECM module located on the back of the motor. In some cases, the captivators will show obvious damage and can be replaced by a DIY with a soldering iron and about $10 in parts. In my case, the ECM module had to be replaced, cost $400. The only website I could find that sold Trane parts directly to the public was www.expertappliance.com.
Posted on Aug 22, 2009
  • 432 Answers
The coil will freeze when the system is low on R-22. The system is low because someone never fully charged it and/or it has a leak...
Posted on Jun 28, 2009
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Trane XL 1600, The heat pump when running will dim the lights in the house and at night it will trip the breaker on the "small electric" line. The ac will trip the same breaker but only at...
the breaker may need replaced, I would start there first. I am assuming that it has a dedicated line (meaning only the heat pump is off that circuit), if not then it will need to be wired that way...Good Luck Tim
May 29, 2011 | Heating & Cooling
Coleman Heat Pump Freezes Up
This sounds like an airflow problem. You said you change the filters every 3 weeks or so. Check the filters and the indoor coil to make sure they are clean. Also look at the indoor fan and make sure it is running and running at speed. A fan that isn't running at the rated speed will cause the coil to freeze. A weak capacitor can make the fan run slow. Also make sure the fan blade/wheel is clean. A low refrigerant charge will also cause the unit to freeze. It doesn't matter what you have the thermostat set on because the temperature of the refrigerant is determined by the pressure of the refrigerant and the airflow across the coils. If it freezes up again you can put it in heat mode to melt the ice.
Jun 23, 2010 | Coleman Heating & Cooling
Trane Air Conditioner air handler drips water
are you still having issues with your twg030a140b1? the heatpump that you own should not be having this issue the question is the configuration of the coil in the AHU is it properly installed. I am a distributor for Trane equipment and am wondering if the install tech installed correctly
May 30, 2010 | DeLonghi Trane 5t Rooftop Air Conditioner...
I am renting a house which has a Trane heat pump
If it is a heat pump it may not have enough oomph.
Oct 20, 2009 | Amana PTH123B25AJ Heat Pump Air...
1994 trane furnace fan will not shut off xl 1200
Hello there:
please contact a certified trane dealer i think that you are having a thermostat problem they may be able to assist you on setting the thermostat the correct way . ok?
best regards
mike
Aug 15, 2009 | Heating & Cooling
Fan Not Working
either bad condenser fan motor or fan capacitor
Apr 24, 2009 | Samsung AW0503B Air Conditioner
No heating, cooling or fan.
I'm confused. You have a Trane, but are asking about the Goodman warranty. I missed something there I'm sure, sorry.
"IF" Trane has a recall or warranty issue, then any qualified technician should be able to help you with that. The parts would be provided by trane in such an event, but unless the unit is less than 1 year old, chances are you will have to pay for the labor.
Being an electricain help if you want us to assist you in troubleshooting.
This link takes you to the TRANE contact page. They can answer any warranty/recall questions you have.
Jan 21, 2009 | Heating & Cooling
Heating & Cooling Logo
598 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
