Question about Maytag EPIC MFW9700S Front Load Washer
Washing machine Maytag has F02 display problem
My mhwz400t has no power no lights at all
Posted on Sep 23, 2009
I have a problem with a f02 error
The washer is not finishing the cicle and is showing error f02
Aug 03, 2013 | Maytag EPIC MFW9600S
Maytag washer throwing fault code 21
An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
May 20, 2012 | Maytag Washing Machines
Hello My Maytag black front loader washer is displaying an error code of F02. Do you know a fix for this error code? Thank you
Hello & Welcome to FixYa
F02 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 07, 2011 | Maytag Washing Machines
Washer displaying FO2. What does this mean. Tenant called me I am out of town. Need to know what the problem is. Thanks!
F02 means its detecting a slow draining condition. The drain pump clean out is most likely clogged. This is located behind the front panel and has a removable cover.
Jan 13, 2011 | Maytag MAH8700A Front Load Washer
F02 keeps showing on display
If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
Cause: wrong detergent, too much of the right detergent, detergent placed in wrong compartment.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 18, 2010 | Whirlpool GHW9400 Duet Washer
Won't drain properlt and F02 error
Junk in the pump, clean out the pump filter and test it. Otherwise the pump impeller may be shot.
Dec 30, 2009 | Maytag Washing Machines
What is a code 2 error for a Maytag Epic wash machine?
F02, usually means drain hose or pump screen is blocked or pump is defective. Using the wrong soap can also cause this problem. Be sure you are using soap marked with the letters "HE" on the front of it.
Helps to have the model number, if possible.
Oct 01, 2009 | Maytag Washing Machines
Maytag EPIC MFW9700S Front Load Washer Logo
229 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
