If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchased a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ If you see these sites by "MOSAIC" or "Magazine" view will make surf easier. Or type in the brand name of your device in the search box, and press "Enter".
Universal remote controls are available at most of the electronic spare part selling shops.
SOURCE: Vizio L32 HDTV 10A-remote
Try a new Remote control, and if that doesn't fix the problem, it may be a remote sensor in the set. Hope this helps. Have a great weekend
Ed
NC Electronic
Mills, Wyoming
SOURCE: Can't get Digital TV (freeview)
Change the input to antenna.
If it says cable:
On your Samsung remote is a button that says antenna. You want it to say AIR. Air is an ATSC tuuner that allows you to receive over the air HD with a pair of rabbit ears.
If it says AIR:
If it says AIR and you still can't get the HD channels. In the menu it will say Channel. In that sub menu it will say autoprogram. Make sure you have an antenna connecte to AIR in the back of the set and autoprogram AIR only.
Any questions respond to this post and I will respond.
SOURCE: Polaroid HD flat screen TV with DirecTV
I have Polaroid TV Monitor HDMI LCD 15.4" no power light on TV, blank screen, the power adaptor is Ok 12VDC supply. I need suggestion; in any possible problem or parts busted?
SOURCE: cant work my freeview
The [A/D] button on the remote control switches between analogue and dgitial TV.
If this doesn't work you can restore the TV to factory settings as follows:
Press and hold the [Menu] button on the TV (NOT on the remote)
The picture / sound / features menu will appear.
Continue to hold until this menu clears.
Release the [Menu] button and wait for about 90 seconds.
The TV will go blank and eventually return to the original install menu.
Install the TV as you did from new.
This will clear ALL analogue and digital TV channels and install again from scratch.
This should be used if the TV ever freezes on digital, or if any of the channels appear in the wrong place or not at all.
SOURCE: Power to TV, cant power on, red light flashing
The repetitive blinking light is a trouble code which is used to determine which series of boards may need to be replaced. How many times does the red light blink?
