Question about Royal ET510 Typewriter
The keys on the left side of my circa 1933 Royal typewriter gets stuck on the ribbon everytime. Also my ribbon doesn't advance. Help?!
  • 125 Answers
Hi:
The most likely problem is there is dirt inside the ribbon basket. This is the area where the type bar (this is the bar with the actual letter on it) ends. They all fit into a semi circle area. If you can find something very narrow and thin with a hook on it you can use it to clean out the areas where each type bar goes. Then try to lightly lube the entire basket right where the type bars pivot with something light like sewing machine or 3 in 1 0il. As far as the ribbon reverse goes it might be as simple as making sure that the ribbon is being fed through the ribbon reverse forks which are usually located left of each ribbon spool.
Good luck
Andrew
Posted on Jun 28, 2009
I have a circa 1940s royal typewriter. Bought it from a professional online who claimed it worked, everything looks good but the carriage and ribbon will not move. Tried messing with the margin buttons but...
Sometimes they had a carriage lock for transporting it. Check for a little lift up lever thingy at the base of the carriage on the bar that goes across from one side to the other. Or just check around for any little levers that hold the carriage in place.
Cheers
Nov 16, 2014 | Office Equipment & Supplies
My vintage Royal manual ribbon cartridge does not advance when typing., stuck in same position.
Usually lubriction, there are small pawls or teeth that move gears and pegs that fit into the ribbon. make sure you have the correct ribbon.
Oct 07, 2014 | Royal Office Equipment & Supplies
Royal FP Typewriter's left Magic Margin is not holding. How can I fix it?
There is a spring that holds the margin together locking in place, most likely the spring is gone or the teeth are broken.
Mar 01, 2014 | Royal Typewriter Circa 1957 Fp
I just got a typewriter (I think it's a Royal #10, circa 1933) and it was working perfectly, but then I hit the margin release key (I think this is the last thing I did) and now all of the hammers only go...
The mech that locks the keys at the right margin did not return to position after margin release. Probably sticky with age. Tough to talk you through but it needs to be cleaned and lightly lubed.
Dec 20, 2010 | Office Equipment & Supplies
I have a circa 1940's-50's Royal Desktop Typewriter. The ribbon that was already on it was rather worn and severely faded so I bought new ribbon for it. The only available ribbon was a red-black silk inked...
You have the ribbon on wrong. The ribbon dosen't feed off the spool but take up onto the spool. install the ribbon so that the moving spool is taking up the ribbon.
DickyO
Oct 16, 2010 | Royal MS 25 Typewriter
Ribbon will not advance
mark the ribbon where it turns, where there is a pin of the typewriter passing through the ribbon,mark it with a white marker.
and type something, if it doesnt turn, you know the machine has a problem.
or try everytime pressing on the ribbon, if it works you know the ribbon is coming up, check if the correction ribbon is placed good.behind the correctable ribbon.
unaasp192
Feb 17, 2010 | Royal Office Equipment & Supplies
How to replace ribbon on Royal Apollo 10 elec typewriter???
The cover either pulls up straight or there is a release lever in the front part of the cover that pushes.
Dec 15, 2009 | Royal Office Equipment & Supplies
The ribbon wont advance
The ribbon drive on this model are gear driven..a .may be off, a loose set screw on one of the gears..the ribbon may be the wrong one or it has a ribbon reverse lever on the side of the machine, this should be free of binds.
Hope this helps........
Squipps
Oct 07, 2009 | Royal Office Equipment & Supplies
Royal ET510 Typewriter Logo
146 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
