Question about Refrigerators
The bottom of the freezer is covered in ice and water leaks through the door.
    President:
  • 1,136 Answers
Hi, The defrost drain is plugged. Remove the rear inside freezer panel and locate the drain hole under the evaporator coils. Remove all the ice and flush the drain hole out with hot water.
I hope this helps you and please let me know if I can assist you further.
Vic
Posted on Jun 28, 2009
Tfx25ppbb. Water leaks into bottom of freezer when refilling ice tray in automatic ice maker. Ice still gets made but water leaks to the bottom of freezer. When enough freezes, it leaks out the door
It's probably not the ice-maker. It has a plugged drain. This is located in the back wall of the freezer near the bottom. remove the evaporator cover...(the back wall of the freezer). Below the coils is a trough with a hole in it where the defrost water drains. This is probably frozen over.
Pour some hot water in to trough until you see drain hole. Keep pouring until water runs thru drain. May have to shut down ref to get it to defrost.
Oct 20, 2014 | Refrigerators
How to clear out the drain tube on a kitcheaid refrigerator
Freezer has been leaking water at the bottom. I opened the drawer/door and removed the bins, there was a small amount of ice formed on the bottom at the back, I broke it away and poured a small bit of warm water in the black drain hole. the next day the bottom and rear are full of frozen ice and it is difficult to open the drawer/door to the freezer. Everything is covered with frost. Help!
Jun 18, 2014 | KitchenAid KBFA25ER Bottom Freezer French...
Bottom freezer is leaking water. Water seems to
You have a clogged defrost drain. The problem is fixed by unplugging unit from wall, open both doors, blow fan for 24 hours to SAFELY remove the ice covering the drain hole. If you use ANY other method, you may regret it. Once ice is melted, remove debris that is likely blocking the small drain hole, if no debris in drain pan, direct some high pressure air down the drain to block the debris INSIDE the tubing. Furthermore, its a good idea to make the drain hole in the drain pan larger, as sometimes a bubble of water can freeze in the drain hole, and ice could be the cause of your blockage from that bubble.
Jun 28, 2010 | Amana ARB1905C Bottom Freezer Refrigerator
Water leaking inside freezer and forming ice in the bottom then leaks water out freezer door
you need to clean out defrost drain hole maybe have to remove back cover of frezzer i use a turkybaster with hot tap water to force hole opan
Feb 13, 2010 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
GE tfx22r leaks water out bottom of freezer door. Bottom of freezer covered with ice. Vacuumed and cleaned evaporator and coils. ice maker water is shutoff. Water seems to be coming out from behind crisper...
defrost drain is clogged, remove back panel, and pour hot water down drain and blow it out with pressure of some sort until water passes freely
Nov 01, 2009 | Refrigerators
Maytag side by side fridge freezer leaking water
Your drain plug within the evap area of the freezer is frozen, turn frig off, let sit for day or two with doors open. Once all ice has melted then take rear freezer evap cover off and pour water into try and make sure it drains, if not then unplug drain. This is usually caused by a defrost heater bad or unit not going into defrost when it's supposed to, may be main board.
Sep 30, 2009 | Maytag Sovereign 60 Side by Side...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
GE frig just starting leaking water at the bottom of the freezer side door
more than likely you have a frozen defrost drain look in the bottom of your freezer section there should be a depression there see if its just a big block of ice let me know if this is the case or not and ill tell you how to clear the drain if not then we will look at something else please dont rate me till were done
Jan 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
