Question about HP Computers & Internet
Laptop fell to the floor and when it powers up a message pops up and says Operating system can not be found. What does that mean?
  • ginavondinke Jun 28, 2009
    Thank you for the quick response... How do I remove and reseat the hard drive????
  • 28 Answers
If i had to guess I would say that the hard drive in your laptop was damaged or there is a bad connection now. If you can access your hard drive i would inspect it for damage and any loose connections. If the problem still persists I would suggest replacing the hard drive.
Posted on Jun 28, 2009
    President:
  • HP Master
  • 1,314 Answers
One of two possibilities:
1. Your hard drive popped out of place and needs to be reseated. Remove and re-insert the hard drive.
2. Or, more probable, the jolt of the fall caused damage to your hard drive and you will need to replace it.
  • Kevin Shafer
    Kevin Shafer Jun 28, 2009
    Hard to say since I don't know what model you have. However, on the bottom of the laptop should be a cover with screws. Next to each screw that you need to remove is a picture indicating disc drive...usually 3 circles one above the other. Remove those screws, pull out the hard drive and put it back in again.
Found an older laptop of mine ,would like it to work saying operating system not found, does this mean its time to get rid
Not necessarily. This means the operating system is either damaged or missing. If you are not receiving any messages about a failing drive you may be able to simple reinstall Windows from a Windows CD. Online Virus Removal 39 99 Online Virus Removal and Online PC Help
Mar 12, 2015 | Fujitsu AMILO Computers & Internet
Operating system not found
I would suggest you may have a hard drive error. A replacement drive will need the OS to be installed. you may be able to recover your old drive with a USB harddrive adapter and lead.
Nov 30, 2013 | IBM ThinkPad 240X Notebook
The computer does not boot into the operating system and displays "Operating System not found."
For that problem, do this first check-up your bios setting.
Power on your PC laptop
, when screen popped up ( press F2, delete etc. ) to get into standard bios Setup you see there if your hardisk drive detected or not detected. if not detected try to open your Laptop PC ( need power off. open cover at the back of your laptop ) check-up your hardisk drive for loose power cable, data cable hardisk Some burn , noise hardisk sound ) if detected, your operating system corrupted. you need to Reinstall your operating system like windows xp, windows 7 or linux base operating system. try that Solution first.
Just let me know if not yet working your laptop PC.
Regard.
Aug 26, 2011 | Toshiba Satellite M30 Notebook
My Toshiba Satellite A105 was accidentally dropped on the floor. When I turned it on and after choosing "HDD" from the Boot Menu, the screen would display this: PXE-E61: Media Test Failure,...
Sorry but Unfortunately Hard drives (HDD) are very susceptible to physical shocks and can be damaged that way. It may be possible to take it to a repair center to see if they can salvage some of you data but their are no guarantees.
If you found the information helpful please rate my response.
Aug 07, 2011 | Toshiba Satellite A105 Notebook
Sony VGN-TX750P laptop Operating System not found message
try seating the hard drive, the HDD might have been loosened when you changed the part.
Hope it helps!
Feb 14, 2010 | Sony VAIO VGN-A170P Notebook
Pxe-e61,pxe-m0f
No; the message indicate absence of hard drive.
open the laptop and remove the hard drive and reinstall it.
if the message still appear then your hard drive is faulty.
Jan 01, 2010 | IBM ThinkPad T42 Notebook
My Compaq Presario F700 dropped approximately 2 feet to the floor from on top of a suitcase at the airport. It was in a case, but not a thickly padded one. When I tried to use the laptop after the fall,...
Try reseating the hard drive and the RAM modules, the fall may have slightly loosen these components.
The error message "Operating System not found" means the laptop could not find the hard disk, this problem could be the hard drive needs reseating, a faulty hard drive (they don't like being dropped), or a faulty disk controller.
Apr 28, 2009 | Compaq Presario 1692 Notebook
Ibm thinkpad prompt: operating system not found.
that message means that windows 2000 professional/98 is not installed which means you have a blank computer you need to put the disk that came with it in and install the OS or purchase one but i'll warn you now those disk are not cheap around a couple hundred bucks
Apr 06, 2009 | IBM ThinkPad T21 2647 Notebook
I probably meant to say "reseat" the memory. Just remove the memory module(s) and reinsert them in their slots. This problem can also sometimes be resolved by reseating the hard drive. I had this happen to me just the other night. The laptop slid off of my lap and fell to the floor. Just fell about a foot and a half, and didn't hit all that hard. Kinda partially caught it as it went. But the laptop didn't like it and I had a message of "Operating system not found". Reseating the hard drive had me up and running in about 30 seconds.
Ron-
Jun 22, 2008 | Acer Aspire 3680 Laptop
Operating system not found, hard disk not found message showing in IBMT20
On my ThinkPad Notebook Windows 7, I have got "operating system not found" error, to fix problem, Windows Boot Genius helped me finally!
Dec 26, 2007 | IBM ThinkPad T20 2647 Notebook
Computers & Internet Logo
319 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
