WRONG! At least CHANGE the FLTER and 6.75 quarts of MERCON V transmission fluid, not anything less!! $ 5.50/quart at Advance Auto. Get a Haynes manual or similar - it's NOT clear, what to do either! AT LEAST do what's being described for this "life-time sealed A05 Automatic transmission! Now if you have the BMW car A06 speed (so-called) transmission - YOU"VE got a REAL PROBLEM + use MERCON SP fluid ($ 10 per quart).
NOTE car MUST be SAFELY, up at least 18" from the ground and LEVEL. Parking Brake ON and BLOCK front and rear of ALL tires! To CHECK fluid level Trans must be at least 80 degrees F and ENGINE RUNNING = DANGEROUS !
The problem is you need a screw in fitting to properly fill and check the A05 speed Automatic transmission ADAPTER (up to 100 dealer) 9 at Amazon worked for me. A small pump with hose (similar, but larger than what hand soap uses) (from $ 6 Amazon to $ 32 - $ +9 at the car stores). A new filter ($ 18 to $ 100). WARNING some filters say they come with a Gasket, the don't! The gasket is special metal and silicone should be reusable IF you don't tear or over torque (tighten). REMOVE Drain plug, the trans pan 15 small bolts, take off pan CLEAN WELL, remove magnet CLEAN, remove two small bolts on filter, LET DRAIN 20 plus minutes. Wipe with clean, lint free cloth ALL of the bottom of trans - then LIGHTLY clean the gasket surface. bolt up the new filter. Lightly install all bolts. Then LIGHTLY with a short 1/4" ratchet tighten all of them.- NOT TOO TIGHT!
Remove the Torx screw/plug from the middle of the Drain Plug - screw in the Adapter, put pump hose onto it - pump 5 quarts into pan. Start engine, pump the next 1.75 quarts into transmission. Using another CLEAN transmission bottle, remove the hose AT the top of the pump - put into the bottle, when about a 1/4 th of a quart drain out on its own - remove the Fill adapter - reinstall the Torx Plug. WIPE all off evidence of oil - drive! Check for leaks the next day!
While doing this, why not protect your investment AND SAVE MONEY? Change the Oil, Oil Filter, Fuel Filter? Use Purolator or Ford Brand Filters ONLY! Use 15-40 Chevron Delo Diesel Grade Oil or Shell Rotundunda . In 500 miles or less I would suggest replacing oil and filter - NEVER MIX OILS. (or use WD40 (designed for arthritis - it's fish oil with water IN it! Destroys engines! Factual Opinions' count, feelings base on LIES, don't!
Larry [email protected] put on Subject: line, your comment!
SOURCE: No transmission fluid Dipstick on my 2007 Ford Fusion
depending on which trans it is there is a small dipstick on the trans at the front on the bottom these transmissions take a specific fluid so be careful
SOURCE: 05 Ford Explorer Transmission
on the bottom of the transmission pan you will find a nut with a hex or torx in the middle you remove the center plug when the truck is hot and running on a level serface the trans fluod will dribble out if it does not dribble out it is low if it runs out fast a steedy streem it is over full now their is a part that screws into this for a fill if you remove the pan you will see how it works the pan has a pipe/ stack that when full of fluid the top of the pipe is at the full point if you remove the large nut the stack and plug will come out the best way to change the trans fluid is take it to some place that has a fluid exchange equment this will get all the fluid out including the torque converter
SOURCE: how can i check to transmission fluid level in 2005 ford explorer
Does not have a dip stick.
Start the vehicle set park brake
In the side if the transmission oil pan a bigger bolt with a small bolt in the center.
Remove smaller center bolt trans fluid should drip out at a fairly constant rate if not its low.
Hope this tip helps.
r/
David
SOURCE: 2007 Ford Expedition EL Limited 4x4 ... no
On the bottom of the trans pan,there should be instructions.
You warm up the trans to 180 degrees or more,hold the drain plug with a 22mm wrench or 7/8",then remove the 1/8" pipe plug in the center with a torx bit.
If filled correctly fluid should just barely run out.
Capacity is around 12 quarts total.
You only get about four to four and a half, if you remove the drain plug or remove the pan to change the filter. Some extra will drain down while your doing the filter.
You need to have a special container that hold two quarts at a time, then you put an air hose to it,to pressurize,and blow the new fluid in,warm up,and any extra will drain back into your fill container.
I found on my Lincoln LS, you can fill it by removing the 3/8" tail housing plug. The other rear drive fords may be similar.
You want to get the old fluid out including your power steering every couple years or 30,000 miles.
I drained mine twice, ( 8 quarts),drove it two weeks to make sure it shifted okey,then repeated. (16 quarts total) I prefer that to a flush machine. I used to own a trans shop.
Use Mercon V and a bottle or two of Red Lubegard on final refill.
Use the power steering additive from lubegard with the correct P/S Fluid.
They are the only two chemicals I ever use on a vehicle,that I know ,not only work, but are necessary on some foreign trans.
If you look at the drain plug when it is out,you will see an extension tube. That is how the correct level is obtained with the torx plug out and fluid warmed up. You need the vehicle up on stands and level,so you can get under it.
SOURCE: How do you change the
if you drained it then you need to look in your owner's manual for the right amount of fluid that your transmission takes then put fluid through the transmission fluid dipstick. If you got any question plz feel free. Good luck
